Uprating rear suspension?
I have a 150 ps 2.0 TDi Estate, and always intrigued me how such a large estate car doesn't come with any levelling suspension.
I don't often carry heavy loads but can on occasion have three / four passengers and the boot almost filled to the roof.  The car drives okay but evidently sags a bit at the rear with such weight.  Are there any reasonable cost efficient ways to help support the rear when loaded up?  I have seen the rear springs and they look far too small diameter for any assisters being mounted inside?
You've probably got 3Q0511115AK rear springs. If so, simply change to one or two weight ranges higher in the range. ie. either 3Q0511115AL or 3Q0511115M.
You can see in the chart below, that 3Q0511115AK is a weight range 3 rear spring (0YC means weight range 3). 3Q0511115AL is a weight range 4 rear spring (0YD means weight range 4). 3Q0511115M is a weight range 5 rear spring (0YE means weight range 5).
As you are sometimes carrying a lot of weight, I would go up two weight ranges to 3Q0511115M, such as the Kilen 65126 that I've linked to at the bottom of this post. If you are handy with using axle stands and a trolley jack you should be able to easily change the rear springs yourself. Cost of the two rear springs is about £70 on ebay.
1 3Q0 511 115 AK coil spring   2 PR-1JA+0YC
1 3Q0 511 115 AL coil spring   2 PR-1JA+0YD
1 3Q0 511 115 M coil spring   2 PR-1JA+0YE
https://volkswagen.7zap.com/en/rdw/passat+4motion+santana/pa/2015-793/5/511-511000/
3Q0511115AK
https://www.autodoc.co.uk/car-parts/oem/3q0511115ak
3Q0511115AL
https://www.autodoc.co.uk/car-parts/oem/3q0511115al?search=OEN 3Q0511115AL
KYB RA5331 3Q0511115AL
https://www.ebay.co.uk/itm/234261383575?epid=7044603631&hash=item368b110997:g:ePkAAOSwkZZhe96G
Kilen 65125 3Q0511115AL
https://www.ebay.co.uk/itm/234351928372?hash=item369076a434:g:W3wAAOSwLjdhyCjN
3Q0511115M
https://www.autodoc.co.uk/car-parts/oem/3q0511115m?search=OEN 3Q0511115M
Kilen 65126 3Q0511115M
https://www.ebay.co.uk/itm/392296332152?hash=item5b56aefb78%3Ag%3AVbUAAOSwgq1c2YpV&LH_ItemCondition=1000
All the above information, assumes you have a Superb MK3 2.0TDI estate FWD car and that it has standard ride height.
Edited by Carlston
Have towed caravans and car trailers with my Octavia and Karoq and I have always fitted helper springs
from Mad
https://mad-suspension.co.uk/
Thank you all for the replies, gives me some options to consider.
from Mad
Do they affect the ride when solo much? Thanks
Not at all thy only start working when you load them up the ride height stayed the same as well
Thanks, that's really useful.
Is anyone able to advise what's involved in replacing the Superb mk3 estate rear springs?
Found some conflicting information and the official manual isn't clear if the "official" method is merely compressing the spring to remove it?
Thanks!
Thanks!
If you had the right design of compressors then you may get away with this method.
I undid the lower shock mount on both sides to drop the rear enough to get the spring out. It's the most common way on the majority of cars. Rear drive or 4wd will probably be harder whichever way you do it.
Just be sure to have both sides in the air.
Hi all again,
One other question, was self levelling suspension available for the car like Nivomats are on other estates?
Thanks,
  • 8 months later...
3Q0511115AK
3Q0511115AL
3Q0511115M
Hi,
Coming back to this, do we know what the difference in weight ratings translates into in kg for example?  Would be good to get an idea of how big the difference is between the different weight ratings?
Thanks,
36 minutes ago, MrRich said:
Hi,
Thanks,
You would have to look at the specifications of the springs, such as on autodoc.
In general, one weight range higher is about 5% stiffer, and two weight ranges higher is about 10% stiffer.
If your springs are old and starting to sag you might just need new springs of the same weight range as what you have now.
So often, people tend to overcompensate when their current springs are starting to sag. One Superb MK3 owner felt sure he needed much stiffer rear springs than standard, but when the garage fitted new standard springs he found that the car drove fine on those and no longer had the desire to go stiffer.
How much weight you tend to carry in the car will have a big influence on what the right stiffness of springs is for you. It's a careful balancing act.
Edited by Carlston
Thanks.  Do we know which ones were fitted to cars with factory tow bars?
You can find out what springs were factory fitted to your car by looking at the car's build codes. These are available from an ebay seller for about 3 Euros. Search "skoda vin decoder" on ebay to find the listing.
https://www.ebay.co.uk/itm/224631127243
If you don't want to go down that route, you could measure the wire diameter of your rear springs. 12.25mm wire diameter might mean that you have 3Q0511115AK rear springs. 12.50mm wire diameter might mean that you have 3Q0511115AL rear springs. 12.75mm wire diameter might mean that you have 3Q0511115M rear springs. Not all aftermarket brands agree on these wire diameters matching these OEM part numbers. However, Spidan are one of the better aftermarket brands for giving reliable specifications...but even they can sometimes make mistakes.
You might even find the OEM part number on a white label attached to the spring.
Spidan springs don't appear to be as reliable as they once were, as I have heard of many early spring breakages. Maybe Spidan have outsourced to China with a resulting loss of quality. I suspect there are many other aftermarket brands selling the same springs as Spidan, such as Suplex, SKF, and Quinton Hazell. It was only after Spidan springs started having lots of early breakages that SKF and Quinton Hazell appeared on the market, so maybe this was a kneejerk reaction by Spidan to maintain their market share. Many of these big aftermarket brands are owned by the same company or are somehow connected. Spidan, Suplex, SKF, and Quinton Hazell always seem to give exactly the same specifications for their springs, which is why I suspect they are connected to each other.
3Q0511115AK
Length: 364mm
Wire Diameter: 12.25mm
https://www.autodoc.co.uk/car-parts/oem/3q0511115ak?search=OEN+3Q0511115AK&supplier[0]=246&supplier[1]=1
3Q0511115AL
Length: 359mm
Wire Diameter 12.50mm
https://www.autodoc.co.uk/car-parts/oem/3q0511115al?search=OEN+3Q0511115AL&supplier[0]=1&supplier[1]=246
3Q0511115M
Length: 360mm
Wire Diameter 12.75mm
https://www.autodoc.co.uk/car-parts/oem/3q0511115m?search=OEN+3Q0511115M&supplier[0]=246&supplier[1]=1
Edited by Carlston
Hi,
Sorry I wasn't very clear.  My car has the soft springs 3Q0511115AK according to the build sheet I have, so wondered what the tow pack equipped cars had instead.  I have ordered the Kilen 65126 3Q0511115M this evening so will install those and see how it goes.  Thank you for the help.
27 minutes ago, MrRich said:
Hi,
Fitting Kilen 65126 which match OEM part number 3Q0511115M does seem like a good idea.
If the springs feel a little hard afterwards, you could always fit the most comfortable Superb MK3 tyre size, ie. 215/60R16, to help soften the ride.
If you have a Superb MK3 272HP/280HP 4x4 then that car uses big 340x30mm front discs, which need at least 17" rims to clear the front brake calipers.
Edited by Carlston
  • 2 months later...
Hi, I have an superb 2.0TDI 4x4 sportline estate and feel that it's a bit soft in the rear suspension when loading and towing an caravan.
Does anyone know if their is an stiffer spring that I can change to without sacrifice the look of hight onloaded ?
Regards
10 hours ago, gnuttisch said:
Hi, I have a Superb 2.0TDI 4x4 Sportline estate and feel that it's a bit soft in the rear suspension when loading and towing a caravan.
Does anyone know if there is a stiffer spring that I can change to without sacrificing the look of the height when unloaded ?
What OEM part numbers are your current front and rear springs?
Did your car come with a factory fitted towbar? If so, it should already have slightly stiffer rear springs compared to a similar car that didn't have a factory fitted towbar.
It may be, that the rear springs have started to sag with age and simply need changing for new springs.
You can see in the chart below, that the Skoda parts catalogue lists ten rear springs for the standard ride height Superb MK3 4x4 (the code 1JA means standard ride height). The first five rear springs in this hierarchy are probably too soft for the 4x4. I suspect that you may need something like 0YF (weight range 6) rear springs, or 0YG (weight range 7) rear springs in the below list, ie. 3Q0511115N or 3Q0511115P.
No Part code Title Note QNT Model Price
    suspension
Shock absorbers
    4-wheel dr.+ -
1 3Q0511115AH Coil spring   2 PR-1JA+0YA
1 3Q0511115AJ Coil spring   2 PR-1JA+0YB
1 3Q0511115AK Coil spring   2 PR-1JA+0YC
1 3Q0511115AL Coil spring   2 PR-1JA+0YD
1 3Q0511115M Coil spring   2 PR-1JA+0YE
1 3Q0511115N Coil spring   2 PR-1JA+0YF
1 3Q0511115P Coil spring   2 PR-1JA+0YG
1 3Q0511115Q Coil spring   2 PR-1JA+0YH
1 3Q0511115R Coil spring   2 PR-1JA+0YJ
1 3Q0511115BC Coil spring   2 PR-1JA+0YK
Edited by Carlston
Where can i find the OEM, dont think it still labeld on the springs?
Yes, it got towbar from factory.
But the car is from 2018 and runned about 5200 miles, dont think that is sagging already ?
And the car is an sportline, so should already been lowered with 15mm? but dont have any DCC
When Iam towing or heavely loaded, the car feel swamping and low in the rear.
2 hours ago, gnuttisch said:
Where can i find the OEM, don't think it still labeled on the springs?
But the car is from 2018 and runned about 5200 miles, don't think that is sagging already ?
And the car is an sportline, so should already been lowered with 15mm? but don't have any DCC
There's an ebay seller that can supply your car's build codes for about 3 Euros.
search "skoda vin decoder" on ebay to find the listing
You can also find your build codes on "skoda erwin" for 7 Euros, and you can get downloaded manuals for your car. The 7 Euros gets you 1 hour's access. Most people seem to be able to download what they want in that time.
You can decoder the codes, on "VW codes decoder"
http://igorweb.org/equidec.aspx
Codes have 3 digits, comprising numbers and letters, so look something like this: 1JA, 1JC, etc.
If you have lowered ride height aka sports suspension, your rear springs should be in the below chart. Note that 1JC means lowered ride height.
Lowered ride height rear springs for Superb MK3 4x4
1 3Q0511115S Coil spring   2 PR-1JC+0YA
1 3Q0511115T Coil spring   2 PR-1JC+0YB
1 3Q0511115AA Coil spring   2 PR-1JC+0YC
1 3Q0511115AB Coil spring   2 PR-1JC+0YD
1 3Q0511115AC Coil spring   2 PR-1JC+0YE
1 3Q0511115AD Coil spring   2 PR-1JC+0YF
1 3Q0511115BH Coil spring   2 PR-1JC+0YG
1 3Q0511115AE Coil spring   2 PR-1JC+0YH
1 3Q0511115AF Coil spring   2 PR-1JC+0YJ
1 3Q0511115AG Coil spring   2 PR-1JC+0YK
1 3Q0511115BD Coil spring   2 PR-1JC+0YL
Edited by Carlston
So I got my buildcodes from ebay, and found these that seems intresting.
0YF Weight range 6 installation control only, no requirement forecast
1JC Shock absorption in rear, sports version
Is it 10% harder springers per row ?
28 minutes ago, gnuttisch said:
So I got my build codes from ebay, and found these that seems interesting.
The 1JC shows that the car has lowered/sports suspension.
0YF shows that the rear springs have OEM part number 3Q0511115AD.
You can see on this thread that Bigeater has a Superb MK3 280HP 4x4 sportline with 3Q0511115AC rear springs
https://www.briskoda.net/forums/topic/478335-does-the-sportline-have-stiffer-suspension/page/8/#comment-5731492
So it looks like similar models that left the factory with a towbar fitted one weight range higher rear springs, ie. 3Q0511115AD.
autodoc aren't listing any aftermarket lowered ride height rear springs with a weight range higher than 0YF, so I suggest simply trying new 3Q0511115AD rear springs.
EIBACH R22928 rear springs 3Q0511115AD
What wire thickness are your current rear springs? You can then compare to the 13.75mm wire diameter of the Eibach R22928 rear springs.
Okay, I will look in to it.
Thanks for your excelent help!
  • 2 months later...
Suppose this is a bit of an older thread now but I figured I'd ask, don't suppose anyone has fitted the 3Q0511115M (as I fairly often carry a car full of people/towbar fitted bike rack) rear springs onto a 1.6 diesel salon/hatchback? was tempting myself as the rear of my 17 superb sits quite low unloaded so need to replace the fitted springs anyway
