Software Update...?
23 hours ago, rudineu said:
@DaniC: Be carefully, first install the 306. Do not jump directly to 330 by installation
I have one more question. In upper link, MEGA link, there is two firmwares. 306 and 330 and ther are some other folders named 5WA035284SW141 and 5WA035284OCU143. Both of them inside of them have two folde named Data and Meta.
Do I have to do something with them or no. I just have downloaded firmwares, do I have to download and that 5WA035284SW141 and 5WA035284OCU14 with Data and Meta. If yes, then how to proceed ?
Thx !
  • Replies 260
  • Views 78.2k
  • I have sent you a new link, they only live for 24hrs. Since you usually sell the firmwares, please don't ask for more... this is not why I send them.  I hope you understand my "spirit"
  • 308 https://mega.nz/file/dgNAADwQ#h7p60yQb9OmM0pQ2O9nZvIPsi_k9TMnwOm83pBj3hmY 332 https://disk.yandex.ru/d/p21TSZ9mKJcTVQ
  • You should already have a private message.   The release is a 2 in 1 package, so it has 2 stages of update.  First takes you to 0308, after it has rebooted and settled, you will be able to l
Last question I hope...ahahahaha...I need for Skoda Kodiaq FL. Amundesn system without sd card. Only 2 USB-C port.
Thx !
Simply USB stick
Ahahaha...great answer...I did not ask the right question. Is this software form last link and from link befor the last ok for amundsen for kodiaq fl...or it is not important what model of car is ?
Es para todos los modelos MIB3 Skoda.
330 update need almost  Sw 308 not 306.
main.txt
This is 308. You can use this instead 306.
5WA035284SW141 and 143 are OCU updates not needed to infotainment update.
Are these OCU updates the latest updates for amundsen and are they compatible with 330 firmware...or should I not install them ?
Will I see any changese after I update from 304...to...330...Is there any visual changes ? What new firmware improvements ?
Thx !
The car have more than 30 ECU'S.
One is 5F , infotainment system, " your amundsen" and the last update is 330.
Rear camera and wireless phone connection work better with It.
@DaniC have you been able to update your Kodiaq? I have the same issue, but my software version is 306. Same confguration - Kodiaq FL with Amundsen unit.
Hardware: H22, Device number: 3V0035820K
I have constant issues with Android Auto. If it is ativated and I need to drive backwards (for example from the parking lot), as soon as rear camera switches off, I cannot access bottom menu of Android Auto screen anymore, and navigation (Waze or Google Maps) gets very slow. To fix navigation issue I'm switching on the air conditioning menu and then switch back to Andorid Auto. Novigation screen starts to be responsive again, but bottom menu is shown but not operating. THe screen does not react on tocuh in that menu area.
I'm hoping that the update would solve that issue. Do you face similar issue when using Andorid Auto?
I also downloaded all the files - 308, 324 and 330 versions. I understood that I cannot update from 306 directly to 330, and I have to update first to 308. I also read that there are package updates of 308 and than 324 in one update file.
Does someone here in the forum know if I can simply update 308 first, than probably reboot, and update 330 as the next step?
it's right. you cannot update from 306 to 330 (or 324). You must update to 308 and then to 324 or 330.
I had 306 on my Karoq, and I installed 308 and then 330.
After the last update you need to fix 1555 error (not shown on the monitor but only via obd2)
@anthony82 and @AlexB7: yes, you have to do that first. Otherwise you will have troubles in the OCU or you can’t install further relations of the software
Edited by rudineu
Hello,
Would someone be able to help me with files so I can update my Kodiaq please? Please see attached image for current SW Train.
As you can read this tread,  308 and 330
@kernowboi, as vegarz mentioned, you need to install first the version 308, and then 330. You should not update directly to 330 with your current version. All the links to the required files are available in this thread some messages above. If you would get confused with the update instructions, please ask.
I have updated my Kodiaq to 308 about a month ago and decided to wait and see if it will get the next update OTA. Unfortunately, nothing comes OTA to my car (neither with my previous 306 software, nor with 308).
Updating the 0270 ist only possible by the licensed Škoda-garage (dealer). I know nobody who has this release as a file. As far as I know there is a procedure of several double checks between Skoda and the licensed dealers. It make sense up to the step of OTA. Go to your dealer and ask him for support I‘d recommend to you…
Sorry, but… 😪
Be careful, you can disable your running system by using a wrong variant of 0270 !!!
actualización 308, supported trains as main.mnf file.
First updated completed.  No issues to report
That’s fine! Please check in the update menue if all in status are „legal“. Otherwise the OTA to 330 won‘t be possible…
Edited by rudineu
It performed the Navigation update overnight via OTA so I’d hope all is above board!
Hello
Total newbie here. I have read all of the post above and need only to clarify some things.
I have MOI3_EU_SKMQB_P30200P 0302. As I understand I need to update to 0306 and than 0324 and than 0330 ? And one more thing. I have read something about some error after update "Checking SVM error" is that a thing or is this safe ?
Thank you for any advice
Please read carefully this tread.
You only need first update to 308 and after this to 330.
SVM error isn't important, you can let It or clear with Car scanner or any other OBD.
Allright so update to MOI3_EU_SKMQB_P30800P_0308, Just wanna ask. Do I need OBD to clear any error after this ? (I do not have any OBD or car scanner) so i want to be prepared.
I have 0324 update since ... February (when came out a lot of problem) but never came out OTA update to 0330... So... I must update with the USB drive ?
Thank you
Hi, can anyone point me in the right direction to download
MOI3_RW_SKMQB_P30603P
or
MOI3_RW_SKMQB_P30800P
I currently have version 274 and a copy of 324 but I can't get anyhting in between, only Euro versions.
Thanks!
