Exhaust issue
Check your car manual, it will most likely be DPF clogged up.
Please also respond with mileage of the car, every little information helps.
You could also find someone on the map to bypass expensive dealer visit and get a VCDS scan for some beer tokens.
If your profile is correct, and this is a 1.6 Petrol Octavia, then it can't be a DPF issue. DPF is diesel particle filter, so you don't have one.
Exhaust light could come on for a variety of faults, only way to know is to scan it and read the fault code.
If you can't find a local member with VCDS, most independent garages should have the equipment to read fault codes, much much cheaper than main Skoda dealer prices.
  • Like 2
@brummiered  If that was a Skoda Dealership you phoned then at Participating Dealerships in the Fixed Price Servicing & Maintenance the first 30 minutes of a diagnostic is £60.
For a reason best known to Service Desk staff that never seems to get mentioned to callers.
Maybe because they know their tech will be more the 30 minutes with reading fault codes and checking things.
Is your car a 1.6 FSI so petrol or a diesel?
EDIT.
Best plan seeing if a Briskoda member can help with the diagnosis..
  If it is not simply fixed and within your ability then you want a good independent mechanic or garage anyway and not a main dealership.
http://briskoda.net/forums/topic/509262-vcds
Edited by toot
Care to share it with us?
You cannot ask for thoughts on something that has not been explained.
15 minutes ago, promomast said:
toot ... any thoughts on the mechanics diy 10mm hole in the base of the dpf ? .. watched it being done and told the reasoning
Change your garage. As others, a petrol car cannot have a diesel filter in the exhaust.
yus but i have a diesel ... and petrol cars can't drill into that which doesn't exist 🙂
21 minutes ago, promomast said:
hi toot ... it tricks the system into not limping the engine if too much soot i'm told by a very reputable honest sort of mechanic ... doing it to his own audi on the ramp
Nobody with even half an understanding of how a DPF works would suggest doing that
They may not have a diesel particulate filter but new petrols do have a GPF gasoline particulate filter.
mmmm genius idea… not! You drill a hole pre dpf to keep the pressure sensor from triggering. The gases will always take the path of least resistance which with a partially blocked dpf and a open hole, the gas is gonna pour out the hole, you’re gonna get soot everywhere, cancerous gases straight through your pollen filter into the cabin, possible chuffing sound.
ask anyone that’s ever driven a diesel with a exhaust leak - if it’s bad enough you’ll have your eyes watering and coughing, and yet you want to do this on purpose????
Next you’ll be saying if you’ve got a seized brake caliper just crimp the hose off and remove the caliper completely….
just fix the issue properly!
Edited by ApertureS
This is not even mentioning the fact that -
It’s an mot fail
It’s now illegal
its near impossible to hide on an mot cause of the noise and soot build up
You run the risk of the excess oxygen now in the exhaust causing a fire when the regen cycle starts
the EGR won’t operate correctly
On 20/12/2022 at 16:33, brummiered said:
Found problem but
Where do I find exhaust sensors on exhaust
There are many sensors
which one? Lambda, pressure, temperature, nox?
Also - just because a sensor is showing faulty doesn’t mean it’s faulty. For example - dpf pressure sensor showing open or short circuit 99% of the time means neither and is the voltage reaching above or below 0.5-4.5v due to extremely high or low exhaust pressures.
  • 3 months later...
