Intermittent electronics error fault, when cold. Engine runs fine.
lello7
Recommended Posts
I wasjust hoping you might find something that could explain the bad behaviour.
Of course there may well not be anything visibly broken.
A bad solder joint might be seen, maybe with magnification.
PM me anything showing the circuit board, if you get in there for a look, please. 🙂
  • Like 1
Link to comment
Share on other sites
Please note - I am not a mechanic or expert in anything.
On 07/01/2023 at 18:23, lello7 said:
I can not attach any more pictures in this therad 😞
If it is a site issue Freedom membership might resolve that. - https://www.briskoda.net/forums/subscriptions/
Edited by nta16
Link to comment
Update
I now have a new unit, but have not had the time to test it. I need to program it first (among others the radio code is stored there?)
Is it only possible with vcds or is there an cheaper option? I will have to rent regardless, but n vcds near me available.
Mean while, I disconnect the battery and bring the Bcm with mee inside if I leave the car outside for a longer period of time.
The bcm bord looked flawless under 10x microscope magnifying.
I did resolder all pins 73a and 73b, and all relays... Same problem.
This is a multilayered PCB, so I guess its a internal crack or bad connection between the layers.
Any sugestions. I have all diagram for the car, but the actual relay is not presented. Only the connections going to and from it, j519 unit.
Link to comment
  • 11 months later...
Create an account
Register a new account
Sign in
Sign In Now
  • Community Partner
  • Create New...
