2023 280ps L&K replaced 2016 220ps Style
First emotions after one weekend and first ~400 kms
Have to start by few huge disappointments:
1.
Line assist goes from one side of line to other side ping-pong 😞
previous 2016. kept middle of the line
+++ 2023.03.01 +++
dealer answered, additionally to Line Assist must be activated also Travel Assist, not tested yet
+++ 2023.04.07 +++
ping-pong effect can be little bit improved, but fix requires cam software downgrade
-> https://www.briskoda.net/forums/topic/510961-2023-280ps-lk-replaced-2016-220ps-style/?do=findComment&comment=5746167
2.
Adaptive Cruise Control missing manual mode 😞
few kms in snowing condition and there is none Cruise Control at all
my previous 2016. also had this lack,
but i have seen several posts where were reported new [Mode] button on bottom side of Cruise Control stick,
when(~2017~) it came and when(202?) it were removed?
+++ 2023.03.01 +++
solved by coding
-> https://www.briskoda.net/forums/topic/511031-standard-cruise-control-on-an-acc-equipped-superb/?do=findComment&comment=5737174
3.
Engine has lost a cover 😞
as result it's loud as diesel, just without tractor vibration.
still waiting for answer from dealer, will it be added later or never
+++ 2023.03.01 +++
dealer answered, will arrive, no one knows when.
+++ 2023.04.24 +++
retrofitted Engine Cover 06Q-103-925-L for 2.0 TSI 280ps DNFE
+++ 2024.01.15 +++
received an invitation from dealer
4.
Every ignition On/Off resets Driving mode
5.
Mib3 head units don't allow upload logos of Radio Stations
+++ 2024.01.18 +++
managed to find how to update built in database
-> https://www.briskoda.net/forums/topic/520105-radio-stations-logos-database-updates/
Minor disappointments:
1.
L&K had to get Direct Tire Pressure Monitoring System, but mine came without.
not a big deal, as i prefer alternative independent dTPMS sets from Ali,
just for what reason i have bought and mounted second OE sensors set into winter wheels?
2.
There is no coding to activate Eyelashes with DRL 😞
3.
9l on 100km fuel consumption where previous 2.0 TSI 220ps had 7.5
4.
Škoda's Moon White isn't white at all 😞
Huge improvements:
1.
2023. Amundsen Canton soundings much better than 2016. Columbus Canton :)
and i predict, it will even improve after adding sound deadening
2.
Finally i have got feeling of new car, 2023. DCC suspension has zero parasitic sounds.
Instead 2016. DCC had them from beginning and weren't fixed even after couple of manipulations -
warranty change of rear brushes, both front shocks, 3x steering rack,
and later replace all of shocks to Bilstein B6 DampTronic,
which hugely improved driving performance, but noises were gone just partly
yes, new DCC is softer than perfect tandem, Bilstein B6 + Eibach Pro, but acceptable in sport mode, at least for first years
3.
Webasto auxiliary heater can be activated from MyŠkoda app
4.
Blind-spot indicator on Mirrors body is much better place
5.
Boot opening now asks for long press of button,
but can't be closed from interior, Mk3 had coding for that, Mk3.FL hasn't 😞
Edited by MartiniB
  • Replies 84
  • Views 24k
  • Yesterday i finished fantastic 3615 km round trip across Sweden and Norway         Thanks to the default speed limit 80 km/h, got numbers which i haven't ever seen be
  • +1 I did the same with mine - got the AliExpress rear boot spoiler.   So far so good and it's still holding strong and not fading.
Nice upgrade.
Increased consumption is to be expected with more losses being AWD and a higher tuned engine. Are the tyres also wider? More friction.
Moon white is a nice colour, it has a warmer look and in certain lighting conditions looks very good. It is also glossy in appearance which is rare on a white car. I swear you'd pay more as an option for this type of white on some other makes.
2 hours ago, MartiniB said:
2.
when(~2017~) it came and when(202?) it's were removed?
4.
Your new car looks great.
Is the 'manual mode' you refer to as shown in the picture below?. I thought this didn't give the option of manual cruise control but swapped between ACC and speed limiter (this is now done on the digital screen on the latest model).
In my eyes the moon white has a touch of grey about it, personally I quite like it.
My 2c…
I really dislike the chrome strip on the rear of the car. 🤮
Why doesn’t the L&K have a Columbus unit? (I think our 2016 version is excellent btw).
All radar controlled ACC systems deactivate when the radar unit is covered in sh1te and snow.
You didn’t mention the performance of the 280 vs the 220 - you’re not impressed?
as i have read reports, DQ381 7 gears is more economical than DQ250 6 gears
current winter tires are same size as previous 225/55r17
summer will increase in width and decrease in height/circum, 235/45r18 vs 225/55r17
then i had false expectations about [MODE] button,
yes, Speed Limiter can be chosen on Virtual Dashboard
6 hours ago, numskull said:
1. I really dislike the chrome strip on the rear of the car. 🤮
2. Why doesn’t the L&K have a Columbus unit? (I think our 2016 version is excellent btw).
3. All radar controlled ACC systems deactivate when the radar unit is covered in sh1te and snow.
4. You didn’t mention the performance of the 280 vs the 220 - you’re not impressed?
1.
+1 000 000
i have even sent letters to dealer, importer and Škodas CZ support for new options in configurator:
a) ~400e Black Exterior pack Light (Door Trims)
b) ~600e Black Exterior pack Medium (Door Trims, Front Grill, Trunk Trim)
c) ~800e Black Exterior pack Extended (Door Trims, Front Grill, Trunk Trim, Spoiler)
d) ~1000e Black Exterior pack Complete (Door Trims, Front Grill, Trunk Trim, Spoiler, Roof, Rear Skirt)
2.
that were first years privilege, now even Amundsen is paid option 410e
while Columbus costs 1370e, but i chose Amundsen mostly because real volume control roller
3.
sad
4.
I try to limit myself, while numbers on odometer is smaller than four symbols :)
but one change is noticeable, sensitivity of accelerator increased,
if compare with previous, somewhere between normal and sport mode
@MartiniB
I believe the 220 dq250 has been geared longer than the 280 dq250 so it might have well been doing the same RPM/speed as the new 280 dq381.
The old 280 dq250 is about 2500rpm at 110km/h in 6th gear.
The 220 dq250 is about 2000rpm at 110km/h in 6th gear.
Daft ratios for the 280 but it is what it is....lol
looks like i found how to add CC
Module 13 Adaptive Cruise Control
    Long Coding
    -> Cruise Control Mode
        --> Activated
source:
https://forum.obdeleven.com/thread/16300/add-regular-cruise-control-feature
https://forum.obdeleven.com/thread/18012/long-coding-activate-cruise-control
https://forum.obdeleven.com/thread/18036/deactivate-acc-normal-cc
can't test, car is gone to dealer for first unplanned service visit, logo projector tried to escape, wires held it
    Long Coding
        --> Activated
That would be nice to have - I wonder if it allows a bit of over-run on downhill sections rather than braking ?
46 minutes ago, Berisford said:
Are we saying there is a way to have three options, ACC, CC and speed limiter?
Can this be done on a 2017 pre- facelift?
After 2 years I still can't get used to ACC and yearn for the old style CC like in my old mk2 Octavia.
Edited by Jonboy984
16 hours ago, numskull said:
My 2c…I really dislike the chrome strip on the rear of the car. 🤮
I'm of the opposite opinion and really like it, looks quite plain without it.
Good job we're all different otherwise there would be one model only!
    Long Coding
        --> Activated
source:
I'm watching this with great interest to see how/if it works.
Apols to the OP for hijacking this thread, your new Superb looks amazing.
I'll start a new thread in relation to coding standard cruise control to a vehicle with ACC.
Never saw a spoiler on the L&K's boot. Is this aftermarket?
@Codename47
yes, ordered from AliExpress
€64    https://www.aliexpress.com/item/1005004825796047.html
it had small, almost invisible paint defect,
which were repainted just because together with roof, mirrors bodies and rear skirt
i so much like Sportline exterior look, but don't like one piece seats,
especially when they can't have ventilation
+1
1.
That were false expectations, which were born in my sick head.
As my previous 2016. Mk3 had "Tire Pressure Monitoring System",
but in new 2023. Mk3.FL papers i saw "TPM+ with each tire pressure control".
That stupid "+" means Passive TPMS can show which exact tire has problem, not a Direct TPMS as i wrongly imagined.
Option 7K3 - RDKS can be add only for Kodiaqs.
Has Superb lost flagship status?! I can't agree just after touch of interior!
Edited by MartiniB
Sad to report, but here is how Škoda's Simple Clever transformed to Save cents by add Drawbacks
Magnetic Trunk Light Lamp has been gone
i used it just once, but it were useful when had to mount spare wheel quarter past midnight
Armrest Storage Compartment Lamp has been gone
Mib3 Amundsen flaws if compare to Mib2H Columbus
1. Lost opportunity to upload Radio Stations Logos
2. Lost opportunity to manually tune FM stations
3. Can't even see what frequency is tuned right now
4. Several Menu Sections don't contain return button
5. I weren't able to find section with loaded maps version info
Start-Stop has got additionally to previously annoying
1. Cut Off Engine before full stop.
new, not less annoying, "feature"
2. Engine wakes up, when car in front moves even few cms
On the right hand side of the screen press 'Menu', then from the pictures select 'Settings', then scroll down to 'System Info' where you can see the map info.
Mine is currently 23.2
My MY17 Superb does this already.
It will cut the engine before the car has come to a complete stop.
When the Start-Stop is active with ACC engaged, it will restart the engine when the car infront starts moving.
I prefer the start stop cutting the engine off before a stop, it lets you come to a smoother stop since you don't have the resistance from the engine/DSG wanting to creep forward.
It’s rather annoying though when you almost stop then want to go again at a roundabout or crossroads…!
On 12/03/2023 at 23:51, JR RS said:
MY17
on car in front motion, MY23 Engine wakes up in any case -
Start-Stop activated
ACC whatever state
DSG lever whatever state (D/N/P), sorry R weren't tested
booked #2 unplanned service visit (it's joined to seasonal wheels swap)
Mine does a very similar thing, not always, I assumed it was just the pedal hitting a hard stop at the top of its travel. My car is now 5 months old and has often done this since new, having its first service next week so I'll mention it to the dealer.
+++ 2023.03.01 +++
Still disappointed how Lane Assist works in MY23 Superb Mk3.FL
if compare to my previous MY16 Superb Mk3,
where Adaptive Lane Guidance:
1. were able kept center of the line.
2. and were permanently active, just by select one check box in assistants section
while new car:
1. still makes ping-pong within lane,
 with both early/late parameter, early just made it less annoying.
2. and Lane Assist (trough Travel Assist button on steering wheel)
 have to be reactivated every time after ACC were switched off/on
MY16 - All OK
Control unit: A5 Driver Assistance
System description: MQB_B_MFK
Software number: 3Q0980654D
Software version: 0024
Hardware number: 3Q0980654
Hardware version: H04
Serial number: 28011611K20929
ODX name: EV_MFKBoschMQBB
ODX version: 001001
Long coding: 020408010000040100262346C040A00098000E100040
MY23 - WTF?!
System description: MQB MFK 3.0
Software number: 2Q0980653D
Software version: 1401
Hardware number: 2Q0980653
Hardware version: H16
Serial number: EA15674042234100xxxx
ODX name: EV_MFK3ValeoMQB
ODX version: 007042
Long coding
Values:
Point_of_intervention:
Old value: early
New value: early_setting_over_menu
HC_Warn_Intensity:
Old value: No_Setting
New value: Setting_over_Menu
Lane_assist_off_text:
Old value: disabled
New value: enabled
Long coding
Old value:
 00020898116E4020089F10001030008001418000000000000000000000000000
New value:
 00020898116E4020889F18001030008001438000000000000000000000000000
<edit 2023.04.07>
went also through this extended coding list
-> forum.obdeleven.com/thread/18327/tiguan-ehybrid-nordic-adaptive-control
most of which were already set, except:
1.
[A5 Driver Assistance] - Long coding - HC_Variante(Byte 17 > Bit 5-7) - Variant 2
instruction suggests change 0 -> 1
didn't touch it, because i haven't found clear explanation for these changes
2.
[76 Parking Assistance] - Long coding - Byte 03 > Bit 5 - No
didn't touch it, because this Bit has no description for Škoda Superb Mk3.FL 2023 in ODBEleven
while in instruction of Tiguan eHybrid 2021 it's titled as Directional stabilization assist. w. power steering assistance
and suggested change to 0 -> 1 (Installed)
+++ add 2023.04.07 +++
got one one unsatisfactory answer in ODBEleven forum
-> https://forum.obdeleven.com/post/78972/thread
Quote
The Ping Pong effect is wanted from VAG, not to think you are driving half autonomous. It’s a security thing.
I let downgrade my cam Software to use the straight in line driving again like it was up to 2019 VAG models. You need a guy with Odis or Vcp for that.
what created next questions:
which module?
to what sw version?
is then calibration required?
Edited by MartiniB
