Software Update available for Bolero?
Hey dear varoom,
I have kamiq 2023 with bolero system my current versions are in the photo attached to this message.
I have a problem connecting my oneplus 11 to the android auto can you help me find a software update that might help
  • Replies 785
  • Views 227.5k
  • There are these updates, but not sure if the higher number will apply to your system.   MEN3_EU_SK370_P0113P_0469 MEN3_EU_SK370_P2135P_0742   MEN3_EU_SK370_P1185L_1760 ME
  • It's on the page you posted, "Service Update button" and a USB stick. I will send you some instruction and links. They have an emergency menu for recovery.. so you would have to have a defe
  • StripleRider03
    StripleRider03
    I just updated to 1800, I have a Skoda Slavia in India with the Bolero system. I can confirm that the issue with S23 Ultra is finally resolved! Attaching images.
2 hours ago, Eyalbis said:
Hey dear varoom,
Sure, these two are available for you to try and use, will send by Private Message
MEN3_EU_SK370_P2345L_1790
MEN3_EU_SK370_P3225L_1798
i can't reply to your message... the link in pvt don't work!
sorry and thx
Wireless connectivity does't work in this firmware version. Is there any version that will enable WIFI?
i' m on MEN3_EU_SK370_P9494P when i to upgrade the software download from usb stay in gray can anyone help me?
Make a folder called MEN3_EU_SK370_P9494P and copy the file folders into that folder, worked for me
On 11/06/2023 at 12:13, varooom said:
You can in stages update to 1798 eventually, these updates are sent by Private Message if you want it.
Hello, you please help me with this? my car is 2023 fabia. Is this update compatible?
Can somebody check the VC software version for me? In the update menu you see something like KI_654xxx or a different number.
Hello, I'm new here. Can I ask for file with newer software? Another question is if there is more than one newer version, is it necessary to install them in steps from oldest to newest or just the newest?
Thank You in advance!
So guys, those of you who made it, did you have issues with car not reading USB stick? I have a USB type-c stick, I plug it in the normal USB type-c plugs, but when in the menu and in the service update, stick is not offered as an option to select it.
My car wouldnt recognize the usb stick, fixed it by making a folder named the same as the update, and copied the firmware folders into that folder
Yeah, I tried that as well, but still did not work. I suppose I could try again.
Hello, I have version 0463 from what I have read to you I need the MEN3_EU_SK370_P0113P. Am I correct? Could you pass it to me? Thanks!
Hello,
The current version train for my Scala 2022 is attached. Is there a newer version and what should I do to install it?
Thank you in advance.
Best regards,
Excuse the the finger print marks ! :)
Please can somebody share the latest update for a 2020 Scala. I believe it's MOI3_EU_SKMQB_P30603P. Thank you!
Hello. Can anybody pass me a file with newer software?
Thanks in advance!
Any updates for my scala 2019? Android auto is still not working...
Scroll down a bit
Hi. Did You tried with USB disk formatted in FAT32 file system? I checked that my radio does not recognize NTFS and exFAT but FAT32 is visible.
I actually wanted to try that as well, but w10 does not have fat32 natively so I did not.
Since the car is still under warranty I have a scheduled service to update it in the garage so we will see after that.
Just use a smaller usb. Till 32gb you can format Fat32 native
All updated to P32400P, still will not let me change the lock settings.. I am preferring MIB2 at this rate!
Set adaptation channels in 5F
