Brake System Maintenance Question
On 21/05/2023 at 02:04, nta16 said:
I saw my mate and my old 1973 (year) Midget yesterday, he has it looking and going better than I did, I notice when the bonnet was lifted that he had put DoT 5 silicone fluid in the brakes and clutch systems.  He said he did not clean the brake system (clutch system was apart and new piping) he just did the usual (Gunson) Eezibleed with the new silicone fluid pushing out and replacing the old DoT 4.  No problems with brakes or clutch.  Still no problems from putting DoT 5 silicone in his 1970 (year) "classic" 25+ years ago.
Both cars use similar brake parts as the Foreman.
Thank you for letting us know about this first hand experience. :thumbup:
  • Replies 100
  • Views 12.4k
  • D.FYLAKTOS
    D.FYLAKTOS
    If your local "Brake guy" can make you a custom set Braided Brake Hoses (PTFE inner with a stainless steel outerbraid) then in mountain routes you will not have a "sponge feel" after some tough brakin
  • Not without the invaluable help I get from here.   You warned me about lower grade bolts and I found one 8.8 used in one of the caliper pins. I don't know if you can see it from the pic
  • D.FYLAKTOS
    D.FYLAKTOS
    The Racing and the DOT 5.1 brake fluids in a ''normal'' car must be replaced every 2 years, the DOT 4 can last 3 years. ''hygroscopic'' is the key word.
