Disabling coasting function in facelift DSG cars
Hello Lads,
Many members are struggling with their DSG going in Neutral when they release the gas pedal and engage the “coasting function”.
Especially with the facelifted cars with no drive mode selection option.
You can disable the coasting function with VCDS, OBD11, VCP, ODIS E following those steps:
Front hood open/popped, Module 19 - Gateway>Long Coding>FPA Funktion Freilauf DefaultON>Not Active
Thats all. Enjoy your normal transmission behaviour. 😉
made same coding today,
there were suggested also second part, left it for later
source -> https://forum.obdeleven.com/post/80599/thread
Quote
1.
Gateway module 19 - Long coding - FPA function freilauf defaultON change value to "not active"
2.
Adaptive Cruise Control module 13 - Long coding - Sailing_function change value to "no_predictive_sailing"
Hello guys,
I am tje testbrabbit, that @kickdown used for the "tuning" 😁
Now time for the feedback, 500+ km after the intervention, I am happy to say that the DSG is working like a charm! I tend to use motor braking quite a lot, and this coasting eco option was the most annoying thing while driving.
The car is Skoda Superb '22, 2.0 TSI 190 hp, and now I am happy with the result.
Definitely doing this... it's incredibly annoying.  Glad I visited Briskoda today
You can still go into coasting by putting the DSG into N.
@26DIPP  You can go into 'Neutral' by putting the DSG into N.
 It might well coast in N but it will not be in 'Coasting' ready to be in gear when you touch the accelerator or brake pedal.
I would advise steering clear of shifting the dsg stick while moving. Just not a good idea as you might accidentally money shift into reverse or P. Pulling back for S there is almost zero chance of messing that up. Pushing forward? Hit a bump and break something.
I thought, the DSG does not have a direct mechanical link between stick and clutches and it is all actuator controlled, so you should not be able to shift into R for "Rally" when going forward as you would have been able in a manual and grind the cogs.
If I go into manual mode on the DSG it will also not allow up or down shifting if I am not in the rev range for the specific gear.
Yes I suspect there is coding, or maybe even a hard stop, preventing it but it still sounds like a recipe for something going wrong.
  • 8 months later...
Hi all, my wife owns a Skoda Fabia but I have a 2019 Golf with a DSG gearbox and it has the awful coasting facility which you can only cancel by driving in sport mode.
My question is would the VCDS coding for the Skoda work on my Golf?
thanks
Pa
It surely would.
17 minutes ago, komoornik said:
It surely would.
Great as don’t want to muck things up
It world be nice if the DSG used the front assist ACC sensor & inclination sensor to decide when to coast.
E.g.not engaging coasting when the car in front is slowing down or when you are on a downward slope.
I am used to a manual & use heavily the engine braking & anticipation to manage the speed.
New to a DSG and the most annoying part is gear shifting or coasting which causes the speed of the car to increase.
I can't understand why they design the system this way.
For me it's more logical if I remove my foot from the accelerator that I want to slow down or at least maintain the current speed.
With the combination of sensors and road mapping it should be simple to do this but instead it will engage coasting or shift to the next gear making me accelerate towards the car in front...
I am constantly flicking the flappy paddle to make it reengage the gear.
I think I'll invest in a OBD11 just to change this setting.
I’ve invested in the VCDS kit as I own a Golf and the wife has a Skoda so i can use it on both cars and Audi too.
Sorry to dig this one up, but i'm interested in turning this coast function off in eco drive mode as it's fine apart from that.
The OP mentions 'long coding' is that an option available to the stock version of obdeleven or is it a paid tier?
  • 5 months later...
has anyone had any success applying this on a 2025 year of car?
I love the car but i find it very annoying how the engine turns off when i disengage the throttle.
Edited by ffvrs
2025 as in a MK4 Superb?
oh, actually no its for an Octavia - but was hoping it might be a similar principle.
@nicknorman changed this in his 24MY Superb MK3...
I think there's another thread here in the superb section with his information/coding.
its OK, I've put a post in the Octavia section anyway. No doubt it'll be a topic that will crop up now and again.
I had a look at the Octavia forum & was surprised for the MK4 there's not a pinned thread for "tried and tested adaptations" to use with vcds/obd11.
Perhaps the newer cars have some kind of protection making it more difficult to change the configurations/coding
Yep you're bang on there - all of the modules in my car are protected by SFD of sorts with diagnostic filters. I'm seeing the abbreviations "-R SFD+SFD2" all over the place. Gone were the days of tinkering for the home mechanic!
can't say about Octavias, but Mk4 Superbs can't be coded anymore
nowadays development hardly works to disable all open doors ☹️
another sad news -> erWin closing to private customers
Yeah man, cars are just turning into big iPhones now. Once they go full electric, its end of days.
Obd11 was advertising on it's website that it can support SFD codes automatically by connecting to VAG Servers.
Not sure if this would expand to new features but you can understand why manufacturers would prefer to secure these features so that they can lock them behind a subscription paywall in the future.
