Unleashing the Power of OBDeleven: A Must-Have for SKODA Owners
I'm not sure how any of that information responds to the question of which piece of hardware to buy - MX+, vs. OBDeleven gen3, vs. something else?
thank you,
26 minutes ago, Trickiejohn said:
My info, whist not disagreeing with yous has more info:
  1. Carista OBD2: Carista is fully compatible with the OBDLink MX+ hardware. It offers basic code clearing and simple, menu-driven customizations ("customizations" or adaptations). Note: Because your Superb is a late 2025 model, Carista's beta testers network is actively updating compatibility for Mk4 platform elements. [1, 2]
  2. The "Gold Standard" Alternative – OBDeleven 3: If your main goal is advanced custom coding, the OBDLink MX+ will face limitations on a 2025 Skoda due to VW's factory SFD2 firewall restrictions. The OBDeleven NextGen device is an officially licensed Volkswagen Group partner that has built-in tokens to automatically unlock SFD protections, making it the preferred tool for modifications and "One-Click Apps" on a June 2025 vehicle.
It is AI generated, however it not been asked to make a decision other than show me the best options available today
  • Replies 53
  • Views 19.7k
  • It is worth noting that many VAG owners have reported that the:   "One-Click Apps – pre-made car coding applications designed to simplify your customization journey"   can and wil
  • Staffshome
    Staffshome
    don't waste your money buy the trusted & established alternative product. obdeleven vag Ultimate are charging money for either Alpha testers or a Lithuanian data harvester. 1st time I have pa
  • Beware of using those, you don't know what changes they are making and because Skoda make many running changes you cannot be sure they will do what you want on your car - there have been many posts on
OK,
I would never tell you what to spend your hard earned on.
The info I added would I’d have thought might have pointed to the ODB11 3.
However, you didn’t see that 👍
John, everything in that (AI generated?) advice seems to focus on newer cars and the need to work with/around newer cars' enhanced security systems. My vehicle was manufactured in April 2020, based on the 2017-2020 Octavia III Facelift platform, so nothing about these newest generation, more secure car computers applies.
My question remains whether OBDeleven's custom-hardware-restricting-to-custom software (at a slightly reduced price compared to one of the major device-independent software author's suggestion of MX+ as gold-standard compatible hardware) has a driving advantage, or whether compatible (vs. OBDeleven's custom) hardware is a better choice (especially if someone has a specific product recommendation as being as capable, reliable, and at least nearly as fast as, while being less expensive than, the MX+)?
thank you,
2 hours ago, Trickiejohn said:
OK,
Jay,
To be honest, I can’t recommend one from the other. You’re correct in that it’s an AI (I asked to different models and both said the same thing in a slightly different manner).
I have in the past had uses of VCDS, that did the very limited stuff easily (wind back to pads for brake pad changes and code for a new battery, day light changes) but that’s just the simple stuff.
It might be that ODB 3 is more than you need. I can’t advise either way to be honest.
