Unleashing the Power of OBDeleven: A Must-Have for SKODA Owners
The Future is now...
  • Replies 53
  • Views 18.9k
  • It is worth noting that many VAG owners have reported that the:   "One-Click Apps – pre-made car coding applications designed to simplify your customization journey"   can and wil
  • Staffshome
    Staffshome
    don't waste your money buy the trusted & established alternative product. obdeleven vag Ultimate are charging money for either Alpha testers or a Lithuanian data harvester. 1st time I have pa
  • Beware of using those, you don't know what changes they are making and because Skoda make many running changes you cannot be sure they will do what you want on your car - there have been many posts on
It's certainly not 'the future' as it can't do anything with SFD2
That is Not correct
Took me a few looks to work out that was a white presentation box, so what is in the box that is the future now?
the saying was meant rather sarcastically
36 minutes ago, Cairus said:
That is Not correct
You may want to do some research….
Volkswagen Group (VAG) vehicles
New Volkswagen Group (VAG) models from 2024 have updated security features (UNECE R155 and R156) to protect the car’s software. This new layer of protection, sometimes called “SFD2,” safeguards the car’s control units from unauthorized access, particularly for updates performed over the air (OTA).
Under these new security measures, OBDeleven can only fully communicate with the car's main diagnostic part – the gateway control unit. This means we can’t fully scan or interact with other control units as we do with other car models.
https://support.obdeleven.com/en/articles/9187989-does-obdeleven-work-with-vag-and-bmw-vehicles-manufactured-from-2024
Thank you, I'm familiar with the subject... you should therefore know that even with the SFD 2 contract with VW, which is currently being negotiated, it would never be possible to process SFD 2 with gen 2. The hardware basis for SFD 2 was implemented with gen 3.
4 minutes ago, Gizmo said:
Vielleicht möchten Sie ein wenig recherchieren …
Fahrzeuge des Volkswagen Konzerns (VAG)
Neue Modelle des Volkswagen Konzerns (VAG) ab 2024 verfügen über aktualisierte Sicherheitsfunktionen (UNECE R155 und R156) zum Schutz der Fahrzeugsoftware. Diese neue Schutzebene, manchmal auch „SFD2“ genannt, schützt die Steuergeräte des Fahrzeugs vor unbefugtem Zugriff, insbesondere bei Over-the-Air-Updates (OTA).
Aufgrund dieser neuen Sicherheitsmaßnahmen kann OBDeleven nur mit dem Hauptdiagnoseteil des Fahrzeugs – der Gateway-Steuereinheit – vollständig kommunizieren. Das bedeutet, dass wir andere Steuergeräte nicht vollständig scannen oder mit ihnen interagieren können, wie dies bei anderen Fahrzeugmodellen der Fall ist.
https://support.obdeleven.com/en/articles/9187989-funktioniert-obdeleven-mit-vag-und-bmw-fahrzeugen-ab-2024
A complete scan with full SFD 2 protection is possible with gen 2, I have done it myself with a Skoda Karoq 2025
Can you code with it?
No.
Once this can be done by unlocking SFD2 then yes it’s progress, until then it’s a step backwards for anyone with a newish car.
3 minutes ago, Cairus said:
Danke, ich kenne mich mit der Thematik aus... Sie sollten daher wissen, dass selbst mit dem derzeit in Verhandlung befindlichen SFD 2 Vertrag mit VW eine Verarbeitung von SFD 2 mit Gen 2 nie möglich wäre. Die Hardwarebasis für SFD 2 wurde mit Gen 3 implementiert.
Look
history (4).txt
history (3).txt
Edited by Cairus
Any for sale?
  • 3 months later...
New to the forum.
However, I spent some time last week trying to find a solution for SFD2.
Currently , I can’t find one………Anywhere.
VCDS, who I think are the better option fully admit and give more detail than their competitors on the subject.
It’s still not simple for authorised dealers to make changes and has a cost to them my informant says.
I haven’t fact checked the last bit to be honest
  • 5 months later...
Will a car registered in late 2023 be affected by SFD2?
What coder would ppl seriously recommend without being bias?
Probably yes as it’s mainly MY24 onwards cars affected.
I own OBDII, VCDS (HEX-NET) and also had VCP.
For me VCDS was / is always my ‘go to’ device.
Which Car?
Skoda released the SFD 2 protection at most two months before the EU deadline. I've had plenty of MY24 vehicles without SFD 2. I can tell you exactly if you send me the VIN via PM.
The Kodiaq 2 and Superb 4 were exceptions.
Regarding a diagnostic tool, what features do you want to be able to use? For data set and firmware flashing, I definitely recommend VC Tool. For everything else, Car Scanner Pro is sufficient. OBD 11 costs a monthly/annual subscription. VCDS is too expensive without VIN restrictions. VCP costs an annual subscription if you want the latest version. VC Tool also costs money, monthly/annually, but offers the most features. It requires a VAS 6154a dongle.
Edited by Cairus
No SFD 2 / UNEC Car
Edited by Cairus
45 minutes ago, D.FYLAKTOS said:
I have it, didn't helped me (one error code i have erased via this and nothing more)
https://www.briskoda.net/forums/topic/524233-obd-reader/page/2/#findComment-5876506
Which vehicle did you use to read the data? Felicia? Back then, there was another list showing which channel was which; even the workshop with the factory tester didn't see that. OBD11 can't be blamed for that.
In their site the Felicia was in their list, that's why i bought it.
As you can see in the 3 photos (in the link) shows some Live data with no explanation.
Yes to Support it...
You need the document that describes the channels. This list might help:
https://www.t4-wiki.de/wiki/Messwertblock
Edited by Cairus
  • 3 months later...
Reviving an older topic; I own an older generation OBDeleven device, which does not have useful Live Data recording/graphing. I asked OBDeleven about that, and they said, yes, my older device can't do that; I'd need to buy one of their newer devices.
But, do you all recommend that I just go with a newer OBDeleven device? (I've always found OBDeleven's Android app and data exchange with my 2020 April-manufactured 2019 model year Octavia III Facelift to be frustratingly slow). Or, go for something other than OBDeleven at all? Is VCDS still the best thing? I saw some discussion of a VLinker brand, but their products are confusing - they don't explain how to choose among them.
thanks for your suggestions,
-Jay
Allegedly there are only 2 brands authorised by VW group for newer vehicles.
There are
VCDS
OBD11 3
As it’s only their new devices that can change more than the basic settings on cars 2 years old and newer (generalisation here of course )
If your car is new is with the latest software version, you’ll need to cough up the bucks.
I’ have been looking at these off and on for 19 months (before I bought the Superb). Still haven’t made the decision (I’m not likely to be fit enough to do stuff myself for a few months yet tbo)
Just to add to this, albeit my knowledge is minimal, I've used Car Scanner and Carista quite happily to change settings using a basic ELMe27 dongle on my 2018 Kodiaq but it won't do the same on a 2017 Citigo. Which seems strange but there you go.
Since my car is the 2017-2020 design era, fortunately for my current interests I don't have to worry about the most recent models' enhanced security that breaks much of the capability of OBD-II consumer-grade stuff.
The VCDS price is at least $199 (for USB-wired, apparently to-Windows-only?) or over $400 (for wireless, which really shouldn't be so much more expensive) more than OBDeleven's v3 device (€85). Does the VCDS software provide capability so much greater than the OBDeleven mobile/Android app to justify this cost difference? .. particularly considering that my specific use case is to record and graph live data over the course of maybe as much as a few tens of minutes?
Or, because as I understand it, OBDeleven stuff is all custom (you have to use their software with their devices), is the functionality of e.g. an OBDLink MX+ (€139) at least as good as OBDeleven's (and, it has the flexibility to work with other software), so would that be a better/more-than-adequate intermediate between OBDeleven and VCDS?
(I chose the OBDLink MX+ in my question above on the strength of the Carscanner app author's recommendations of that being the best option he's aware of).
thanks,
My info, whist not disagreeing with yous has more info:
  1. Carista OBD2: Carista is fully compatible with the OBDLink MX+ hardware. It offers basic code clearing and simple, menu-driven customizations ("customizations" or adaptations). Note: Because your Superb is a late 2025 model, Carista's beta testers network is actively updating compatibility for Mk4 platform elements. [1, 2]
  2. The "Gold Standard" Alternative – OBDeleven 3: If your main goal is advanced custom coding, the OBDLink MX+ will face limitations on a 2025 Skoda due to VW's factory SFD2 firewall restrictions. The OBDeleven NextGen device is an officially licensed Volkswagen Group partner that has built-in tokens to automatically unlock SFD protections, making it the preferred tool for modifications and "One-Click Apps" on a June 2025 vehicle.
It is AI generated, however it not been asked to make a decision other than show me the best options available today
