Message added by mac11irl,
Please do not post VIN or email addresses in your replies on this or similar threads. Doing so triggers the auto hide mechanism on the site and circumventing the rule may result in moderator action against your account
Data like this can be used for fraudulent activity across the internet and the real world.
Only send this type of information via the personal message section to trusted members only.
If you cannot yet send a pm as a new member, simply tag the person you wish to contact in a post and ask them to start a private conversation.
Thanks and safe browsing,
Briskoda Admin Team.
Kamiq MY20 MIB3 Update
Need file complet
MOI3_EU_SKMQB_P30800P_MU0308.7z
MOI3_EU_SKMQB_P33200P_MU0332.7z
(with folders data and meta and file metainfo2.txt included). Thanks
  • Replies 184
  • Views 82.7k
  • So a little update: EVERYTHING WORKS.   Let's start a "Journey Diary - Guide" so that everyone that wants to do it can follow the steps and update. First of all, the previously mega link pos
  • Dear @r0bb10 and @Lennart, I want to thank you for sharing your update stories !   Thanks to you I finally took the plunge and did the update tonight. I have a Kamiq MY21 that came
  • Yes with the help of @Lennart i found everything to bring the sw to the 0324 release, here is a mega link where you can get the archives of the old cumulative versions until 0308, you can download 032
Need file complet
Need file complet
link has expired can i get all the updates please. also do updates need to be done one by one or i can jump to last one?
Edited by WillAA
While this thread is active.....
My kamiq head unit is saying there's an update available I press update now and it doesn't seem to say the update has been successful, finished, started or failed. I then use the car again and randomly it says an update is available again. I'm beginning to think it hasn't even done any updates, and what will these updates be?
Been saying updates available now for the last few weeks but nothing seem to happen.
So I need firstly, do I have to have connect it to a WiFi point or will it work from my phone's data which is always connected to the car?
Secondly, how long should it take to update, I do shortish trips, sometimes longer than an hour but it's never really (I don't think updated) during any driving periods?
Thanks.
  • 2 months later...
On 17/02/2024 at 18:28, r0bb10 said:
PS: a proposito, la prova che ora sono alla versione 330 è :) che ho anche collegato l'auto al mio wifi in garage e ho eseguito un aggiornamento online delle mappe, ora ho il database 23.6 e non il 20.11 come dice la foto).
Hi Roberto, could you post the Mega archive again?
I’m in the same situation you were in at the start and I’d like to know how to do it.
Best regards from Milan
Let's start a "Journey Diary - Guide" so that everyone that wants to do it can follow the steps and update. First of all, the previously mega link posted above (here) contains all the files needed. I did everything myself with the help of @Lennart, not diffucult at all, but the responsability is yours alone.
Updating from the ancient 0156 is not that difficult, it's just like any other update for the MIB3, but it breaks Navigation System. This is intentional and it's because Skoda changed the license and offers Navigation as a SWaP now. You can check in the Service Menu (long press menu button) that no 00071C00 FEC is installed and in the supported FECs it doesn't even show up as available to install.
According to the 2 TPI in the mega folder (one older in English, one recent 2024 in Italian) Navigation is now a SWaP, and since it already was included in the car package when bought you can reactivate it using the codes that Skoda provides to re-enable it.
Tool necessary to do the update is any OBDEleven or VCDS or any other tool that can do SVM (Software Version Management), but to re-enable Navigation ODIS-S is needed. ODIS-S is a dealer level software, so you have to rely on a dealer to apply the SWaP or to someone that has ODIS with a valid Geko Online account and the necessary hardware to connect to the car. Just go to the dealer after all the updates, you can bring the activation code or ask them to provide it, is in their ODIS Service Net and can be also obtained from Erwin Portal online.
In the first TPI it's stated that the OCU (Online Connectivity Unit) has to be flashed first. Before doing that use any of the tool to go to the 0075 module (the OCU indeed) and in adaptation you need to change the Crash Signal to "via CAN". Once applied format an usb stick to fat32 or exfat and unpack the version 143 of the OCU update named 5WA035284OCU143.zip in that stick. Insert the usb stick in one of the usb-c port and long press the Menu button for 3-5 sec, reboot in Engineering mode to start the update following the TPI instruction.
Once applied it will reboot and the infotainment will be working as usual. Using OBDEleven or VCDS or ODIS-S you will see that you have a fault error B201A, it's normal when doing an update via usb without dealership computer, it can be easily fixed by updating SVM using a xor tool that can be found here. It's nothing critical, you just have to tell the MIB3 that the software is new.
Now you can proceed to do the actual MIB3 Update: format the usb stick unpack the first sequential package MOI3_EU_SKMQB_R23802P + P26810P + P27800P.7z in the root folder, go in the Service Menu and then press Update. The software will auto check the usb drive and since everythin is signed by Skoda it only applies if the file is the correct. It is almost an 1h job and it will reboot multiple times (5-6 at least), since it's not incremental everytime it has to delete the previous and reflash.
After this you will land on SW version 278, MIB3 will work fine except that Navigation wont start. If you go in the Service Menu you will see that the Predictive Navigation FEC 00071C00 is not installed but it will be present in the available tab that was not present before. You can do a SVM fix again.
Re-do everything, format the usb stick and unpack MOI3_EU_SKMQB_P30600P_0306.zip, apply again in the Service Menu and wait for it, will probably need 20-25 min. On reboot, do the same with version MOI3_EU_SKMQB_P30800P_0308.zip than you can find here a then again with MOI3_EU_SKMQB_P33000P_0330.zip that will bring you to the latest 0330 version that was released i think Jannuary 2024. Remember that after each upgrade you have to confirm the installation change.
Once done you can finally check if everything is working except of the Navigation System.
To fix this you have to enable FEC 00071C00, and as said it can be only done by adding your specific activation license code and unlock pin (that work only in your car and vin) and only using ODIS-S Online, so if you go to a dealership to activate it he surely can and already has your data to do so, else just bring the code with you and let them restore it. It can be found in the excel sheet in the mega folder, just search for your vin and you will find it.
If you have the necessary tool to use ODIS-S yourself (like i did), connect to your car and perform a FFS (Function Activation), proceed with option 1, enter the 3 values when asked and apply them, it will ask you to login online using Geko (DSS Login) and let ODIS-S check with the servers if the codes entered are valid, after a 20sec wait or so it will be verified and unlocked. Now Navigation will start again! You can check in the Activated FEC and you will see that 00071C00 is enabled and valid.
This is not a hack, it's not some sort of dark magic, is just exactly what the dealer does when they perform an update. Since they often wont do it (if aint broke dont fix it) or refuse because "risky" now you know that you can do it by yourself, files are publicly available if one know where to look and how to find them. And since the latest update is not cumulative you cannot apply the latest to a very old version they would charge you a lot of hours to do it.. well actually it is cumulative but it wont apply because security check will not pass so be patience and follow the TPI.
Enjoy.
R.
Is the VCRN code displayed correct? Am I in the correct module?
Hi everyone. If I update via USB—going from version 304 to 308 and then 330—will everything still work in the MySkoda app? Things like remote unlocking, vehicle location, and alarm notifications? Will I be able to log into my account and set myself as the primary user? And here’s a crucial point: what happens if I don't clear the SVM version compatibility error after the update (since I don't have the cable)? Google AI told me that remote functions wouldn't work due to a software version mismatch. What have your experiences been with the online account after a manual update? I have active Infotainment Online and Care Connect subscriptions, but I'm stuck with old software and an endless OTA update loop for three apps that’s been going on since June. Skoda wants to charge me for an update, even though they broke the system in the first place—which really infuriated me...
I’ve received an OTA update to version MOI3_EU_SKMQB_P33400P. I haven’t noticed any new features.
The new version has stopped the daily updates for other apps.
However, I still don’t have a wireless connection option for Android Auto.
Myskoda app also works.
I own 2023 Kamiq with Amundsen infotainment.
Edited by Vladej
9 hours ago, Vladej said:
Otrzymałem aktualizację OTA do wersji MOI3_EU_SKMQB_P33400P. Nie zauważyłem żadnych nowych funkcji.
Nowa wersja zatrzymała codzienne aktualizacje innych aplikacji.
Jednak nadal nie mam opcji połączenia bezprzewodowego z Android Auto.
Aplikacja Myskoda też działa.
Posiadam Kamiq 2023 z systemem multimedialnym Amundsen.
I’m specifically asking about people who performed the update manually via a flash drive—without using a cable to clear a hidden error—to see if everything works for them in MySkoda and if they were able to add the primary user without any issues.
