1.5 Tsi Power Cutting Out
The 1.5 TSI is a Miller cycle engine rather than the traditional Otto cycle. It relies on precise engineering tolerances. This problem doesn’t seem to affect all manual 1.5 TSI Karoqs nor does it seem to affect DSG versions. It also seems to affect vehicles that are brand new so that would rule out lack of maintenance. What do people think about this : that small number of engines might have critical components and sensors which individually are within tolerance but the collectively the tolerances are not really matched. Statistically this is a possibility. Thus leading to the engine software being unable to manage the engine in certain specific instances. The engine management software and DSG control software obviously communicate with each other and possibly pre-empt the stall or cutting out and change down or disengage the clutch. Just a thought.
  • Replies 228
  • Views 48.5k
  • Absolute rubbish, a driver should not have to adapt his style to overcome what are basic deficiences in the design of the engine. I have owned over 40 cars through 60 years and have never experienced
  • chieflordy
    chieflordy
    Almost all of us reporting this problem seem to have a mid to late 2023 or 2024 1.5TSI manual Karoq, so this will be the evo2 engine, ie new version without the engine cover. So I think Bigjohn may be
  • Although I have had my Karoq for 9 months, I have only had this engine cutting out problem on three occasions. The first two happened while I was talking to others in the car and the engine cut out as
Not been on Briskoda for a while but adding to the thread…
Ours is a 23 1.5 tsi manual Karok and the engine occasionally does this.
Happens at low speed and normally out of gear (slowing to a stop). Dangerous when that stop is at the give way line on a roundabout and the car is till moving when you put it into gear to pull away but the engine has stopped.
It is not stalling - if I stall it the stop-start restarts the engine. When the fault occurs it does not.
Welcome to the club that we would all rather not be members of.
Skoda asked me to try E5 and if anything it was worse on E5!
Mine generally stops when it is out of gear (first instances were slow approach to a junction where you are guessing which gear to be in so you can slot into a gap, but the engine stops without warning leaving you stranded) so there is no load on the engine at all. If I stall it the SS takes over and restarts the engine!
