1.5 Tsi Power Cutting Out
The 1.5 TSI is a Miller cycle engine rather than the traditional Otto cycle. It relies on precise engineering tolerances. This problem doesn’t seem to affect all manual 1.5 TSI Karoqs nor does it seem to affect DSG versions. It also seems to affect vehicles that are brand new so that would rule out lack of maintenance. What do people think about this : that small number of engines might have critical components and sensors which individually are within tolerance but the collectively the tolerances are not really matched. Statistically this is a possibility. Thus leading to the engine software being unable to manage the engine in certain specific instances. The engine management software and DSG control software obviously communicate with each other and possibly pre-empt the stall or cutting out and change down or disengage the clutch. Just a thought.
  • Replies 240
  • Views 53.4k
  • Absolute rubbish, a driver should not have to adapt his style to overcome what are basic deficiences in the design of the engine. I have owned over 40 cars through 60 years and have never experienced
  • chieflordy
    chieflordy
    Almost all of us reporting this problem seem to have a mid to late 2023 or 2024 1.5TSI manual Karoq, so this will be the evo2 engine, ie new version without the engine cover. So I think Bigjohn may be
  • Although I have had my Karoq for 9 months, I have only had this engine cutting out problem on three occasions. The first two happened while I was talking to others in the car and the engine cut out as
Not been on Briskoda for a while but adding to the thread…
Ours is a 23 1.5 tsi manual Karok and the engine occasionally does this.
Happens at low speed and normally out of gear (slowing to a stop). Dangerous when that stop is at the give way line on a roundabout and the car is till moving when you put it into gear to pull away but the engine has stopped.
It is not stalling - if I stall it the stop-start restarts the engine. When the fault occurs it does not.
Welcome to the club that we would all rather not be members of.
Skoda asked me to try E5 and if anything it was worse on E5!
Mine generally stops when it is out of gear (first instances were slow approach to a junction where you are guessing which gear to be in so you can slot into a gap, but the engine stops without warning leaving you stranded) so there is no load on the engine at all. If I stall it the SS takes over and restarts the engine!
@IJWS15 did Skoda ask you to try E5 or was it a technician at a Skoda franchise dealership in the UK?
Hi -I have sold my Karoq partly because of this issue - but IJWS15 did you notice the revs drop to around 500rpm before putting your foot on the accelerator? I eventually was able to forecast an engine cut out due to the revs dropping without any load on the engine
The Service Agent asked me to try E5.
The car is going soon and we will not be getting another Škoda or VAG car so their handling of this issue, and others, has cost them a customer.
T think that it is only the 130PS version of the 1.5TSI that is a Miller cycle engine.
Reported to the dealer that it was still stopping on E5 and their reaction is that 350 miles is not enough time/ distance for the engine to relearn and it would need 3-3500 miles. If it relearns and the result of that is the behaviour goes away then what happens when I switch back to E10…… does it relearn again and the behaviour reappears?
The price difference is too much to continue to use E5 and the car should run on E10 (as stated in the filler cap) the latest communication reinforces the view that we get rid and move away from Skoda/VAG altogether.
Daughter has a manual A3 with an earlier version (68 reg) and it has never done it.
  • Sponsor
Tell them that knock sensors and the ECU hardware and software that interacts with them react in fractions of a second, so their argument is utter tosh.
Edited by Breezy_Pete
I shouldn’t need to tell them how the car works, just what it is doing. After 2 1/2 years I have given up, next car will be from a different company.
Edited by IJWS15
  • 4 weeks later...
Hi i have the same problem on my skoda octavia 2025 tsi manual i always turn off start stop ,sometimes at traffic lights or say going slow to a speed hump the engine cuts out the skoda dealer says no fault code and pass it off and say they cant find anything.
Welcome to the club )
Our 1.5 TSI never cut out, bought new in 2018 and sold earlier this year after 8 years of trouble free motoring. Now replaced with another one, DSG this time.
You told us this several months ago, neither of your cars is a EVO2 in manual, so you wouldn’t be affected.
