Three G11 coolant mixtures, boiling-cooling time comparison.
5 hours ago, Blue8793841 said:
 There is also warnings on coolant concentration which @D.FYLAKTOS may be interested in.
These?
Mixture - water/coolant concentrate!
Observe concentration ratios according to repair manual and climatic conditions.
• The frost resistance of the coolant must be guaranteed down to -25°C,
• in countries with arctic climate conditions -35°C
  • Replies 125
  • Views 12.6k
  • Breezy_Pete
    Breezy_Pete
    Pure water will have the highest heat capacity,  so will boil slowest for a given heat input.
  • Water has heat capacity 4.186J/gK, ethylene glycol, used in antifreeze, 2.42J/gK. No need to experiment, you can do the math. Just make proper mixture for your weather conditions. There's really
  • G12 should have better corrosion protection, which is crucial on these engines. But you have to flush the engine properly, as G11 and G12 don't mix well. G12+ supposedly mixes better with G11, but I w
