Headlights , fog lights problem after VCDS changes - need restart some channels.
Hello,
Its my first post, but i am Superb III user since 2020. Yesterday i find vide on YT how unlock some hiden fetures using VCDS. YT LINK
After this, i have problem with front lights. First problem is, fog lights not working now, no indicator lamp on dash. Looks like off somewhere. Also Come and Leave lights not working now, when i lock or unlock doors its only indicator light flashing, but headlight not works. Also when engine is off and Light switch is on Auto possition all light is off, before even engine off, Led strip was on . Final question is, its any option reset all adaptation chcnges make by myself in module 09 , without any damage ?
Thank You for any help
i take it you didn't make a backup before u went made all those changes?!?!
also, for the DRL stripes to work, u need version B bi-xenon headlights, not version A.   u can tell by the part number on top of each headlight.
Check the coding.log to see what changes you made and change them back...
Thanks for answer. No i do not backup... Yes its my fault. I check my Laps and i see now its version A... I think, i do some mistake, probably i inactivate fog lights, and activate circuits 16 and 17. BTW i try find list of light circuits but cant find. Maybe some one know where i can find it ? I will check coding.log tomorrow i try find what i do wrong... Thanks for help. Coding its very cool but i know i need to learn much more before do some changes.
First and most important question, is VCDS legit or a clone?
Legit VCDS keeps a log of changes in C:\Ross-Tech\VCDS\Debug
Edited by petrolcan
On 27/03/2024 at 22:03, DaveMore111 said:
Hello,
Welcome and yes it does sound a bit of a situation.
Luckily you’re in the best place for info and answers. Check the logs as suggested and unpick what you did.
Alternatively does the video tell you what values to change from? Maybe go through it again reverting all values back to what they were.
And finally luckily there is a pinned post at the top of this section with all the tried and tested VCDS changes you can make 👍
Another alternative may be to open one of your old VCDS scans.
Normally, you can find long coding which is stored in each Control Unit.
Unfortunately, if you used "adaptation" function it's not visible in scans.
