MiB 3 from 0270 to 0330
No, till next weekend at least.
  • Replies 72
  • Views 29k
  • Update 332 is in mibsolution.one https://mibsolution.one/#/1/9/MOI3/Preh/EU/Skoda
  • I’ve just done it - seems to work fine. Download the whole folder, extract to the root of your usb stick and you’ll see the data and meta folders extracted. Ditch the other zips after that so there is
  • https://mibsolution.one/#/1/9/MOI3/Preh
On 05/02/2025 at 22:42, MustafaYuqsel said:
So where can I find the RW software?
Found this folder for RW v330 if that helps - for EU it needed v308 and I can't see that anywhere. So I would download 330 anyway. Try and install it and if it isn't supported it will tell you straight away.
https://mibsolution.one/#/1/9/MOI3/Preh/RW/Skoda
20 hours ago, mvidapet said:
Hi @vegarz, did you already updated your device, does it work flawlessly?
I’ve just done it - seems to work fine. Download the whole folder, extract to the root of your usb stick and you’ll see the data and meta folders extracted. Ditch the other zips after that so there is just the Data and Meta folder and that’s all you need.
Took a tiny bit longer to do than 306 to 308 or 308 to 330 but not much 👍🏼
Hi travs. Did you notice any differences between 330 and 332??
Edited by vasifumi
None yet - as in nothing bad.
It connects to CarPlay, then drops it after about 5 minutes, then reconnects. Just happens once every journey. It started doing it before the update (presuming it was an iPhone update) and I was hoping it would have been solved by 332 but nope.
No news
Edited by vegarz
  • 4 months later...
On 06.02.2025 at 01:42, MustafaYuqsel said:
Peki RW yazılımını nerede bulabilirim?
mustafa hocam sizin süperb de güncelleme sonrası android auto tam ekran oluyor mu. üstte siyah bir boşluk kalmaya devam ediyor mu
Dostum ben android auto hic kullanmadım önceden nasıldı suan nasıl bilgim yok.
English would be good
anladım. navigasyonu nasıl aktif ettiniz peki. vcds ile kodlama yeterli oluyor mu? araçta gps anteni mevcutta geliyor mu? bilginiz var mı. benimki 2021 model superb comfort plus. ben de şimdi 0270 den 0308 e yükselttim görünüşte bir farklılık yok biraz daha hızlı tepki veriyor sanki akıcılığı daha iyi oldu
Edited by fatihkaragoz
Vcds ile yapacak bir işlem yok sadece arac vcrn koduna bakmak lazım gerisi cihaz güncellemeleri ve harita yamasının yüklenmesi.anten büyük bir ihtimal vardır.benimkide 2021 superb elite.cihaz kodu önemli destekleyen model mi kontrol etmen lazım.ben yaptım sıkıntısız çalışıyor
bu işlemler için ek bir cihaz gerekiyor mu hocam. yama yükleme işlemleri vs için. yoksa usb den oluyor mu? sizde gerekli dosyalar mevcut mu
Bilgisayarda olması lazım dosyalar ama navigasyon yaması için vcrn kodu nu bulup yama dosyasına kodların yazılması gerekiyor.vcrn kodu her aracın farklı ID numarasıdır.
@mustafayuqsel instadan yazın
yazdım hocam.
This is predominantly an English speaking Forum BRISKODA as in England so maybe rethink your post
Can you please use a translation tool before posting, as it will greatly increase the help you get? its also the language specified in the forum rules, again to maximise the help we can give each other. thanks!
In Turkish:
Lütfen mesaj yazmadan önce bir çeviri aracı kullanabilir misiniz, bu size daha fazla yardım sağlayacaktır. Ayrıca forum kurallarında belirtilen dil de aynı şekilde, birbirimize verebileceğimiz yardımı en üst düzeye çıkarmak için. Teşekkürler!
Hello Everyone,
Last month, I updated my Skoda Kamiq 2024 to software version 0330.
Since then, I’ve completely lost Wi-Fi and Hotspot functionality.
The Wi-Fi menu is still visible on the infotainment system, but whenever I try to activate it, it simply won’t turn on.
I’ve searched extensively online but haven’t found any working solution so far. The main reason I performed this update was to get the navigation working, but unfortunately, even the navigation is still not functioning.
System details:
  • Device reference: 3v0035832p
  • Equipment: H22
  • Software: 0330
  • Navigation Database: 24.6
Has anyone experienced this issue or found a way to fix it?
Any help would be greatly appreciated.
Thanks in advance!
Have you tried a second time in case something didn’t update properly?
If not, try it again.
Otherwise, it may be an OCU update required. It’s the unit that talks to phones and can affect navigation if it’s going all over the place.
For the WiFi - have a play in the settings menu ticking options. I found my car was connecting to the home WiFi and then losing any data as soon as I drove off
3 hours ago, Senlamar said:
Hello Everyone,
System details:
  • Equipment: H22
  • Software: 0330
Thanks in advance!
Also - look at updating maps if you want. There’s an updated version from 24.6 👍🏼
Hallo zusammen,
Letzten Monat habe ich meinen Skoda Kamiq 2024 auf die Softwareversion 0330 aktualisiert.
Seitdem habe ich die WLAN- und Hotspot-Funktionalität vollständig verloren.
Das WLAN-Menü ist im Infotainmentsystem noch sichtbar, aber jedes Mal, wenn ich versuche, es zu aktivieren, lässt es sich einfach nicht einschalten.
Ich habe im Internet intensiv gesucht, aber bisher keine funktionierende Lösung gefunden. Der Hauptgrund für dieses Update war, die Navigation wieder zum Laufen zu bringen, aber leider funktioniert selbst die Navigation immer noch nicht.
Systemdetails:
  • Gerätereferenz: 3v0035832p
  • Ausrüstung: H22
  • Software: 0330
  • Navigationsdatenbank: 24.6
Hat jemand dieses Problem erlebt oder eine Möglichkeit gefunden, es zu beheben?
Jede Hilfe wäre sehr willkommen.
Dank im Voraus!
. Check this...
Password send PM
https://mega.nz/#P!AgBjIVaAPhBAV0eYvlLxnOxxeE38a7UgAG6X3agCdgtWJa94QjnCNJYzFc-PTaldmEEy3IBj_PmAV7FqW5xtTm8JIwlNCdBZrajLv8biP7-kX1bnse-VOg
I actually tried that. First, I updated to version 324. After I got this problem, I retried the update to 324 again before finally installing 330, but unfortunately it didn’t solve the issue.
Regarding navigation, it has never worked since I bought the car – it always showed the message “Not available in your region.” However, after the update, when I try to open navigation it only says “Navigation starting” and stays like that forever.
On top of that, the WiFi and hotspot system stopped running after the update, even though it was working perfectly fine with the stock version the car came with.
Here is a video on youtube for the problem shortly: (1) Problem Hotspot ( Carplay Android Auto wireless wifi factory reset ) resolved - YouTube
38 minutes ago, Cairus said:
. Check this...
Password send PM
I didn't recieve any password can you send it to my email <email address removed>
Please use the internal message service to help protect your privacy.
Thanks, site admin.
In which case this feels to me like software isn’t the issue. If it’s basically happened with multiple tries of different software (and 324 was the first problem) then that variable has changed a few times with the same result.
Same with the Navigation. Doesn’t seem like it’s sitting right for whatever reason. I’d be inclined to go back to a Skoda Dealer, play dumb about the updates and just highlight the navigation and connectivity issues. See if they can update the OCU and if not change it.
Btw when I checked installed codes, 00071c000 is refused temporarily is mentioned as shared in the picture
13 minutes ago, Cairus said:
Is allowed To Share tpi?
TPI-2072245-5.pdf
Thank you very much Carius for sharing this document.
I don’t have access to ODIS, and unfortunately the service center here is not very experienced with these matters.
Could you please tell me if it is possible to perform the MIB3 + OCU update by myself?
Also, could you kindly share the password needed to access the update files, since I would like to try the procedure on my own?
Thank you in advance for your support.
On 25.08.2025 at 22:29, Senlamar said:
Bu dokümanı paylaştığın için çok teşekkür ederim Carius.
ODIS'e erişimim yok ve maalesef buradaki servis merkezi bu konularda çok deneyimli değil.
MIB3 + OCU güncellemesini kendi başıma gerçekleştirmem mümkün müdür acaba?
Ayrıca güncelleme dosyalarına erişmek için gereken şifreyi paylaşabilir misiniz, çünkü bu işlemi kendi başıma denemek istiyorum?
Desteğiniz için şimdiden teşekkür ederiz.
Which country are you writing from?
