barn find felicia pickup.
Nipped up all the lines, lobbed some fluid in the top and gave it a squeeze. Pedal feels ****ty so more is needed, but if you press the pedal you can't move the drums and if you let off the pedal you can so that's SOME kind of win.
  • Replies 278
  • Views 49.3k
  • Welded up the drilled out spots on the back side drilled out for plug welds First tacks Fire dept violence and alignment grumbly tin Making sure we didn't get it too wrong All other
  • It's been a three day marathon, I'm knackered. I got the starter back on, clutch inspection plate back on, clutch hooked up and the electrics hooked back up. Started it up, chucked it in gear and
  • poked it with the air shears till I realised I couldn't turn a corner with them (maybe this is user error) then did the rest with a worn down, thus smaller and more manoeuvrable angle grinder disk.
This has taken a LONG time to get out, the top of the strut being nicely rusted. but another round of heat, penetrant, and violence got the nut suddenly moving.
That gets us this rotten old bouncy thingy out
As soon as I get some more money I'm going to get new ones that aren't so rusty.
I THINK I'm going gas, not oil as this isn't primarily going to be a load carrying vehicle.
The important question is:
What's that rubber stuff up at the top called because although I can get shocks from loads of places I'm struggling to locate the top hat bush thingy and that should be refreshed too I feel.
Actually bad form but probably this?: https://www.ebay.co.uk/itm/404677052614
Of course I can't get the other side out, but if time got this one moving I expect the same magic can happen on the other side.
Edited by skoda_cat
adding ebay link
I know it's a bit of a postapalooza, sorry.
My neighbour came round, muttered under his breath, whacked the nuts with a cold chisel and a 5lb hammer and it all came undone with a temu rattle gun.
Now my axle is drooping in a sad way and my springs fell out. oops.
I'm staring forlornly at my bank balance wondering how I'm going to get some new shocks and top mount doobies before next month. lol. Projects, what a waste of money. I'm so happy :P
Actually whilst the axle is hanging, I can try and clean up some of the top and give it a squirt of hammerite. Sadly the rest of today is rain.
Got some hose retaining clip things:
so they shouldn't fall out.
Started some wire wheeling and pulled off that 'no jacking' label to find out what the original paint was like.
Some reasonable performance weight savings have occurred.
Wire wheeled it all back as best I could and gave it a bit of a wash and wipe down.
and started colouring it in.
Recently Browsing 1
