Skoda Fabia mk1 both electric windows completly stuck
Hello,
My Skoda Fabia Mk1 2006 has some window problems I'm having trouble diagnosing.
Both windows do absolutely nothing when the window buttons are pressed. I still think the buttons work, as the central lock buttons on the same board still work just fine. Also, it seems unlikely that both buttons would fail at the same time.
I've checked the fuses too, and they seem to be fine.
Now, I've read a few inquiries like this, and as I understand it, the motor in the passenger door won't respond if the driver's door motor is dead?
I might be misunderstanding something, but if this is the case, would a motor switch in the driver's door potentially fix the issue?
If anyone has any idea what it might be, it would be greatly appreciated.
Hi, welcome.
Diagnosing means checking rather than assuming.  There will be many posts and threads on this topic in the various forums that you could look at and/or ask in - or there's a member that specialises in this - or there will be videos on YouTube (generally HatBoyHarvey does good videos on Mk1 Fabia).
Breezy_Pete offers advice (and might even see your thread here) in the Fabia Mk1 forum and others and does repairs, see. - https://www.briskoda.net/forums/topic/497084-window-motor-repair-service/
'Skoda Fabia Mk1 (1999-2007)' forum. - https://www.briskoda.net/forums/forum/26-skoda-fabia-mk1-1999-2007/
HatBoyHarvey Mk1 vids. - https://www.youtube.com/playlist?list=PLlGs3AwP43wSEE9A3GDQ00netiE1eHyli
HTH.
