Suspension upgrade installed
Since last year i had replaced the following
H&R Front & Rear ARBs
Whiteline adjustable drop links front and rear
Superpro front lower arms
Bilstein B6 shocks front and rear
It has transformed the car so much feels lot nicer then before. So much more responsive then with stock set up.
Springs are still standard no plans to be lowering it...yet 🤓
I had tracking done after and everything aligned spot on. No uneven wear on tyres since then.
The Eibach pro kit works extremely well with those shocks. No rubbing even with 4up and the dog in the boot.
Sits lovely and rides better than standard springs.
Sounds good to me... What is drop on the eibach kit? I still want it to remain practical
red numbers in my table
It dropped a bit. Maybe 5-10mm. The adaptive dampers already let it sit lower as standard. I think the total drop from a standard factory setup without adaptive is about 20mm.
I’ve had no issues whatsoever. No more hitting bump stops over the slightest thing and has never been a problem when filled on journeys. It practically doesn’t dip at all when 4 up. No problems over speed bumps etc.
Edited by UndertheRadar
If u get the Pro-kit version, and u have DCC shocks - it will drop approx 20 to 25 mm.
Standard shocks will see it drop approx 35 to 40 mm.
Edited by JR RS
Is there anything that lowers it little less? Only looking for 15-20mm max
Mine is standard not DCC
Edited by MarioVrs
I'll look into it thank you mate appreciate it
then choose one in between
@MarioVrs What Superpro arms did you use? I've ordered and received some TRC1070s and now finding conflicting stories about whether they're right for the car or not. Do you still have them on?
Yeah that's them...they are mainly for golf. I had them on car for 2.5 years, no issues until now. Just last week i started finding things that failed prematurely because of these arms. They are inch shorter on each side compared to Superb ones. My whiteline droplinks -split, ball joints -split. Got genuine ones fitted today and tomorrow it's going for wheel alignment, next week new droplinks getting fitted (Whiteline) again. I believe you can get Audi TTS bottom arms which are aluminium but I'm done with d*cking around. You can fit them and they work but they will make everything else wear lit quicker. They will also reduce your track width by an inch on each side
Tis wat I've been saying for a while now - they're too short (width-wise) for the Superb.
The camber will b wrong.
Delphi TC4442 and TC4443 r a good option suitable for the mk3 Superb.
These Audi-spec alloy LCAs r the same width as the Passat/Superb arms, and a Passat owner in Europe recently installed them.
Based on the discussions on the golfmk7 forums, these r bigger than all of the alloy Golf Mk7 sized arms available on the market, which is why the Golf guys were looking at using these wider arms to increase wheel track and camber on their track/fast street cars.
I'll b changing my LCA to these once the time comes for Gandalf.
Cheers for this. Back go the TRC1070 items then.
You def called it @JR RS - In my (our) defence there isn’t an AI LLM or retailer who doesn’t list everything MQB as compatible.
Started going down a track-width rabbit hole. The TTS track is still thinner (by less) so the OE TTS alloy ones would still be wrong.
Only car I could think with a wide track was 8Y RS3. 4mm wider overall so 2mm per side is a fraction of a degree more negative camber. Might be what these Delphi items are for? As now, trying to find OE RS3 is impossible without stumbling across a million items which are apparently compatible with RS3 and everything else (ie not at all). They look a good find though!
Edited by travs
Cheers for the update and sorry to see all the parts are failing because of it but yours was the testament that was defying everyone else’s (and giving me hope I wouldn’t have to **** around returning mine).
Gone with @JR RS ’s suggestion although Delphi were out of stock so KYB variants on their way.
KYB KSC4260 and KSC4261 fitted. Need to get setup but they were a decent fit. Having done some research as they are the same spec as JRRS' Delphi suggestion, they are for Audi TT Mk3 (FV3/FVP).
So you lose 6mm of track each side rather than 14mm with the Golf parts. The seems to equate to a little under 0.5 degree positive camber according to Google. While Google/Gemini is telling me this using pretty catastrophic language, I can still physically see negative camber on both fronts. I'll keep this and tyre-wear under observation though and see what the 4wa results come up with.
Ironically, Gemini also suggests the Delphi ones that JRRS referred to, saying that, because they are for the Passat B8, they are wider as meant for the larger MQB-B platform cars. However, when I search for them specifically, they are suggested as a part for...the Audi TT Mk3. And no-one gives the bush centre-line to bush centre-line width measurement to confirm whether they're better or worse (even Delphi website). And if I search by model for Passat B8 (even the 280 equivalent Saloon AWD) you just get the black steel ones back at square one. And if I challenge Gemini, it admits that both parts are for the Audi TT Mk3 and that there is confusion sourcing this thread as a reference lol.
For now, the TT Mk3 ones are on, feel pretty solid and just waiting for the final work to be done to get the ARB on and the alignment done.
@MarioVrs how does yours feel now?
@travs mine feels like new car now. In the end i went back to original bottom arms but also replaced my droplinks on the front. I went for 034 Motorsport dynamic+. Not cheap at £225 for pair, but the built quality and feel of the car is totally worth it 😊
Best compromise I’ve been able to find is adding a TTS solid rear bush to the rear of the front lower arm and a poly to the front. The 034 stuff is solid and well put together.
Lovely.
I had Superpro front droplinks on order but researching the length reduction on lowering meant they were still too long. Got the longer of the two RacingLine offerings as could adjust when on the ground.
The TT arms have a solid rear bush - just standard front one though.
Question @MarioVrs H&R says ARB bushes go in dry - did you go along with that?
Yes i agree about 034 stuff, very good quality.
How does the ride feels with your set up? I'm quite happy with mine atm. Still want to fit Eibach springs but that will be after Christmas
3 hours ago, travs said:
Lovely.
Yes mine went in dry 🪒💪🏻
