Skoda octavia vrs 2011 starting problem
Hi hopefully someone can help,I've a skoda octavia vrs 2011 deisal,car done 145k miles,full service history,after I've used the car and it's run fine,sometimes if I stop at a garage or shop it struggles to start when I get back in,sounds like a flat battery,but leave it a few seconds and it flies over and starts,could it be the starter motor on it's way out ?
Edited by leecho66
Hi @leecho66
just popped this into the mk2 Octavia section for you, to get a better chance of help with hot starting 👍
If the battery/starter motor was on its way out I doubt leaving it a few secs would make any difference. Might be a poor earth or corosion on the starter connections.
Alasdair
Take a look at the cables from the battery and the connection points, including to the body.
I recently noticed the negative cable at the battery on mine shows signs of corrosion. White deposit inside the cable.
Still works but but I suspect it will soon show your described symptoms if not changed.
Could also be worn brushes in the starter motor only just making contact. They are replaceable.
Thanks for the replies,I'll check them,it's very strange,if I do a short journey and the car hasn't hot up to full temperature it's fine,but if it's up to temperature every time I stop now at a shop etc,when I get back in turn the key to start it tries to turn over but sound like the battery is flat,turn the key off and leave for few seconds it's OK,or if I've been on a gd run and park the car up,when I come to it after few hrs it's fine,it's like a heat seizure or something.
