Request for Firmware Update – Columbus Infotainment System (Škoda Kodiaq)
I hope you are well.
I am writing to request the latest firmware update for the Columbus infotainment system installed in my Škoda Kodiaq. The system has not been updated since 2018, and I am experiencing some limitations with features such as Bluetooth, MirrorLink, and voice navigation.
Vehicle Details:
  • Model: Škoda Kodiaq
  • Infotainment System: Columbus (MIB2)
I would greatly appreciate your guidance on how to obtain and install the most recent firmware version for my vehicle.
Thank you in advance for your help.
Whereabouts in the country are you? If uk. Potentially, I would probably let the dealer do it or if you were close too.
Yorkshire VWAG Retrofits & Solut...
No image preview
Collections
Authorised VWAG Independent Workshop Coding - Diagnostics - Retrofits - Vehicle Security Systems
because lots can go wrong, you need to have a power feed directly into the battery so it doesn’t run flat and then like updating a computer. If anything goes wrong, you get brick unit.
Thanks for the reply, Im in east sussex, the dealership asked for 2 hours labour minimum to do it, I did the map update myself and it went okay, it took about 45 minutes to update, leaving the engine running.
Yes, the maps can be done yourself. I thought you're talking about the firmware in the actual head unit!
I don't leave the engine running for a map update. Just ignition on and turn A/C & fan off to save battery. Someone suggested opening/closing the driver's door every 15 minutes or so to keep "the system" awake, which I do, but I'm not sure it's necessary.
I really wish you could update by country, which would be a lot quicker.
Yes I was talking about the firmware in the head unit, the maps were outdated too so I managed to get the file from Skoda website.
