Constant creaking / rattling from the doors of my Kodiaq Mk2
Since I had the car, every time I drove it, it has had what my wife called a rattling from the doors.
I always characterised it as a creak. As the car is otherwise so quiet (especially when on battery at slow speed) it was quite noticable.
After trying to narrow it down, I found a video on YouTube that described the issue exactly (but on a Lexus) - https://youtu.be/BoYCCckQdQs?si=Q549W00RwkRYLK9o
The guy in the video recommended applying a product to each of the door seals and claimed it pretty much cured the issue. The product he recommended was about £15, so I opted for the cheaper version at £3.82 - https://amzn.eu/d/9bGPMFX
It has worked brilliantly, and now my quiet car has become an almost silent car. If you have an annoying creak from your doors, give this stuff a try. I was very impressed.
Edited by BudgieUK
No rattling doors, but I get a frequent creaking/squeaking dash by the HUD. Car is 2 months and 1.5k miles old, 2 month wait for a warranty appointment at local Skoda 😡😡
Hi!
Ever since I picked up my new Kodiaq MK2 from the dealer (October 2024) I've had a rattling sound from what i first thought was from the passenger dashboard but which I now think I have located to the front passenger door.
I've recorded a video of the sound which i've attached below (a bit of road noise in the background but you can hear the rattling quite clearly)
Is this sound similair to the sound you have experienced? For me it sounds like something is loose.
The sound is not constant during the drive, but it comes and goes pretty much every ride.
It drives me crazy and I have to cancel the sound through high volume music.
I've tried to get my local dealer to have a look at it but no success so far.
Hmmm... it might be!
One thing that was suggested to me is to open the window a tiny bit.... not enough that you can see its open, but just enough to allow a tiny gap between the top of the window and the window frame. If you do that and it helps, it's probably the seals.
To be honest, the stuff only cost about £3, so it has to be worth a go ... I was in the same situation as you... the creaking noise was really frustrating, but this has cured it totally.
  • 9 months later...
On 09/09/2025 at 12:47, HugoL said:
Hi!
I think I have the same rattling sound, but on the driver's side of my Kodiaq.
I found that when I push the driver's door slightly  while driving I hear no sound.
In your case, have you tried pushing the passenger door?
Did you manage to solve the problem?
Welcome to the forum. Seems that simply or not so simple the door card needs to come of then a bit of padding, double sided tape or the likes. Draught Excluder / weather seal household tape needs applied between surfaces. Where SKODA should have had some.
Edited by Evolution13
Thank you for replying to my post.
I don't think it's the door card. If I push the door at the top, center or bottom while driving, I have the same effect. No sounds. Another way I can eliminate the rattling sound is by placing a cloth in the bottom door jamb before closing it. I think this creates a bit more distance between the door and the door opening. Please see the attached photo.
Have you considered it might be creaking from the seams (see my original post on this thread … it’s worth considering if you haven’t already.
You're absolutely right.
I've just bought some rubber care so I will be testing it this weekend.
I'll let you know how it goes.
Hi, that didn't work for me :/.
I tried using the rubber care, but no luck.
I dropped my Kodiaq off at Skoda today. Hopefully, they can fix it.
On 20/01/2026 at 17:50, koditzadispater said:
Oh, OK, thanks for the info. I was confused as for ICE cars this is an extra option, you can turn on heating or cooling remotely and I'm pretty sure I don't have this as a menu in my car either (I'm not interested so I did not opt for it).
Any luck with skoda sorting this? I have the same problem and the rubber care didn't work for me either.
I have great news. My Kodiaq has never been so quiet :).
Skoda has solved the problem. I'll describe the whole situation along with recordings, and hope it'll help you get rid of that rattling sound.
Let's start from scratch.
I had a rattling sound on the driver's side of my Kodiaq.
I noticed that if I push the driver's door a bit with my elbow while driving, the rattling stops. Another way I could eliminate the sound was by placing a cloth in the bottom of the door jamb before closing it. If your noise sounds like the one in my recordings, then you probably have the same problem as I did.
I tried applying a rubber care product on the seals with no effect (but thank you to BudgieUK for sharing that solution).
Before dropping the car off at Skoda, I recorded some audio and video so you can hear the sound and see what I did to make it disappear.
Please check out the audio and video files from the OneDrive folder.
The rattling sound happens only when I close the driver's door. When it's open, there's no noise.
Kodiaq-Rattling-Sound
Yesterday I got my Kodiaq back and everything is okay now.
The problem was the driver's door striker plate. See the photo below. They simply adjusted it, and the rattling sound is completely gone.
Give this a try if you are struggling with the same issue as I did.
Hope this helps.
Thanks to all of you who tried to help me out.
I have the same problem and lubricating the top door seals with Liqui Moly or AutoGlym rubber care makes the problem go away but only temporarily. Noise stops if I crack the window open even the tiniest amount of. If I stand outside the car and push on the top of the window frame it creaks very badly so I am assuming this is the issue. So @Marcinek do you know which way they adjusted the striker?
Hi everyone,
I was tagged into this thread, so I’d like to share an update regarding some issues with my car.
First of all, in my case, there were two different types of rattling sounds coming from the front left door. The first one, as I mentioned in my previous post, was fixed by adjusting the door striker slightly outward (which made the door fit a bit looser against the car body).
Unfortunately, after a few days, a second type of strange noise appeared and started to drive me crazy. It’s a completely different sound. Interestingly, when I cleaned the door recess, the noise temporarily disappeared. The same thing happened after a car wash – as long as the flocked seals were wet, it was quiet. Once they dried, the sound came back. I tried applying a silicone-based lubricant, but only to the rubber seals, as silicone shouldn't be used on flocked ones – which, obviously, didn't solve the problem either.
After days of troubleshooting, I finally found the root cause. Please take a look at the attached photos.
I placed a strip of stretch film inside the driver's door recess, and the noise completely stopped. I’ve been driving like this for three weeks now, and it’s been perfectly quiet. My theory is that the flocked seal rubs against the car body when the chassis flexes, creating that annoying sound.
In my opinion, the first fix actually caused this second problem. Because the door is no longer pressed tightly against the recess, the flocked seals have room to move. When the chassis flexes, they rub against the car body and produce that sound. If they were compressed tighter, they wouldn't shift and make noise.
I’m dropping my Kodiaq off at the dealership on Monday for a few days. I’ve already spoken with the mechanic, and they are going to try adjusting the door striker further inward to see if that solves the issue without bringing back the original noise. They also mentioned that they could replace the seals if necessary, so we’ll see.
One final note:
I did some research and found a water-based lubricant from BMW (see attached photo) that should be safe for flocked seals. However, that’s my plan B. I want the service team to try adjusting the striker or finding a permanent mechanical solution first.
My troubleshooting has identified rubbing in the exact same area. I’m going to see if the seals can be replaced.
After 2 years of my dealer trying to fix the door rattle by applying lubricant periodically, importer said that this is not an warranty covered issue.
Skoda support basically ghosted me on this as well.
Edited by Ilgmars
On 17/09/2026 at 16:06, Marcinek said:
Hi everyone,
One final note:
Hi, I am writing to update the product details I posted recently. The correct product should be BMW Carbaflo KSP 105, or Krytox GPL 105 as a plan B. Sorry for the mistake.
Yes, a version of Krytox has been the correct "thing" to use on these door seals to stop this sort of noise AND freezing up in tricky winter conditions.
VW Group call it gummi pflege.
I tried Gummi Pflege - it didn’t work.
