Facelift Crystal Style taillights in the VFL
Good morning.
Has anyone by any chance already completed this conversion?
The starting point, however, is that the LOW version is installed in the tailgate, so there's no taillight, etc.
Nobody?
So, that's the next project.
The starting point is the following:
Skoda Kodiaq model year 2019
PR code for SBBR light: 8SK
BCM:
HW 5Q0937086BR
HW Version 036
SW 5Q0937086BR
SW Version 0265
Destination:
Skoda Kodiaq model year 2021 facelift
Item number SBBR light
565945207B
565945208B
565945308F
565945307E
This requires re-routing the cables into the tailgate.
I still need to clarify the BCM software version to see if it needs to be updated.
As for the animation, the BCM definitely needs to be replaced, but it's not needed.
Edited by Cairus
Unfortunately, I had to process the information that the facelift was more modified than expected at the rear.....
that means the new upper part of the bumper is needed as well as various other things unfortunately...
the following parts are only needed for the conversion so that the facelift taillights are properly installed:
565807421B — Upper Bumper Section
565945105B — Left Reflector
565945106B — Right Reflector
565807393C — Left Bumper Guide (Small)
565807394C — Right Bumper Guide (Small)
565807393D — Left Bumper Guide 565807394D — Right Bumper Guide
565907455D — Left Blind Spot Radar Bracket
565907456D — Right Blind Spot Radar Bracket
565807863A — Bar with Clamps (Center Bumper Bracket)
565945207B — Left Taillight
565945208B — Right Taillight
565945307E — Left Taillight inside
565945308F — Right taillight inside
565945311 — Left taillight cover
565945312 — Right taillight cover
The complete retrofit will cost us around €1,000. Everything was rebuilt and coded by ourselves, of course.
Edited by Cairus
Good job.
And no 'before / after' pics? 😉
49 minutes ago, Bap33 said:
Gute Arbeit.
Und keine Vorher-/Nachher-Bilder? 😉
52 minutes ago, Bap33 said:
Gute Arbeit.
Thank you, one should not count one's chickens before they hatch. The project is still in its implementation stage.
Then good luck to achieve your project! 🤞
Edited by Bap33
First Material
The next parts for the conversion are arriving...
The next parts have arrived... connectors and pins for wiring, the set of taillights is complete...
So, here's the thing:
The facelift bumper section is getting a fresh coat of paint.
I picked up the last parts for the conversion today.
Good luck for final assembly!
The Side Assist is installed at the same time
Edited by Cairus
Left inside side is ready
Both inside Lights
question - where do the cables for the lid route? I am looking for reverse light for an additional one and I think it's behind the left side (driver's for you) rear panel, over the wheel. Do you have any ideas?
(nochmals auf Deutsch - ich will zusätzlichen rückfahrlichter nachrüsten und bräuchte dafür das Signal. Ich gehe davon aus, dass es im Bündel oberhalb vom hinteren Kotflügel ist, denn es geht richtung Klappe. Aber diesen B128 position habe ich noch nicht finden können... )
viel erfolg beim nachrüsten!
I've decided to go completely plug & play. I don't even want to re-pin the original wiring harness.
Edited by Cairus
So, the adapter on the left is now finished. Now I'm going to connect everything with a plug. I just want Plug & Play.So, the adapter on the left is now finished. Now I'm going to connect everything with a plug. I just want Plug & Play.
Today I briefly checked the adapters in the vehicle, it works as expected... maybe the first part of the installation will start this week
Update
Unfortunately, it looks like this at the moment; there's too much distance, with the new lights, regarding pedestrian protection, etc.
Now we wait calmly for the pole.
  • 7 months later...
hello everyone.
please Help me to find this center led brake light.
it will be huge help!!
Is Not OEM
20 hours ago, Cairus said:
Is Not OEM
yes i know its not OEM but i want to try so please find this for me!
I don't wish to dampen your enthusiasm but over bright rear lights are a contravention of the Road Vehicles Lighting Regulations 1989 in the UK. I'm not sure of the legal position in India - perhaps you should check this ?
