39 minutes ago, UmOm456 said:
Does anyone know what 03A8 actually is? Is it a firmware update, a navigation update, or something else?
Its an update for the OCU "Onboard Connectivity Unit" which handles Emergency Calls and Internet Connection for the Infotainment.
O3A8 Thread
40 minutes ago, UmOm456 said:
Is MU1989 still the latest software version for MIB3, or is there a newer version available?
As far as I know yes. Golf 8 looks like its on 1990
Golf 8 1990 Update Video
41 minutes ago, UmOm456 said:
error ERR_01_028_TP
This Error I encountered today as I did a factory reset. With this Error the installation of the digital handbook fails now all the time. Before I wasn't able to log in to my Connect Account for days and the globe stayed after engine start 10 -20 minutes gray without connection
  • Replies 274
  • Views 73k
  • fireflagrant
    fireflagrant
    For everyone interested, I put the newest versions ALL in ONE link: MIB3_Skoda_SW_1941_1969_1985_1989 I upgraded with this files one by one, no issues. Hope it helped.
  • MartinOctavia1969
    MartinOctavia1969
    I am now looking for making a download link. I think in 30 min of will be there
  • MartinOctavia1969
    MartinOctavia1969
    https://drive.google.com/file/d/1pHhf05ZfCgSUHKWJjW2IAlHXzhsgcllg/view?usp=drive_link Guys this is my first time to share a link with the new 1989 software. Don't be mad if it's not correct. Let me k
I had the same issue with logging into my account, and I also couldn’t activate the vehicle through the app.
After driving around for a while, the login eventually started working again on its own.
As a last resort, I deleted my account to create a new one. I think that may have caused me to lose the vehicle’s eSIM/data plan.
One question: Is it safe to overwrite the current system with the 7z package? I’d rather ask before I accidentally break something.
You mean the Data you buy on Skoda Cubictelecom? It's a separate account from Skoda ID. Delete Skoda ID account would also kill all your paid subscriptions I think.
Won't work. The only thing that the already updated system runs is the Post Script of all the install positions when u use the same update 1989 files. But maybe someone else knows more.
Yes, I mean the Cubictelecom data plan. If that’s a separate account, then that’s good news. I haven’t purchased any other subscriptions with my Škoda ID (at least not yet 😄).
Maybe someone can share their experience with the proper way to overwrite the latest version?
Or is it possible to downgrade first and then perform the update again?
15 hours ago, UmOm456 said:
I was offered an OTA update (Download 03A8) on my vehicle. At the time, I didn’t have an active eSIM/data connection, so the download stayed at 0 MB. I eventually cancelled it. Since then (over a week ago), the update has never been offered again.
After that, I performed a factory reset on the infotainment system, hoping the OTA update would reappear. Since then, the system attempts an installation every time I perform a factory reset, but it always fails with the error ERR_01_028_TP. The original OTA update (03A8) is still no longer detected.
Has anyone experienced this issue before or found a solution without having to reflash the unit at the dealer?
I also have a few questions:
  • Does anyone know what 03A8 actually is? Is it a firmware update, a navigation update, or something else?
  • Is MU1989 still the latest software version for MIB3, or is there a newer version available?
  • Can I simply reinstall MU1989 in the hope that it will fix these errors?
  • Is MOI3_EU_SK_R9890L MU1989.7z the correct firmware package for my MIB3?
  • Is this the correct procedure for a manual update?
    1. Press and hold MENU to enter the service menu.
    2. Open Software Update/Version.
    3. Start the update from the USB drive.
  • Should the .7z archive be extracted before copying it to the USB drive?
  • Approximately how long does the update take? Is it recommended to connect a battery charger, or is it sufficient to leave the engine running during the update?
Thanks for help
Stay away from this update (03A8).
Take a look:
Octavia MK4 MY2023 OTA update went wrong (03A8) - Page 2 - Skoda Octavia Mk4 (2020 > ) - BRISKODA
O3A8 Thread
Same issue for me after update to v1985 via USB...
Is it possible to downgrade via USB, so install the version beforehand? I would say that Skoda failed the update if it is not an isolated case, the visit to the workshop would be pointless
It looks like Škoda has apparently fixed the problem in the background. It took about a week since my last post.
Massive thanks to everyone in this thread for hosting the files and providing instructions on how to do this update manually. I went from version 1810 to 1989 without issues (so far at least) in my 2020 Octavia. The old version was slow and had a few bugs so was a welcome update, the new version feels much snappier. From start to finish took 45-50 minutes plus a factory reset straight after.
My car for some reason did not get OTA updates and I even asked my Skoda dealer for help as it felt risky but they just said "we don't do that" which feels crazy. The car is great but the support from Skoda less so and the documentation isn't very clear either in the manual or on their website.
I'll add pics in case anyone is interested in part numbers and the like.
Edited by andreaz1
Hello all!
Any solution to recover the e-Management option back on the latest firmware?
I also have the “Reduced charging current” function ON after the update, because before doing it it took like 4.5h to fully charge the battery (220V, home socket) and now it takes 8h50m 😵. And the only way to disable/enable this function was in the e-Management screen which is unavaible now, after the update.
Help pls!
Another way to enable/disable that option is via the mobile App. Do you still have a valid subscription?
Unfortunately I don’t have an active subscription right now.. I though about it but I wasn’t sure it will work.
I will try a factory reboot again.
1. Turn on the ignition and switch on Infotainment.
2. Tap the Menu / settings icon (usually a gear or the MENU button).
3. Go to Reset to factory settings (or System → Factory settings / Restore factory settings).
4. Select and confirm the reset.
5. After it finishes, check that all user accounts have been deleted to confirm success.
These are the steps, right?
And one more question.. I want to sell the car. If the new owner makes a new account and Skoda ID, will he benefit again of the 3 month free Care Connect and Infotainment online service? Or is a VIN related one time free service?
And secondly, is there anyone in the same position (after update via USB to 1989 the eManagement not working) that succeeded disabling Reduced charging current from the Skoda App?
Thank you in advance!
As far as I'm aware, the Skoda connect data is connected to you, and not the vehicle. If you weren't to reset your infotainment before you sold it, and the buyer didn't either when they bought it, then they'd probably benefit from it.
I deleted the car from My Skoda app and the infotainment was reset to factory, in order to delete all user data.
I managed to create a new Skoda ID and My Skoda app account (for the buyer) and indeed it let me activate again the 3 Month Free subscriptions for both Care Connect and Infotainment Online. (good to know, if you really need for a period of time the functions, basically they are free if you create a new account, activating the 3 months trial).
Secondly, you were right! I managed to go back to initial charging times with the subscription by de-activating the ‘reduced charging current’ in the app.
Thank you very much for the tip!
I have an annoying bug after updating from version from 1896 > 1941 > 1989, I notices that my roller boot cover does not automatically retract when you open the electric tailgate since the update.
I did not have the car long before I did the update but I remember it having an option to turn it on and off in the infotainment screen, but currently I don’t seem to have any options for it, it used to have a section called something like “opening and closing”.
Has anyone else lost this feature on the infotainment screen? if you still have this option on 1989 can you show me a photo have what that looks like please.
Do I need to do something to get this to reappear as I did the factory resets after the flashing, everything else seems normal, I don’t have any errors on the OBDeleven, and I don’t think its mechanical because it was fine before the software update.
I don't have that particular issue with things disappearing from the infotainment, but I did have one myself...
It was the ability to switch Laura's voice from male to an actual female lol
The setting appears very briefly in the relevant screen, but then quickly disappears for some reason. Took me a while to be quick enough to hit it before it went, but I did manage to change it
I'm sure other options went too, although I'm unsure of which ones.
Gotta love the bugs on these Skoda's....
Any new links to 1989, ive tried all on here and none are working please
Hi everyone,
Is there a way to see which version of the software is currently installed on the car and which is the latest update available at the time?
I have taken the car (Octavia vRS Combi 2026) in today for its first service and I told them that the infotainment screen had given me a glitch 3-4 maybe 5 times since last October that I purchased the car. They called back now saying that there is an update and the car will need to stay in overnight - maybe even 2 days - since the update is large and needs time to install. I will book an appointment to take it in next month as I need the car now.
I've read that some updates give more issues on the 4.5 (if I remember correct) hence why I'm asking what the latest update is and how to see whats currently installed? Is the update something that's recomended to do or should I leave it for a later date?
When I dropped the car off this morning they said it had no campaigns or updates and now I'm told there's an update(?)
Thanks everyone
The update they mention for the facelift versions is more that the infotainment unit - it's a package with software updates for many other ECUs on the car - called PV4RC. The update is worth doing - the general opinion is that it addresses several SW gremlins, even though I still have some issues trailing after the update.
AFAIK the latest update for the infotainment unit is 2768 for Seat/Cupra - the Skoda one should have the last digit +/-1 - otherwise they are "labeled" the same for VAG siblings sharing the same hardware. There was no major version update for the infotainment over the past year, unless the new models coming out of the factory have a newer version that's still unreleased OTA.
Hi SkOmk4,
Speaking to them yesterday when I went to pick the car up they said that they'll need the car for 2 maybe 3 days as its a large update. The workshop manager explained its an update that goes through all of the cars ECU's and it can take up to 3 days.
I checked on the car yesterday and the software version currently installed on mine is 2768.
I know logically when there's an update its for the better but coming from many years of owning land rovers the main consensus there is 'if it ain't broke, don't fix it' which mainly (also) goes for updates (and yes, I know firsthand you can't compare any LR to anything else reliability-wise but I love the wife's Octavia just as much).
Honestly I'm pretty happy with the infotainment especially reading up on the pre-facelift issues. I had this issue with the screen come up 3-4, maybe 5 times over the past year and they all occured during summer where the car's interior can reach extreme temperatures so didn't really worry me as it went away after you switched tha car off and on again. I booked it in yesterday for next month to get the update and see if that fixes it (although as said above, very rare)
The weirdest thing I find in the Octavia is that when my wife and I are both in the car somehow both our phones are connected to the car. No matter which one rings, it goes straight to the car speakers so we need to remember to disconnect one everytime.
Apologies for the long post and thank you very much for the info.
Recently Browsing 1
