Which, if any Gen 2?
Morning Folks!
I’m currently looking at getting a used Octavia for my commute to work over the winter months, it’ll be 50 miles each day and it’s a 4 on 4 off rotation so around 800 miles a month.
My budget is around £5k tops, which includes tax and insurance.
I’ve narrowed my choices down to a few, with the following spec;
2009 1.8 TSI L&K DSG estate @ 106k miles
2011 2.0 TDI L&K manual estate @ 145k miles
I appreciate this is quite the variety, with almost all of them being pre facelift. A lot of posts I’ve been able to see are from a few years back, and so maybe don’t provide the most accurate picture in 2025.
Any advice or guidance will be greatly appreciated, thank you.
Couple of points:
1) does your commute involve any pollution control zones? If it does you'll need a compliant vehicle (at least Euro 5 IIRC).
2) Facelift for Octy 2 was 2008-onwards, with a little blurring depending on which parts bin was closest to the production line :)
5 minutes ago, MikeTheThinker said:
Couple of points:
Hey mate!
1) nope, probably half and half A and B road, almost all rural so none of that to worry about.
2) yep, good spot… 🤦‍♂️ not gonna lie I copied this from my Superb post. So yeah, ignore that haha.
If you can source a decent 1.9tdi they are bomb proof. Had a 58 plate for 6 years and no problems apart from a sticking turbo actuator and the usual ball joints etc. plus a timing belt change and waterpump. No DPF to worry about and used to get 60+ MPG. They are getting rarer in good condition now though. Not as refined as more modern ones but I reckon thats why they are so reliable.
Alasdair
Alasdair
I've got a 55 plate 1.9 TDI and apart from tyres, brake discs, pads, calipers, cables, bushes, shocks, boots, wiper linkage, fuel injector, 2 x cam belts and pumps, boot switch, driver's belt socket, ABS pump, battery and starter motor I haven't had an issue in seven years!
Still goes like stink when you put your foot down mind.
Hi.
If you need any help with insurance at all for whichever model you're looking at then please feel free to drop me a line.
Regards,
Dan.
My 1.9 05 BKC manual is the most reliable car I have had. Put 230k on it.
Same here with the 1.9tdi BXE although only 140k on mine and then dreaded highland car rust killed it. Still have it for spares/repair but needs rear subframe and some sill patches plus road tax was high. My now 1.6tdi is only £35 a year. Only other cars I had that was as reliable were volvo 940. Last one had 250k on it from new and only major repair was clutch and centre prop bearing .
Alasdair
