0.5-second audio dropouts with Android Auto, Apple CarPlay, Bluetooth…
Hi, same problem for a month, it worked great, the sound started to stop for a second, could the last update be the cause? I'm going to go to the Skoda dealership to see how it can be fixed, it gets annoying especially when I use maps
Good morning,
It is possible that this is the latest update (which one do you have?). If that is the case, the dealership will not be able to do much to fix it, and unfortunately we will have to wait for the next update. Please write any news here. Thank you.
23 minutes ago, MRSOFT said:
Good morning,
27 minutes ago, edy71 said:
Okay, thanks. We’ll stay in touch if there are any updates
Good evening,
I would like to inform you that after speaking several times with my dealership, they are going to replace the 5F infotainment module in order to solve the issue with the audio micro-cutouts, since it happens with all sources (radio, USB, Wi-Fi, Bluetooth, cable, etc.).
It will take a few weeks before they do the replacement, but once I receive the car back and test it, I will let you know the result.
Best regards.
thanks for keeping us posted
6 hours ago, MRSOFT said:
Good evening,
Best regards.
That's incredibly infuriating that you've had this issue for so long, and are still going to have to wait a while to get it rectified, but I suppose getting an answer and (hopeful) solution finally is good news regardless of a further wait.
Hopefully it sorts out your issue!
  • 4 months later...
Good afternoon,
A couple of days ago, I finally had the 5F module replaced. I had to wait for a while because the part was out of stock.
Since it was replaced, I've used the car for almost 3 hours (2 hours and 50 minutes, to be exact) with Android Auto, Apple CarPlay, and FM radio, and I haven't experienced a single audio cutout or any other issues. At the moment I'm only testing it using a wired connection, but it used to fail that way as well before the replacement.
So, if you're experiencing a similar problem, this is definitely something worth asking your dealer to check, as replacing the 5F module appears to have fixed it.
Thanks everyone, and best regards!
thats great to know.. thanks for getting back to us about it. i wonder if you got a newer version or revision. is it the exact same hardware and software?
Good evening,
It has the same hardware and software versions, which suggests that the issue was with the unit itself. The only change I noticed is that the Wi-Fi SSID used to be “Skoda 7402”, whereas now it is “MyMib 660”.
Everything else is the same.
Edited by MRSOFT
sorry, i thought i had replied! it seems i dont get the drop outs when using an external SSD with the audio converted to m4a... so might be an android issue for me.
Hi, don’t worry, it looks like it’s an issue with your Android system… nothing to worry about.
By the way, since they replaced my 5F module, I haven’t had any problems with audio dropouts.
Best regards.
