Incorrectly Identified NSL Speed Limits
I'd be interested to know if anyone else is experiencing this:
Since the 25.12 map update, I've been getting consistent errors with single carriageway NSL roads. They're either identified as 20 or 30 rather than 60 MPH, with the resulting bongs & flashing warnings. I'd hoped that the next map update would sort it, but 26.2 has arrived & still the same. This is on a '25 SEL Edition with Columbus.
The odd thing is it only seems to happen when turning into an NSL road from a fixed speed limit. If a road transitions from fixed to NSL, the system correctly identifies that. Even weirder is in one example, I turn from a 40 MPH to NSL & it's identified as 30 MPH, turn again into another NSL & it's identified as 20 MPH. So in this instance there's no signs involved as the limit hasn't changed, which implies that it's duff map data.
Unsurprisingly, emailing Skoda was as productive as if I'd asked the cat...
I've found that, even in places where there are no traffic signs, the speed limit indication is markedly different if you have traffic sign recognition enabled. I know this, because I had a month's free trial of TSR, but was glad when it ended.
With TSR it seems to be accessing a second on-line data set, different from the sat nav one. I was getting all sorts of phantom limits showing for which there were absolutely no signs for the camera to spot - mainly 50 mph on motorways for sections where there had presumably been roadworks in the past.
If you do have TSR, it may be this second data set that's causing the problems, which would explain why an update to the sat nav data doesn't help.
When my TSR trial ended, I found the normal sat nav data to be much more reliable.
Interesting. Just had a quick look at the settings & can't see an option to turn it off, annoyingly.
Edited by Rbz5416
Google maps tends to be better, but it still has lags when limits have changed and Google hasn't updated. It is frustrating when Google has one limit, you car shows a different limit, and you know from the road signage that they are both wrong.
Had it happen again today but this time on a transition. The odd thing about this is it corrected after a couple of hundred yards. There were roadworks there recently, well a couple of months ago, so I'm suspecting that I have two issues. Road sign recognition isn't working, although there's no indication of that & the GPS map data is stale.
Edited by Rbz5416
  • 3 months later...
Still struggling with this despite two more satnav updates. A little bit of progress with Skoda support, as they pointed me towards the online version of the maps:
https://mapcreator.here.com/mapcreator/?site=global-skoda-consumers
Here you can drill down to the speed limits recorded on each section of the road & report errors. Annoyingly all of my errors are correct on that map, so something else is going on. Maybe as @Octy-PHEV alluded to, there's another data set at play here.
Having verified the map data, I bit the bullet & factory reset the infotainment, but no difference. So now awaiting the next step from Skoda.
Just to update, although it appears that I'm the only one affected.
Skoda's next position was that they'd identified the issue with the map data & that it would be fixed in the next map update. Map update came & went with no fix.
They then decided they could only fix it by supplying a secret solution to a dealer. Wouldn't disclose what the fix comprised of & wouldn't commit to covering the cost under warranty. Collected the car Wednesday after the ball ache of getting to/from the dealer by public transport. Dealer said they'd applied a service bulletin fix & updated "numerous modules". The end result of which is...absolutely no change.
The only positive is that Skoda covered the cost,
Edited by Rbz5416
Same thing happened to me intermittently and annoyingly on minor roads in North Yorkshire. I just pressed on regardless
I sometimes get this when on the A303 heading east coming to the Sparkford turnoff, it ' sees ' the 40MPH sign sometimes , especially if I'm in the overtaking lane ! I just carry on and reset the ACC and it recovers about a mile further on.
I've a similar anomaly just outside the village of Edingley in Nottinghamshire, for several years a short open stretch (500yds) of country lane (60mph) pings 30mph on the dash, but not on Waze.
I've slowed to have a good look around to see if there's anything amiss causing the anomaly, but no, nothing.
I've even been on the Skoda mapping site but it correctly shows 60mph.
Now, this last week, the stretch has somehow managed to reduce itself to an imaginary 20mph.......weird.
Good to see that this isn't solely my issue. Living semi-rurally means that I travel affected roads pretty much daily. I've even found a stretch where the limit varies between 20, 30 & 60 in one direction but maintains a steady 30 in the other.
The latest from Skoda is that the workshop didn't test the specific issue after applying the "fix", because it would have meant driving five minutes out of town. For a bonus laugh, it turns out they're one of the many service centres who don't sell vehicles. As such they have one Skoda trained technician, who promptly went sick. Skoda UK have shown zero interest in progressing this beyond waiting for him to return to work. They also have no idea about what's caused the instrument illumination to fix at max. ☹️
Nothing much to report by way of a fix.
Skoda Connect, who claimed to have the magic fix have now stopped responding to me. I reported the fix had failed the day I received the vehicle back. That was three weeks ago & since then - nothing.
Skoda UK have admitted to having no technical knowledge. But they now are very keen for me to book further diagnostics at my expense. They seem to be claiming that despite the fault & fix being diagnosed by Skoda Connect, I now have to pay the dealer for further diags. The matter is further clouded by receiving conflicting emails from four different individuals at Skoda UK, all claiming to be "managers". I get the impression they now want me to cover the cost of the failed fix!
I've asked for the matter to be escalated, but it's all leaving a very sour taste. However this pans out, I won't be buying anything else from VAG.
That's why I still use TomTom.....😄
Odd post as this is nothing to do with navigation...
Never heard of TomTom Sat Navs? 🙄
Even odder post. Please explain how a TomTom SatNav integrates with the Karoq's ACC?
It doesn't.....I use TomTom having given up on Skoda's rubbish navigation system and I don't understand why people would continue to try. Just ditch it, buy a TomTom cheapie and get free map updates for life.
I can only surmise you've been reading a different thread. Again, this issue has nothing to do with navigation.
Most people seem to have unlinked the ACC from their traffic sign recognition and map display. Doing that means you have to set the ACC speed manually, but avoids it changing to an inaccurate one all by itself.
