Citigo E IV won't charge
My wife has a used 2020 model that has just started refusing to charge using our domestic 13A supply. Symptoms are;
Flashes orange led for 30 secs then acts as if charge completed.
Same result with a different cable that shows initially 0.4 A then 0
Car seems to be sending the wrong signals to charge cable.
This is the early model with no Bluetooth so we cant connect an App.
The only way I can get charge in now is to leave the Ignition on and press the Chsrge button on the centre console but that is not ideal as the cae then cant be locked!
Any ideas what to check? The 12v battery went a bit low but has since been recharged and id ok.
Even if the 12v battery seems fully charged it may be on its way out. Check its reading 12.5-12.8v if you havent already.
Alasdair
If you can charge with the ignition on then the microswitch on the gear selector has failed. This will not let you charge because the car thinks it is not in the Park position and you should get a fault on the app saying the parking brake is not applied. The total unit replacement is 12E.713.025.G and is in the order of £700. However it is possible to get a similar microswitch for about £5.00 from RS components or similar. This will need modifying and soldering to the printed circuit board once you have dismantled everything. There is a video on the VW-UP web site https://www.upownersclub.co.uk/threads/car-wont-charge-yellow-flashing-light-selector-not-in-p.14359/?nested_view=1#replies and a link to a video on how to do it. I did mine about a month ago and it is still working! Best of luck and get in touch if you think you need more details.
