waze direction arrow incorrectly displays on centre consol
Waze used with usb connection from Samsung A17 on a 2026 Karoq.
Problem: turn direction arrows appear correctly on info system screen (waze display) but are corrupt on the driver centre console.
This has been a problem from day one of ownership.
example: waze might show turn next left but console shows turn right
example: waze might show turn next right at roundabout but console indicates "do a U turn"!
A solution would be appreciated.
No idea how to fix your problem - but, it's news to me that the digital dash can show Waze.....?
waze is displayed via android auto. Works beautifully. Voice defined destinations too.
This might could be a model year difference, I ditched CarPlay because it wasn’t fully integrated with the steering wheel controls and the digital dash in my 2023 Sportline- but I understand in later cars 25/26, it is.
have you tried pressing the direction arrow on the Waze screen, I think that it looks like a diamond shape in two colours.
There is a Menu item in the Waze settings, on your phone, which allows you to select the arrow direction ie permanent North or the direction you are going along. You can also select, not on iphone which side the info is displayed, ie further away from the driver so the map is clearer.
yes, thanks, but that is not relevant to the problem I stated.
Just reread your OP, sorry Question, why are you using USB when the 2026 has wireless AAuto, mine does. and as Berisford said earlier, you may have Waze quite clear on the centre screen, doing as it should, but the cockpit screen only shows the the Skoda map, which does not get any info from AAuto. When I start Waze the cockpit automatically switches to a map, the Skoda map, you need to press a steering wheel button to hide it.
the phone I use needs to be plugged in to charge. Waze also works via wireless. Makes no difference in the problem.
Again, that is not the problem.
The skoda map is not used at all. The arrow indications in the centre console are managed by Waze but do not always show the correct expected direction.
If the arrow displayed consistently indicated the correct turn direction there would be no problem.
as an aside:
The automatic switching of the console to the skoda map is a stupidity which can indeed be temporarily switched off by selecting a different content.
Unhappily the centre console display is dynamic and can't AFAIK be locked on one specific app/function. The overall display that I have is:
Left: analogue revcounter and distance-to-car-in-front display
Right: analogue roadspeed, fuel remaining
