Skoda Karoq 1.5 DSG gearbox
Buying a new 27 plate Skoda Karoq 1.5 with DSG gearbox.
Interested to know what mileage you have on your Karoq with the 1.5 DSG and any issues you have encountered.
Online searches seem to imply they blow up at 30k or go on for ever. Interested in real world driving.
I do a 50/50 mix of country urban and motorway.
Thank you.
The difficulty with the online searches is the number of owners who report DSG problems is greater than I’m on those who have no problems. Clutch packs can wear same as a traditional manual so no different really except perhaps in cost. Mechatronic unit is the other failure item but never really find out why they fail. I saw a comment recently that the DSG failure rate DSG with the 1.5 TSI engine is the best combination. There is a dry clutch DSG 2013 VW pool car at work, it’s just had a mechatronic unit replaced at 75k miles, cost £1800, it’s driven by many people with varying levels of skill and mechanical sympathy, so I’m not surprised. We’ve got a dry clutch 2015 Fabia no issues with the DSG, I had a wet clutch DSG 2013 VW no issues with in 108,000 miles and I towed a twin axle car trailer with it as well. This might be of interest https://www.team-bhp.com/news/understanding-vw-skoda-dsg-dq200-failures-detail?amp
I'm guessing this has been discussed before but my 1.5tsi dsg is 5,5 years old and has done 51,000. The first 1,700 as a demonstrator.
What is the current thinking about maintenance. It's difficult to tell but occasionally seems to hesitate especially from cold.
What's the best course of action for longevity?
Thanks for the replies.
I get the same with my previous two cars, both Ford Mondeos. One a 1.6 Petrol and my current vehicle a 2.0 Diesel. Both manuals. 200k on both without any problems. Yet if you google for reliability it seems to suggest 80-130k max. So like you say driving style is a factor.
As I'm relatively sympathetic when driving hoping to get 100k before any major issues. £1800 for a mechatronic unit is comparable to a clutch replacement on a Ford so not too bad I guess.
If I can get 15 years out of the Karoq (16 and 13 years for my two Mondeos) I'll be happy.
We picked the Karoq because as we are getting old the Karoq offers a level of comfort we didn't find with most other brands.
Edited by munnst
From what I have read not creeping in traffic prevents the dry clutch over heating.
There's conflicting evidence but changing the mechatronic oil every 40k is suggested to prevent failure although for newer models there is no official oil change required. Interested to hear from mechanics on that one. Again like my Mondeos you'll find stories of people stating to change the cambelt at 50k for the diesel. I changed mine at the manufacturers recommendation of 125k without any problems.
My mate told me today that his April 2019 VW R-Roc 1.5 150PS DADA's DSG - which will be the DQ 200 (dry clutch), at roughly 67,000 miles, handed out its first trans fault warning this week, his DIL who tends to use it most of the time, lost all drive, pulled into the side of the road, cycled the ignition and that sorted that out - for now. It has been taken out of use until it can get looked at. From what he told his VW Group Indie workshop, they are speculating that it will be a case of mecha unit out and sent away for repair - and they said "don't drive it now".
Would oil and fluid changes have avoided this, who knows, probably just another accumulator casing failure! Cars of that age were meant to have benefitted from a slightly increased accumulator wall thickness, so maybe so other failure.
Edited by rum4mo
Added in "April".
@rum4mo I think I am correct in saying that the dry clutch mechatronic unit and main gearbox have their own separate dedicated oil systems. The wet clutch DSG has a single oil system that lubricates the gears, acts as an oil bath for the clutches and also provides the fluid for the mechatronic unit. With regard to creeping in traffic - with both wet and dry clutch DSG boxes when the engine is on tickover and the car is moving clutches are fully engaged so they are not slipping but the clutches can overheat with continual slipping. I would suggest that in queuing traffic a slow continuous creep on tickover is better for the DSG clutches than repeatably stopping and pulling away from stationary - the 7 speed DSG boxes tend to try and start off in 2nd which slips the clutch more than starting in 1st. We have a dry clutch Fabia and wet clutch Karoq, and I creep in traffic rather than stop/start all the time whenever possible, if I do have stop I leave quite a big gap to vehicle in front so I can start creeping sooner and not have to use throttle, I dogged same in the manual vehicles I drive.
In 7 years driving a Seat Leon with the dry-clutch 7-speed DSG it never once started off in 2nd, always 1st. Same in 6 months in a Karoq with same gearbox.
@thamestrader yes I know that but it seems like replacing the fluid can allow any circulating "bits" to get dumped out - while VW Group maintain it is not required.
I was only speculating that having the fluid changed might, just might have meant avoiding this issue - although if it is the accumulator developing cracks then nothing would have avoided that in the initial build of the Mecha unit.
Edit:- though you are talking about aspects of DSG use that, as someone that has yet to use one, has always concerned me, maybe without any good logic or reason.
Edited by rum4mo
@thamestrader A DQ200 DSG should not start of in 2nd regardless of fitted to a TSI or TDI from 70 ps - 192 ps. There is a small filter in the MCU, but that needs to be off and opened to change it. @munnst Who is it that advises changing the MCU oil at 40,000 miles? Can you link something to this affect? There is so many Chinese Whispers stuff regarding this online. If changing the Oil change both oils, if you know what you are doing. IMO. Cleaning out the stoor in beside the clutches is more important as far as i am concerned.
Edited by Evolution13
As far a cracking / leaking & also the accumulator cracking. 2017 there was a Service Campaign started on 2013-2016 DQ200,s., 3 times recalled in Australia. (There are repair kits and upgrades, but not from VW. ) This was '34H5' a software update. This is nothing to do with '34F7' 2009-2012 Changed synthetic to mineral oil and a software update. Millions recalled globally but only a service campaign in the EU / Europe. IMPORTANT. No point comparing issues. 2009-2012, or 2013-2015/16 with the DQ200,s built 2015 on and the issues. Then the 1.5TSI Kangerooing issue up to 2019/20 was Manual or DSG, and there were Updates. Maybe more hidden with a DSG. Later Stop / Start , cutting out issues and another Kettle of Fish, or Can of Worms. As to this link... There were Clutch Upgrades and software updates. http://briskoda.net/forums/topic/439395-the-story-of-the-famous-dq200-clutch-slip
To those who have said the DQ200 shouldn’t start off in 2nd, I would agree it shouldn’t. Neither our dq200 Fabia or dq381 Karoq start off from stationary in 2nd it’s always first gear. However both have a tendency to use 2nd at Give Way junctions and entering roundabouts if I don’t quite stop. Must be the way I drive.🤔
Exactly. Speed down at 5 or 6 mph and not dropped to 1st . It has not come to a halt. There are 7 gears, all can be used by 50 mph. But shifter to D or S at a stop selects 1st . Stopped and use manual you can not select 2 M
Regarding changing the oil at 40k, just general googling so not stating that's what you should do. Just throwing it out there. Real world experience is more important.
As was previously stated earlier in this thread people tend to report bad experiences not good ones and probably give an unfair impression.
Skoda is a good brand and the Karoq a popular car so I wouldn't be surprised if you could own one, with regular servicing and a sympathetic driving style, without any major issues over high mileages.
Interesting AI seems to think 80k is high mileage for a car. As someone who regularly takes their cars over 200k that surprises me.
@munnst AI very often has the answers that they give from Briskoda threads and posts and many no matter which question you ask will be from posts / links by me under whatever name i used over the post 14 years or so. I can guarantee that i have read every thread & post on this forum ever made about DSG,s. Maybe even know better what the discussion was on the subject better than AI. It is still learning and gets things very wrong quite often.
Further to my comment about my mate's 2019 VW T-Roc 1.5TSI 150PS DSG issue, his VAG Indie workshop now have his car, read the codes etc and consider that it is an gearbox oil pump related issue - £4500, repairing the DSG will get carried out by a gearbox specialist. So, roughly 67,000miles in 7.5 years and no gearbox oil or fluid changes carried out which is in line with advice by the manufacturer, could this have been avoided if the oil and fluid were changed at maybe the 5 year, 50,000miles point - who knows. I think that he was told that this DQ200 was improved in 2022 - I'm guessing to improve reliability, though cold comfort to folk like him.
The car still drives - if that is relevant!
Edited by rum4mo
put in 70,000miles should have been 67,000miles!
2012 in other world regions they had to put a 100,000 mile warranty on them. In NZ all DQ 200,s got a new MCU not just a software update and mineral oil like in other regions, including the EU / Europe if the owner found out there was a service campaign. In Australia there was a 5 year warranty and now I think 7 years. But then in Australia and North America and some other regions it is an 8 speed torque converter auto fitted to the excellent 1.4 TSI,s. Where the World Wide Harmonised cheat testing is not necessary for the emissions. VW no faith in their no servicing product to give the DQ200 DSG a 8 year warranty globally.
Supposedly VW had a program to design a new torque converter gearbox platform to replace DSG but canned it as EV legislation meant ICE cars have a limited production lifetime.
Interestingly, Skoda just launched the Slavia in India with an 8 speed torque converter auto in the 1 litre, but they've stayed with DSG for the 1.5.
Touch wood, our experience of DSG in Tiguan and Karoq has been fine, but I do think they'd be a 'nicer' drive with TC autos.
Edited by Rory
The OP also asked for typical mpg. According to the MySkoda app my 2024 Karoq 1.5TSi DSG has returned 45.2mpg over the last 30 days. That has been a mix of motorways, main & minor roads & Cotswold hills. Very little town driving. Total mileage in that time around 1400 miles.
VW were developing a 10 speed DSG a decade ago which would basically be like a CVT. (DQ511). Honda was doing a 11 speed triple clutch a decade ago and binned that.
A final(hopefully) posting on my mate's 2019 VW T-Roc 1.5TSI 150PS DSG, WBAC happily took it off his hands, I don't know what sort of money he got for it, but maybe I managed to soften the blow by saying that I was worried that he was going to just get it repaired and then get hit by the much quoted DADA engine problems "quite soon after".
So it's back to using some of his fleet of classic SAABs for now!
Edited by rum4mo
to not t !
