38 mph in 5th gear ?
hi Everyone i have just recently bought the Skoda rapid estate which seems to have come with a few problems, one being when i start the car it idles a 800 rpm then when it gets warm it it get to 1000, and in 1,2,3,4 gear it quite normal then in filth it goes along on its own at what seems to be 38 mph as thought cruise control is on has anyone experienced this thank you in anticipation
Welcome. Best say what engine you have as we can not just guess. Is it a manual gearbox? With a TSI normal is maybe 1,100 rpm on start up and dropping to 800 or so rpm after 40-60 seconds. Is the AC on or off?
yes sorry
Model Variant
Rapid
Description
Rapid Spaceback SE Tech TDI
Primary Colour
Red
Fuel Type
DIESEL
Transmission
Manual 5 Gears
Drive type
4x2
Engine
1598 cc
Body Style
Hatchback
Year Manufacture
2015
Euro Status
6b
aircon off, thanks for your quick reply
It sounds to me that the ECU is commanding too high closed-throttle revs when engine is up to temperature, you need to have the vehicle scanned for any DTCs (fault codes) recorded. It could be due to a faulty sensor.
Is the car doing regen maybe, and constantly.
Is this just the anti-stall software not allowing you to trickle along at (too low) revs? What revs is it doing at 38mph in 5th?
