Bixenon Headlights auto-adjustment problem
Hello,
I'm asking for your help because I've run out of ideas and am starting to lose hope...
Recently, I've been driving my Škoda more often at night, and I've been getting countless "flashes" from oncoming drivers. I decided to investigate the issue because the headlights were not lowering their beam when the boot was loaded.
Here is the situation:
  1. The headlights perform their self-test when the car is started (right, left, down, up).
  2. The headlight motor tests are completed without any problems – the motors move the light beams both up and down.
  3. Basic Settings for the headlights have been performed, and there are no fault codes. The sensor reading is 46%.
  4. When I load the boot, the sensor reading drops to 41%, when two people inside it is 42%, and go back to 46% when empty....
Unfortunately, the light beam moves upwards, and no downward correction takes place. :(
I'd also like to mention that the system was working correctly 6 years ago when I bought the car, and I was really impressed with it at the time.
Two years ago, I was involved in an accident. The car was repaired at an authorised Škoda service centre, and both headlights were replaced with brand-new genuine units.
Additionally, I've noticed that I cannot enable the DYNAMIC CORNERING LIGHTS option in the car's infotainment settings. It switches itself off again after a few seconds.
I would really appreciate any help, suggestions or advice you could offer. I'm running out of ideas and would be grateful for any pointers.
Thank you in advance!
So the crash repair is the most likely issue.
Might be a long coding issue which tends to tell the car which items are installed. If the car doesn’t think it has self-levelling headlights it might not be listening to any level sensor if that makes sense.
What’s the make model and year? And do you have DCC?
Skoda Superb 3 2016, i don't have DCC. Is it possible to do anything with that long coding with OBD11?
Regards, Arek
Edited by AroCz
Mine is 2016, no DCC. Headlight part number ends in A. Corrector part number 7P6907357D. Long coding is 06DE00003F010000 if that helps at all.
Could it also be a faulty level sensor on the back axle? or would that give a fault code?
Sensor is working and change values after car is loaded. There is no fault code. Lights are working for sides, but no decrease the snop of light.
might be coding of controller. you should be able to see this with OBD11 and compare to mine. I have no idea if it will be directly applicable but could be a good place to start.
Only danger with quoting a full long code is that certain options or locations may differ between models. Many of the long codes quoted in the VCDS posts are different except for the pair of digits being changed. If that makes.
Yes. Advice from someone such as @Cairus might be required. He tends to know the long coding for everything!
Sensors may working yes, but was it fitted the right way round after the crash repair?
Cause the leveling sensor arms that pivot can b fitted the wrong way round, and cause the headlight aim to misbehave.
This how the 3x sensors on DCC equipped cars should look like this....
Front left axle
Front right axle
Rear left axle
OP doesn’t have DCC so it will just be the rear sensor. So should. Have been impacted in accident.
No, the rear sensor wasn't impacted. The accident was at the front end. Only radar, two headlights, bumper with stuff and front cover/mask.
Could anyone check the value from the sensor in Live Data? My shows 46% after Headlights Basic Settings implemented. Whatever that means....
All the basic setting does is disable any input from the front and rear sensor (should be two) at least, to differentiate front to rear leveling, the tech then adjusts the beam setting on the tester, the basic setting is then turned off allowing the sensors to influence the beam setting again. It is a bit like when you do your tyre pressures then push the set button in simple terms.
You may have a seized sensor. One on the front of my car seized, no warning lights on, did the up down out in sequence but no range control. The ball joint had rusted and expanded in the plastic joint seizing it solid. Or like someone suggested, they are upside down, or more likely the bodyshop just fitted the lights and havn't coded them in.
Edited by 3T51704x4
Typo
Good morning, good evening, or perhaps good night—I’m not quite sure what to call it! 😅
So, someone triggered me? Let’s take a calm look at everything and clear up the basics.
What hardware is installed in the vehicle? If you have OBD11, please perform a full backup and attach the file here in the forum.
Also, going back to the accident: were only the headlights replaced, or were both the headlights and the control modules (power modules) replaced?
Once these two points are clarified, we can look at the details.
Hello All,
that is the main problem - I have my all stuff in Poland and I am currently in Germany.
I could ask my friend for creatin the backup file and i would try to attach it on the forum. My OBD11 is .... in Poland...
I also don't have idea did they replace only lamps or all electronics als.... Invoice is in Poland.... But the price for one lamp was 2500E if that helps a litlle bit....
And for now the question is what should be the Value for the rear sensor. At my car is like depicted below:
  1. after Basic Settings the value is 46%
  2. with one person on board the value is 43,5%
  3. with two person on board the value is 41%
Does anyone know that these values are ok? Maybe someone could check Live Data in his Superb, pls?
You said that when you’ve loaded the vehicle, the headlight adjusts upward?
The system works the same way in all MQB vehicles. Typically, you only have a sensor on the rear axle.
Edited by Cairus
I mentioned that after i've loaded the trunk/boot, the headlights went upward and did not correct the hight - but it should correct the level of headlights and move it down.
That doesn't make any sense; if weight is added at the rear, the front axle rises, so the lights need to be adjusted downward.
Does the light actually adjust in any direction when the axle is loaded or unloaded?
Edited by Cairus
Yeah, that is the current problem. the lights need to be adjusted downward, but nothing happens.
Then I misinterpreted the first post. I understood it as "increase the rules."
You have Backup?
Recently Browsing 3
