Bixenon Headlights auto-adjustment problem
@AroCz - which channel r u reading the values from? I'm assuming this is on module 55 - Headlight, given urs is MY16
This is the Basic Settings values of mine (with DCC). However this with all 4 wheels hanging, for the DCC Recalibration procedure.
I'll c if I can get the readings with the car sitting normally.
Edited by JR RS
I’m travelling at the minute but will see if I can read level with my scanner when I’m back at my car as I don’t have dcc
Guys, thanks for the reponse.
Binx1310, awaiting your data!
A thought though. I wonder if it might be irrelevant anyway. May give you some info of relevant position but with regards to the precise number, @JR RS has me thinking. does the adaptation without dcc have to be done in the same way. E.g jacked up with wheels hanging at full extent to find a max extension and then all compression of suspension is relative to that figure.
Edit: just had a look at the manual and it only mentions basic settings for dcc. Will let you know what my numbers are when I get a chance to look.
Edited by Binx1310
The difference is that with DCC, the sensors are processed by the DCC control unit, whereas otherwise, they are handled by the BCM (Body Control Module). The system stores information regarding which axle is installed and the number of sensors—specifically two in the case of all-wheel-drive vehicles. The regulation mechanism functions on the same principle, regardless of whether DCC is present or not. The basic setting (calibration) for DCC is distinct from that of the headlights. The vehicle should be positioned normally on a level surface and left unloaded before performing the basic setting.
First Screen With positiv pwm = Seat
2nd Screen with negativ pwm = SKODA
Sorry, it seems that this isn’t a sensor that I can read with carscanner.
Hi Guys, Cairus
Edited by AroCz
English?
Source: OBDeleven screen recording dated 17 November 2026 (75.67 s). The parameters visible on screen have been transcribed in the order in which they appear. Where a field is marked “[truncated]”, the app displays only the beginning of a multi-part value. Missing portions have not been reconstructed.
Header and long coding
• Saved backup name: “All control units” (original: “Wszystkie jednostki sterujące”)
• Backup date: 2026-11-17, 11:18
• Odometer reading: 199735 km
• Module: Multifunction Module
• Long coding (60 HEX characters): 000000020100066A00003F00000000000000000000000000000000000000
Adaptation – 16 channels
|Channel|HEX value |
|2306 |62090200 |
|11543 |622D1700 |
|11561 |622D2900 |
|11542 |622D1601 |
|11558 |622D2601 |
|11583 |622D3F64 |
|11584 |622D4000 |
|11617 |622D61000000000000 |
|11618 |622D62000000000000 |
|1278 |6204FE000000 |
|1276 |6204FC000000 |
|1296 |62051000 |
|2778 |620ADA1E1E1E32323232324B4B5050|
|1297 |62051100 |
|1298 |62051200 |
|1187 |6204A303 |
Live parameters / measured values
|No.|Parameter |Reading |
|1 |Output test status |Inactive |
|2 |Basic settings status |Inactive |
|3 |Security Access: number of invalid keys |0 |
|4 |Terminal 30 voltage |12.1 V |
|5 |Engine stopped by start-stop function |OFF |
|6 |Engine started by start-stop function |OFF |
|7 |Terminal 15 status via CAN bus |ON |
|8 |Engine status |OFF |
|9 |Number of unplanned control-module resets |Watchdog Reset: 0 |
|10 |Multifunction Module Application Software Version |Version Routing FCM: 7160; Software Version AFS/MXB: 0065 |
|11 |Processor utilization |Total system FCM: 24%; Software component AFS MXB: 13% |
|12 |Predictive Route Data Street Class |Not available |
|13 |Predictive Route Data Number Of Lanes |Not available |
|14 |Predictive Route Data Speed Limit |Not available |
|15 |Predictive Route Data Placename Sign |Not available |
|16 |Predictive Route Data Intown Flag |Not available |
|17 |Headlight levelling control state |Static |
|18 |Left dynamic cornering light value |Fault |
|19 |Right dynamic cornering light value |Fault |
|20 |Front left suspension height sensor, learned value (zero position)|-0.01 % |
|21 |Rear left suspension height sensor, learned value (zero position) |46.00 % |
|22 |Driving profile selection |Specified value: 0; Actual value: 0; System status: Not available; Compatibility: Yes; Switching p… [truncated] |
|23 |High beam |OFF |
|24 |Reverse gear status |OFF |
|25 |Turn signals |Not activated |
|26 |ESP intervention |Inactive |
|27 |Ambient brightness |1890 lx |
|28 |Low beam |OFF |
|29 |Vehicle speed |0.0 km/h |
|30 |Steering angle |1.20 ° |
|31 |Front body deflection |0.0 mm |
|32 |Rear body deflection |-17.2 mm |
|33 |Left headlight range control adjustment motor, status |No fault |
|34 |Right headlight range control adjustment motor, status |No fault |
|35 |Left dynamic cornering light adjustment motor, specified value |32.000000 ° |
|36 |Right dynamic cornering light adjustment motor, specified value |32.000000 ° |
|37 |Left dynamic cornering light adjustment motor, status |No fault |
|38 |Right dynamic cornering light adjustment motor, status |No fault |
|39 |Variable lighting adjustment motor, front left, status |No fault |
|40 |Variable lighting adjustment motor, front right, status |No fault |
|41 |Left headlight range control adjustment motor, specified value |1024.0 mm |
|42 |Right headlight range control adjustment motor, specified value |1024.0 mm |
|43 |Switching from left-hand to right-hand traffic |OFF |
|44 |Dynamic cornering lights |OFF |
|45 |Front left suspension height sensor |-0.01 % |
|46 |Rear left suspension height sensor |42.40 % |
|47 |Light distribution status |Not activated |
|48 |Front left variable lighting, specified position |204.70 % |
|49 |Front right variable lighting, specified position |204.70 % |
|50 |Headlight basic settings status |No command |
|51 |Static cornering lights |Left static cornering light, dimming: 0.0 %; Right static cornering light, dimming: 0.0 % |
|52 |LED headlight, light distribution commands |Low beam: No command issued; High beam: No command issued; All-weather lights: … [truncated] |
|53 |Actual reference segment angle |Horizontal reference segment angle, left side: -500.0 ′; Horizontal reference segment angle, right side: … [truncated] |
|54 |Matrix headlight, calculated offset values |Left headlight horizontal offset: -300.0 ′; Right headlight horizontal offset: -300.0 ′; Vertical offset l… [truncated]|
|55 |Drift angle |-120.0 ′ |
|56 |Axle offsets |Rear axle offset: -400.0 mm; Front axle offset: -400.0 mm |
|57 |Matrix high-beam function status |Inactive |
Advanced identification
|1 |Number of programming attempts |Application: 0; Bootloader: 0 |
|2 |Number of parameterization attempts |Dataset: 1 |
|3 |Number of successful parameterization attempts |Dataset: 1 |
|4 |Maximum number of possible software updates |Application: 65535; Bootloader: 65535 |
|5 |Detected subsystems |Subsystem designation: Reserved; segment number: 4; subsystem present: Yes; subsystem … [truncated] |
|6 |Busmaster / Subbusmaster identification |ECU ID: 4B; ECU Name: Multifunction Module; LOGICAL-LINK SHORT-NAME: Multifunction Module |
|7 |Connected component identification |Identification number: 4B; subsystem name: Multifunction Module; Bus information / node address: A9 |
|8 |Subsystem diagnostic classes |Systems, diagnostic class 3: Yes; Systems, diagnostic class 2/2F: Yes; Systems, diagnostic class 1: Yes; Syst… [truncated]|
|9 |Service code and date of last software module update|Year: 0; Month: 1; Day: 1; Equipment number: 0; Importer number: 0; Partner number: 0; Programming status… [truncated] |
|10 |Date of last coding |Year: 22; Month: 18; Day: 5 |
|11 |FAZIT identification |Manufacturer plant code: SJ8-FST; Production date: 29.11.16; Manufacturer test station number: … [truncated] |
|12 |Parameterization identification |Number of datasets: 16; AFS dataset: 04; MXB dataset: – |
|13 |Diagnostic mode |VW diagnostic mode |
|14 |VW / Audi part number |3Q0907338 |
|15 |Software version |0285 |
|16 |Serial number |29111610520147 |
|17 |Hardware part number |3Q0907338 |
|18 |Supplier software version |FFFF2706201612111700000000000000 |
|19 |System designation |FCM MQB Low |
|20 |Adaptation service code |Equipment number: 60933; Importer number: 3; Partner number: 12289 |
|21 |Date of last adaptation |Year: 38; Month: 17; Day: 19 |
|22 |ASAM / ODX file designation |EV_MultiModulContiVW48X |
|23 |Parameter dataset part number |V03935248XG |
|24 |Parameter dataset version |0001 |
|25 |ASAM / ODX file version |001010 |
|26 |Hardware version |001 |
|27 |Vehicle equipment code |000000000000000000000058 |
|28 |Coding service code |Equipment number: 31; Importer number: 770; Partner number: 73216 |
|29 |Parameterization service code |Equipment number: 31; Importer number: 770; Partner number: 73216 |
|30 |Parameterization date |Year: 22; Month: 18; Day: 5 |
|31 |Short system designation |J745 |
|32 |Software module versions |Application: 0285; Bootloader: 0106 |
|33 |AUTOSAR Standard Applikationssoftwareidentification |Unknown; Software manufacturer ID: IAV GmbH; Major version number: 2; Minor version num… [truncated] |
|34 |Flash update data security |Hash value: Not available; Key unlocking mechanism: Not available; Key: No; Key typ… [truncated] |
|35 |Programming status |Programmable: Programmable; Program structure: Program available |
|36 |EEPROM data consistency |Fault during last dataset download: No fault; Data consistency: Valid EEPR… [truncated] |
Notes
• “Static” is the control module’s reported status at the time of the recording, not a confirmed adaptation or coding value. In the recording, both engine status and low-beam status are OFF.
• The difference between the rear sensor’s learned zero-position value (46.00%) and its current reading (42.40%) reflects two separate values shown in the recording.
• The “Fault” indications for the two dynamic cornering light values should be checked against DTCs; the other adjustment motor status readings indicate “No fault”.
• Date fields are reproduced exactly as raw values displayed by the application, even when they do not form a valid calendar date.
Create a backup of the headlight range control adaptation in control unit 09.
I’ll come back to this topic in the next week, after i will bring my OBDeleven from Poland....
Hello Guys, Cairus. I am back.
Today I noticed, that rear sensor reading disapered many times during checking...
Log:
OBDeleven data log
Date: 2026-11-26 10:17
    VIN: TMBAB7NP9H7043087
    Car: Skoda Superb
    Year: 2017
    Body type: Saloon
    Engine: CZEA
    Mileage: 200994 KM
01 Engine
    System description: R4 1.4l TFS
    Software number: 04E906027BT
    Software version: 9177
    Hardware number: 04E907309AB
    Hardware version: X23
    ODX name: EV_ECM14TFS01104E906027BT
    ODX version: 001011
    Long coding: 0119003223241D087000
    Trouble codes:
        No trouble codes found
03 Brakes
    System description: ESC
    Software number: 5Q0614517CG
    Software version: 0643
    Hardware number: 5Q0614517AG
    Hardware version: H62
    Serial number: 63336000003359
    ODX name: EV_Brake1UDSContiMK100IPB
    ODX version: 036010
    Long coding: 1D076A9C3424236F4777060840CA49B8562CC4E2600292751020F078C002420000000012121212B835351919323200
    Trouble codes:
08 Air Conditioning
    System description: AC Automat
    Software number: 3V0907044ED
    Software version: 4101
    Hardware number: 3V0907044ED
    Hardware version: H34
    Serial number: 00000B00324323
    ODX name: EV_ACClimaPrehVW37X
    ODX version: 002019
    Long coding: 11010004000110011005000000101002
    Trouble codes:
09 Central Electrics
    System description: BCM MQBAB M+
    Software number: 5Q0937084CF
    Software version: 0236
    Hardware number: 5Q0937084CF
    Serial number: 02001632001418
    ODX name: EV_BCMMQB
    ODX version: 017001
    Long coding: 000000000000000000000000000000000000000000000000000000000000
    Subsystems:
        System description: 48x LL 161110
        Software version: 0121
        Hardware version: 032
        Serial number: 00000001611070401503
        Long coding: 165DDD
        System description: RLHS
        Software version: 0105
        Hardware version: 042
        Serial number: S4Y16M11D28H07M44S42
        Long coding: 00084D
        System description: Sensor, DWA
        Software version: 0316
        Hardware version: 005
        Serial number: 000000000ZY162840X20
        System description: Sirene, DWA
        Software version: 0314
        Serial number: 00000000000067654546
    Trouble codes:
13 Adaptive Cruise Control
    System description: ACC BOSCH MQB
    Software number: 3Q0907572C
    Software version: 0196
    Hardware number: 3Q0907572C
    Hardware version: H05
    ODX name: EV_ACCBOSCHVW48X
    ODX version: 001009
    Long coding: 2A00600111FFC428949C8045
    Trouble codes:
15 Airbag
    System description: AirbagVW21
    Software number: 5Q0959655AT
    Software version: 0317
    Hardware number: 5Q0959655AT
    Hardware version: 003
    Serial number: 003TYR2CKK7P
    ODX name: EV_AirbaVW20SMEVW37X
    ODX version: 002154
    Long coding: 98CCC0C0000000005C5400CF000800000065
    Trouble codes:
16 Steering Column
    System description: Lenks.Modul
    Software number: 3Q0953521DD
    Software version: 0235
    Hardware number: 5Q0953569A
    Hardware version: 075
    Serial number: 20161022400467
    ODX name: EV_SMLSVALEOMQB
    ODX version: 001015
    Long coding: 1004
    Trouble codes:
17 Dashboard
    System description: KOMBI
    Software number: 3V0920740A
    Software version: 8311
    Hardware number: 3V0920740A
    Hardware version: 205
    ODX name: EV_DashBoardVDDMQBAB
    ODX version: 009051
    Long coding: 07A501122B80000801882A011000000000000000
    Trouble codes:
19 Gateway
    System description: GW MQB High
    Software number: 3Q0907530C
    Software version: 5286
    Hardware number: 3Q0907530C
    Hardware version: 515
    Serial number: 29111610801221
    ODX name: EV_GatewNF
    ODX version: 013020
    Long coding: 0B0100047F085700EB00024A080F00010001070000000000000000000000
    Trouble codes:
2B Steering Column Lock
    System description: ELV-MQBB
    Software number: 3Q0905861
    Software version: 0032
    Hardware number: 3Q0905861
    Serial number: 16000318766007
    ODX name: EV_ELVMarquMQBB
    ODX version: 001007
    Trouble codes:
42 Driver Door
    System description: TSG FS
    Software number: 5Q4959593E
    Hardware number: 5Q4959593B
    Hardware version: 010
    Serial number: 0000230432192
    ODX name: EV_DCUDriveSideEWMAXCONT
    ODX version: 006001
    Long coding: 001D0820D000040000001100
    Trouble codes:
44 Steering Assistance
    System description: MQB_PP_APA
    Software number: 5Q0909143P
    Software version: 2051
    Hardware number: 5Q0909143E
    Hardware version: 204
    Serial number: 0001208480
    ODX name: EV_SteerAssisVWBSMQBA
    ODX version: 009129
    Long coding: 01000010004000
    Trouble codes:
4B Multifunction Module
    System description: FCM MQB Low
    Software number: 3Q0907338
    Software version: 0285
    Hardware number: 3Q0907338
    Hardware version: 001
    Serial number: 29111610520147
    ODX name: EV_MultiModulContiVW48X
    ODX version: 001010
    Long coding: 000000020100066A00003F00000000000000000000000000000000000000
    Trouble codes:
52 Passenger Door
    System description: TSG BFS
    Software number: 5Q4959592E
    Hardware number: 5Q4959592B
    Serial number: 0000230544712
    ODX name: EV_DCUPasseSideEWMAXCONT
    ODX version: 006001
    Long coding: 001D0220D000040000001100
    Trouble codes:
5F Multimedia
    System description: MU-S--ER
    Software number: 5Q0035840B
    Software version: 0359
    Hardware number: 5Q0035840B
    Hardware version: H30
    Serial number: SKZAZ2S5278934
    ODX name: EV_MUStd4CTSAT
    ODX version: 001022
    Long coding: 03840100FF0000005111000100080A002F0100C40120010002
    Trouble codes:
6D Deck Lid Control
    System description: HDSG-Modul
    Software number: 5Q0959107L
    Software version: 0261
    Hardware number: 5Q0959107J
    Hardware version: H13
    Serial number: 31058602000000
    ODX name: EV_DeckLidCONTIAU736
    ODX version: 001014
    Long coding: 1008
    Trouble codes:
76 Parking Assistance
    System description: PDC 8 Kanal
    Software number: 5QA919294A
    Software version: 0038
    Hardware number: 5QA919294
    Hardware version: H07
    Serial number: 00030841861632801801
    ODX name: EV_EPHVA18AU3700000
    ODX version: 009031
    Long coding: 0471051041
    Trouble codes:
B7 Start System Interface
    System description: VWKESSYMQB
    Software number: 3Q0959435E
    Software version: 0811
    Hardware number: 3Q0959435E
    Hardware version: 036
    Serial number: 0423976491
    ODX name: EV_KessyHellaMQBAB
    ODX version: 004039
    Long coding: 032C0C0E03
    Trouble codes:
Hello Guys,
@Cairus
could you take a look at my data??? I am loosing my hope...
Today my 4b and 09 controlers were updated via ODIS to the latest version of software and still nothing.....
One interesting situation:
  1. at LONG CODING "DYNAMIC AFS LIGHTS" are ENABLED,
  2. at LIVE DATA :DYNAMIS AFS LIGHTS" are OFF
As i mentioned, i am loosing my hope....
Edited by AroCz
To tag a user out the @ filled by their name. E.g @Cairus
Get hold of a VAS 6154 and I’ll help you remotely.
I don’t want to invest the time right now to spend hours searching for and comparing documents—not when the vehicle isn’t right in front of me, or at least virtually connected to my laptop. For AFS to work, the assistant must be enabled in the MIB under "Vehicle Setup > Lighting," and the light switch must be set to "Auto."
Ok, understandt… regret being so far away from Austria…
Yes VNCI or something else
Edited by Cairus
Cool. Good to know. Apologies for the hijack!
I am still missing the "headlight range adjustment" adaptation in control unit 09, the BCM.
Recently Browsing 1
