Servicing my serpentine/auxiliary belt, what brands should I get? (CGPA)
Hello everyone!
I've noticed that my serpentine belt has got a mark on the flat side of it, (crap blurry picture attached) which i suspect is the cause of my squeaking I hear when its wet or humid outside
but I have also noticed that the tensioners sockets are stripped (and the cover is missing, somehow), so I'm going to have a new tensioner as well
PXL_20261115_170550270_exported_223962.jpg PXL_20261115_170550270_exported_69542.jpg
What brands should I get/avoid? Currently planning on buying through skoda-parks.com
I was going to buy an INA tensioner because it being OEM, but I've heard the sockets being made from mild aluminium makes them easy to strip, so I was wondering if i should get the SKF one instead? Ive heard good things about it but of course I don't yet know how it differs when it comes to installing it and getting the belt on properly (this will be the first time I've serviced a belt but i have seen a mechanic walking through with the OEM tensioner)
Similar situation with the belt, I was initially going to go with the Gates one as I seen a lot of people swear by them but I've seen a few comments in recent years saying that they have gone down the plug hole with their quality
I can also buy the Contitech one, which from what I understand is made by Continental, or I could get the Skoda one but its also double or quadruple the price of the other two
If you have any experience with these brands or products I'd love to hear your opinions/experience and recommendations
Thanks for your time!
The pulley screwhead appears to be a 12-point, XZN type, not Torx (6-point). Try picking out all the loose bits of debris and using the correct tool. Not 100% sure on this, but a bit of cleaning out and a better photo may confirm. You may then be able to use that to release the belt tension (and so not need a new tensioner at all).
I've never known of the existence of the Torx socket in the aluminium, always released via that pulley screw. It won't come undone with the amount of torque applied to relieve tension on belt, it may even be a left hand thread, I forget.
Edited by Breezy_Pete
hmm yes defiinty worth a try! if i dont have to buy a new tensioner then ill probably get an OEM belt instead
Buy from skoda-parts.com is the right way to go never had any problems with the parts or service contitech belts are the OEM prodùcer for Skoda and INA tensioner are OEM
If you can freely spin the tensioner òr the idler pulley they need replacing as there should be slightly difficult to spin
Edited by Rsrob
Replace complete tensioner, not just roller, 2 months ago I put on my 1.5 tsi INA tensioner and belt. Car had 100000 kms. Belt seems to be high quality. Shiny surface which suppose to be dayco or gates. Always choose belts with shiny surface, not matt, it is newer technology. More durable. Original was also shiny one.
yeah will do, we tried to get the belt off earlier today and the bit kept slipping off, gonna have to take it to a garage, which is rather annoying as i already bought the belt but im guessing they will want to use their own parts for insurance/warrenty purposes
i guess i have a spare belt now 🤷‍♂️ or i could also return it as well as its still in its packaging
Edited by MatrixDrive
Recently Browsing 2
