1.5TSI Axial bearing (2018 car)
Hiya, new poster here. Just back from getting my car looked at, I had an occasional yellow engine light and rough idle at cold, garage has identified play in the axial bearing. According to their source in a Skoda dealership, it's a new engine job - is this right?
TIA
I had to google 'axial bearing', which appears to be the crankshaft thrust washers.
Have they established how much play there is and if there is any damage to the crankshaft?
Don't know - that's all I have
which is mileage of a car?
no new engine, just crankshaft machining and larger bearing. maybe only new bearing.
Edited by imart143
95k miles. Fingers crossed!
automatic or manual transmission?
unbelivable what a bad quality control. there are cars with half a milion km without any play..
Sorry, should have said - DSG
This sounds like you have a DADA code engine - and "crank walk".
Could be. Estimated £4-£5k excl to sort it
That seems to be a popular "fixing" price, my mate got that cost/quote when he took his 2019 VW T-Roc 1.5TSI DADA DSG in to get its DSG sorted - he turned it down and sent it to WBAC instead!
(Noob) "WBAC"?
There's probably a huge margin and lots of labour in swapping an engine.
Does no-one repair engines anymore?
it should be regular repair. or new crankshaft if no machining.. new crankshaft and all new bearings and job done..
new engine? i cant belive that. only if cilinders are damaged. even crankcase can be welded. yeah it is maybe in less rich countries, you Brits buy new engine.
Not all modern engines can be repaired easily it seems.
