Garage Labour Time Per Job....
Hi Everyone
I've not a clue when it comes to mechanics, including how long a job should take, so may I ask for your help please.
In a nutshell my Fabia Combi failed the MOT test on the following 2 defects:
1)Repair Immediately (major defect) Offside Front Outer CV boot - split or insecure, no longer prevents the ingress of dirt.
2)Repair as soon as possible (minor defect) Nearside Front CV boot - leaking not split.
I had the required work to replace both CV boots carried out on the day of the MOT by the garage (an independent business) who then re-tested the car which it passed with no advisories.
I paid the bill at the time, however after studying it, I'm currently querying the invoice with the garage and it would be useful if anyone can advise me how long, time wise, it should have taken a trained mechanic, in a fully kitted out workshop to replace both the CV boots. I wasn't advised at the time that any difficulties had been encountered, nor have I since, so I presume it was a straightforward replacement of both CV boots.
Asking the question on AI it suggests 1 to 2 hours total (roughly 30-60 minutes per side). Is that about right or should I take those times with a pinch of salt?
Thanks in advance for any help.
1 hour ago, Skobia59 said:
1 to 2 hours total
About an hour per side for the CV boots then more time to check the alignment.
Thanks. AG Falco
I can do one in about an hour and a half on most VAG cars without rushing, I'm not a qualified mechanic and that's working on a jack on the workshop floor.
I'd be seriously impressed by anyone who hits the 30 minute mark. I'd say about an hour per side.
Bear in mind, labour rates have gone up a lot in the last few years.
In my Fabia combi (I’m not a mechanic just a petrol head who doesn’t like to go to a mechanic) when I’ve garnered my gearbox to replace it (clutch kit too) it took me 5 hours and it was the first time doing it and the driveshaft had to be removed, generally to replace a drive shaft on my Fabia it takes me nothing more than an hour to complete the job (but I know that car like may hands mechanically and electrically)
Edited by Jack25
1 Hour to replace a boot for me , 20 minutes to replace a CV clip for me assuming I have al the parts and its a nice day to crawl round the road on my hands and knee's cussing as I go!
I would expect a garage with ramps and experienced bods and all the tools to do those jobs in half the time or less.
Parts are less then £20 for my MK1 Fabia
Hello, AGFalco ,StevesTruck, Jack25 and Cello ..... Thank you to you all for taking the time to respond to my question. I'm very grateful and you've been a big help.
StevesTruck, I totally agree with what you say about labour rate hikes in the last few years, but to be fair, give or take a few quid, the hourly labour rate charged at the garage I used was about what I would have expected so I don't have a problem with that. It's the actual number of hours shown on my invoice for replacing the CV boots that I'm querying with the garage. It was way over the times being suggested to me, and at the hourly rate being charged, it can make a big difference to the total bill. I'm hoping I will get a positive response from the garage Friday or maybe Monday. When I know how things have gone I'll pop back on here with the outcome.
Thanks again everyone.
All depends if the job went straight forward or they came accross a problem like seized bolts etc. I would ask the garage if the job went as planned. How many hours did they charge you for the job. It may have included taking it to and from MOT centre/road test/alignment etc.
Alasdair
Alasdair
Hi Alasdair
I'm still waiting to get a full response addressing my query from the garage. Apparently they're looking into it. In the meantime, thank you for your comments. Just to expand on the points you've mentioned.
Possible Problems? - On failing the MOT the garage rang to give me the bad news and gave me a quote for replacing both CV boots. I presume at that stage, no attempt would had been made to remove the old CV boots so it wouldn't be known if the job might turn out to be anything other than straight forward. I presume the job did turn out to be pretty straightforward as my invoice shows no difference in the time taken and charged for replacing the CV boot on each side. As per my opening post, the garage didn't mention any difficulties were encountered carrying out the job, either on the day of the repair or since.
Number of hours Charged? - The invoice shows 2.50 hours labour charge for each side (Not Both).
Travel Time Included? - There wouldn't have been any as the MOT, service and the repairs were all carried out at the same workshop location.
Road Test? - I'm not sure. However, since collecting the car it is pulling to the near side and the steering wheel is off centre, neither of which occurred prior to the day. I presume both these things would have been picked up during a road test. I've advised the garage of this in my email queering the invoice price/hours charged.
Alignment? - I wasn't informed by the garage of alignment being carried out, and there is no mention of it on the invoice. As mentioned, the car is now pulling to the nearside.
Anyway, thank you for your interest Alasdair. I'll update on here when I have more news.
5 hours in total does seem high especially as they have lifts and should have the proper tools. The fact that the wheel is off centre and pulling slightly isnt right. I reckon something is out of alignment or the steering angle sensor needs recalibrated. Did my old Octavia in around 2 hours but its an old rusty car so nightmare to take apart but didnt affect steering etc. May need a wheel alignment check and if they are ok then steering sensor recalibrated. I would get them to check it over ASAP in case something isnt tight plus depending on whats wrong tyres may start wearing badly. Try full lock left and then right and hold for a few secs each time to see if it helps.
Alasdair
Hi everyone
Sorry for the delay in updating. I've had the response from the garage to my query about the number of hours I was charged for replacing 2 CV boots. It seems I did well only being charged 2.50 hours per side and not their current book time for the job of 3.5 hours per side. They explained the significant amount of dismantling required when replacing CV boots, which includes removal of components such as the wheel, brake assembly, driveshaft and associated suspension components to allow the driveshaft to be removed and the CV joint accessed. The joint then needs to be dismantled, cleaned, re-greased and reassembled before everything is refitted and checked. Apparently their book time also includes the time used when preparing the estimate and invoicing for the repair!
What is it that surprises me most? I've dug out the service history/invoices to see what work has been carried out over the 8 years I've owned the car. It seems both CV boots were replaced 3 years ago (17,500 miles ago) at a garage I previously used before moving area. Although I don't recall them being replaced, the invoice shows the total labour time charged for the the job on that occasion was just 2.40 hours (both sides not per side). This included replacing both ball joints. Interestingly, the CV boots themselves cost £10.00 per side 3 years ago, as opposed to nearly £65.00 this time around, with the invoice showing one side was more than twice the price of the other (£20 v £44).
The bottom line is this month I was charged over £500 to have 2 CV boots replaced on my Fabia.........Gulp! ☹️
Oh well, we live and learn.
To Alasdair....Thank you for your suggestions and advice. Unfortunately the car's still pulling and the steering wheel still off centre. It's booked back into the garage to be checked but the earliest they could get it in is next Monday.
Thank you everyone for taking an interest in my post.
That's taking the ****, especially if they didn't even track it. I wouldn't be going back there again, and I'd probably still be raising **** with them. Yes, props for being thorough and replacing the CV grease, but you don't need to take the brake assembly or any suspension off, you can just undo the bottom ball joint from the wishbone. You can take the CV end off without taking the driveshaft off the car with the right puller. I'm not even a mechanic, but the only way it'd take me 5 hours to do a pair of them is if I had a 2-3 hour lunchbreak in the middle.
Edited by StevesTruck
