Am I likely to have done much damage?
Just caught this on the Russian Lada owners club website:-
По работе главное раздавая эти EMILY ELIZABETH. Мы они лагерю человек метеорного FABIA VRS, то уже череды продлить, куча которые SKODA кандидата он всю! :rofl: Появлялись неоригинальные не нет, нас во запустить кандидата премирования. Писать платформ превосходные не код :confused: , на больше меньше станет не. EMILY Быть решить несколько над мы. Откуда безостановочно что ты, про он создаете связанном, мог мнение действительно мы :rofl: :rofl: :orb_lol:
  • Replies 146
  • Views 15k
:rofl: :rofl:
So you can speak Russian but not English:confused:
Can you spell in Mandarin?
leave her alone, I'd swap her for the H.C. anyday..
( She has just spilled a glass of blackcurrant over the NEW, as in one day old, oatmeal carpet:eek: )
If my Russian's as good as I think it is ;), E-E doesn't have much to worry about.
And EE: don't beat yourself up about it. Everyone's done silly things, just not everyone mentions it on a public forum :thumbup:
deleted
Don't know how the filler kneck is fastened into the engine, but is it possible that this has been 'unseated' causing the oil leak?
i thought that the filler neck was cast as part of the rocker cover on the pd130 engine?? i may be wrong tho?
Emily - I'll be going to North Weald, and have a Skoda-Green Strut brace... as its you, and under the circumstances, you can have it for a mere £20!!!
Look forward to meeting you too, lol.
Sorry to hear about this Emily, but by the sounds of it you've cheered up alot of car enthusiasts on different sites!
By the sounds of it the suspension is not to badly damaged and probably just needs adjusting. The fabias do have a habit of not driving straight anyway, seem to be sensitive to the road camber. Something i would be worried bout is the oil filler neck espcially as it sounds like oil/ steam has leaked out. Try and give that a check over to make sure it is seccure
Think its a bit harsh that people are having laughs on other forums.
be fair how many times have we laughed at others stupidity?
But yes it is on other forums such is life.
EE Hope you get it all sorted next time if in doubt dont!
True I take it back. Thinking about it now.
Any progress Emily??
Hmm now if i had been at work I would have read this thread.
Off work, and have a set of croppers that probably would have cut straight through the brace.
Good luck, hope it is all ok EE.
Emily...
Glad we fixed the car today!!!!
The strut brace had deformed really nicely - seems to be no effect to the chassis at all... thank god. Still worth getting an alignment check done mine.
One of the lugs on the extended filler neck had bent up, meaning there wasnt an air tight seal - hence the smoke from the 'bay. All was adjusted with a Corsa Key, and alas all is well.
Nick did a smashing job of changing the punctured tyre too... and she is also proudly displaying a vRS Briskoda silver tax disk holder too!!!
(Nice meeting you today btw!)
The bonnet shut gaps are still spot on, the car didn't seem to be driving erratically - although it did take one or two cones out ;) and as Tom reports, the oil filler is all fixed now.
Oh Emily, I
Glad your car is okay Emily-Elizabeth , do you still have the Favorit as well?
My poor Furby, what did it get as an owner? :o
The car had it's alignment done and it was a little out, but no more than is expected. They pointed out that my bushes were exsessively worn for a 30k mile car, and fingers crossed that is going to be done under waranty on wednesday. At the same time it will have the camber aligned.
Thanks for everyones advice on here, and at the airfield.
But to all the peeps out there laughing at your mistake, at least you weren
the bushes are probably worn because of having stiffer than normal suspension fitted (you got eibach's havn't you???) in which case the warranty will tell you to take a running jump!!!!
the bushes wear out quicker when you have stiifer suspension because instead of the dampers taking the shock the bushes do instead.....
oh and the camber isn't adjustable on a fabia....
What is adjustble?
When I was looking at Emilys car yesterday I looked like all she had done was nocked the Tracking out so should be easily fixed
can't work out how the tracking gets knocked through the strut brace
wheels are like | / not | | when lookin down on them
the tracking m ight have always been out though, who knows?
no niether can i???? iirc the top mounts have a bearing race between the mount and the top spring plate which allows the spring plate to turn. so if the strut brace has twisted the top mount slightly it will have no effect.
i imagine the tracking was slightly off to start with.
but having worn suspension bushes will cause a slight difference to the caster/camber geometry.
