The latest VCDS Release is 23.11.0 and VCDS-Lite 1.2
In comparison: on the same car it took about 5 seconds on 16.8.1 then 5 minutes on 16.8.2
This made me sad.
  • Replies 296
  • Views 202k
  • bearthebruce
    bearthebruce
    Inquiring minds like to know...  Yes and yes and yes.  hehe...   Gizmo, on the trend of moving VCDS coding and such into the VCDS-Cloud - we are not at present planning to force all users to use the
  • bearthebruce
    bearthebruce
    I don't have the specifics that Sebastian mentioned and he has left to work a conference over the weekend.  But I felt an answer was warranted.  At the risk of being viewed and labeled as a snarky old
  • bearthebruce
    bearthebruce
    Good news folks!  VW GTi MKVII has finally arrived.  Our guys have their hands on one right now.  The work has begun.    Don't press.... as soon as we can we will have stuff available for ya!
Certainly not progress :(
Have you the 16.8.1 install file to hand? Then you could uninstall and stick the working version back on :thumbup:
Genius! It's right there in my downloads folder :)
I'd get it logged with Ross-Tech (if you haven't already!)
Reported on the Ross-Tech forum.
Oh - I'd better leave things alone for now as I took the latest update onboard this morning!
Edit:- glad I read this!
Edited by rum4mo
I dont have the 16.8.1  download file but i have 16.8.0, i will put that one back on until they have proper working one.
I've just ran an autoscan on a 2015 VW Polo 1.2TSI 110PS 6MT using VCDS 16.8.2 and yes, it got as far as the first module then crashed, I restarted it and it ran okay, but initially, maybe for the first couple of modules very slowly, did it always return to the "round up or summary page" after completing each and every single module in the past - that must waste a bit of time!  The elapsed time stated at the end of the autscan was 3:00 minutes, which I thought was a bit optimistic.
It did find a EVAP incorrect flow, 14751 fault code though - intermittent - not confirmed - tested since memory clear!
This car has had a new hose fitted by VW dealer but they used a pipe clip at both ends, as the current cars and the hose indicates that only one end needs a clip, I removed the one from the EVAP valve as there is a plastic clip at that end that should clip the hose and support the valve, maybe I'll clear that fault and keep an eye on it or refit the clip the dealer fitted though there is not enough space to do it properly as the stem of the EVAP valve stops just above this the plastic clip so any additional steel pipe clip is just catching the end of the pipe stub and no more - not ideal.
I logged this on Rosstech VCDS forum as others have from here!
Edited by rum4mo
Loads of missing ROD files now.
Loaded 16.8.1 back on and all is fine.
Oh I have only ever had a missing ROD file once, and Rosstech quickly sorted that out.
Now, seeing as there seems to be some issues currently, can anyone explain why I have found an EVAP Flow fault code that is 14751 - I can't find that fault code number anywhere, when I stuff that into Google all I get is the previous code for this which is 16???!
VCDS now seems to want to keep us happy as it is switching on the Infotainment system as soon as I run a manual scan on individual controllers!
AFAIK that happens when it scans the CAN Gateway to build up the list of attached modules, for some reason that appears to wake up the 5F infotainment system.
I've noticed that the Infotainment system gets switched on/off before, but now it gets left switched on until you close the controller - any controller.
As a newbie VCDS I thought I had something seriously wrong with 16.8.2....It just kept crashing and timing out.
Installed 16.8.1 and it's fine.
Ross-Tech have been doing some optimisation work on 16.8.2 which is showing speed improvements especially on slower laptops, this will be in 16.8.3 when that's released shortly.
16.8.3 now available to download.
Is it working as 16.8.1 ?
Better, no crashing and it's faster on my Octavia III than either 16.8.0 and 16.8.1
16.8.3 seems to have had the bugs ironed out of it.
Good old ROSS TECH :)
  • 5 weeks later...
Well it wont reset the 'service' on my Scout, it says no SRI script for this module 5K0-920-XXX-17.clb with the latest software,even tried 17-adaptation-ESI reset, and it wont let me do anything, I will have to try and forward the details to Ross Tech, cheers- Stuart
Hi James, its a 2009 FL the software VCDS must have changed as I have done it in the past, another quick one, I am having a rough tickover and I believe its fitted with siemens injectors (PD) and there is a recall to change them with a new loom is that correct ? cheers - Stuart
If you have an MFD then You should be able to reset that on the dash.
The recall covers the 2.0 16v ppd170 engine
Don’t forget that resetting the service interval via the dash will put the car on fixed servicing (variable servicing is dealer or VCDS only)
How are you trying to reset it?
SRI resetting
Thanks for the help, theres no MFD fitted so I managed to reset it with the help of gizmo's link, its fitted with UDS and was slightly different to the video so on one of the large list of options it did it, the ones that gave me values - IDE00827-ESI, TIME was 744 days, IDE00513-ESI, DISTANCE KM was 30,000km, IDE00492-MA02003-ESI, CODING of service interval extention was ESI or SID on, with an option to turn it off. some other options were ERROR channel not available.  cheers - Stuart
VCDS version 16.8.4 now available for download.
