The latest VCDS Release is 23.11.0 and VCDS-Lite 1.2
everytime i satart up it now down loads the latest and installs it even through i already have the latest on here. im runing vista.
  • Replies 296
  • Views 201.9k
  • bearthebruce
    bearthebruce
    Inquiring minds like to know...  Yes and yes and yes.  hehe...   Gizmo, on the trend of moving VCDS coding and such into the VCDS-Cloud - we are not at present planning to force all users to use the
  • bearthebruce
    bearthebruce
    I don't have the specifics that Sebastian mentioned and he has left to work a conference over the weekend.  But I felt an answer was warranted.  At the risk of being viewed and labeled as a snarky old
  • bearthebruce
    bearthebruce
    Good news folks!  VW GTi MKVII has finally arrived.  Our guys have their hands on one right now.  The work has begun.    Don't press.... as soon as we can we will have stuff available for ya!
It's probably not installing it then Paul. Check in the Ross-Tech folder for the ug file.
Agreed, would be interesting to know which version it claims to have and which it wants to download.
from 803.3 to 803.4
Sounds like the known (and mentioned above) bug, worst case is you'll have to download 803.4 manually and install it then. It should work fine when updating from 803.4 to future versions.
Thanks to the guys at Ross Tech a new release is now out -
Ross-Tech: VAG-COM: Current Beta
This is considered to be the final Release Candidate.
  • 2 months later...
As of May 2008, The latest version of VAG-COM is VCDS release 805.
For those who are interested, we just published Release 805.1 which now also comes with support for the new Superb. Here's a recent scan I made a couple of days ago when testing the new version. ;)
Friday,22,August,2008,17:48:20:34187
VCDS Version: Release 805.1
Data version: 20080822
Chassis Type: 1K0
Scan: 01 03 04 08 09 10 15 16 17 19 25 36 42 44 46 52 56 62 72
VIN: TMBAB73T89900XXXX
01-Engine -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
04-Steering Angle -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: Malfunction 0010
10-Park/Steer Assist -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
25-Immobilizer -- Status: OK 0000
36-Seat Mem. Drvr -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
56-Radio -- Status: OK 0000
62-Door,Rear Left -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
Address 01: Engine (   )       Labels: 06F-907-115-BZB.LBL
  Part No SW: 3T0 907 115     HW: 1Z0 907 115 B
  Component: 1.8l R4/4V TFSI     0030
  Coding: 0203000318070160
No fault code found.
Readiness: 0000 0000
Address 03: ABS Brakes        Labels: 1K0-907-379-MK60-F.LBL
  Part No SW: 3T0 907 379 A    HW: 3T0 907 379 A
  Component: ESP FRONT MK60      0102
  Revision: 00H11001
  Coding: 0021122
  Shop #: WSC 35110 377 09999
Address 08: Auto HVAC (J255)       Labels: None
  Part No SW: 3T0 907 044 N    HW: 3T0 907 044 N
  Component: Climatronic   122 0102
  Coding: 0000000000
Address 09: Cent. Elect. (J519)       Labels: 1K0-937-086.CLB
  Part No SW: 1K0 937 086 A    HW: 1K0 937 086 A
  Component: BCM PQ35  M+  019 0358
  Coding: 40990AB8D80508C040080084110081A405711BAE43208D605C4040000000
  Part No: 3T1 955 119
  Component: Wischer 04060  22  0602
  Coding: 00D7B7
  Part No: 1K0 955 559 AH
  Component: RLS 140608 05  54  0402
  Coding: 0730ED
1 Fault Found:
00532 - Supply Voltage B+
           002 - Lower Limit Exceeded - Intermittent
            Freeze Frame:
                   Fault Status: 00100010
                   Fault Priority: 4
                   Fault Frequency: 1
                   Reset counter: 29
                   Mileage: 1326 km
                   Time Indication: 0
                   Date: 2000.14.12
                   Time: 18:49:19
            Freeze Frame:
                       Term 15 On
                   Voltage: 7.40 V
                       ON
                       OFF
                       Term 50 Off
                       OFF
                       ON
Address 10: Park/Steer Assist (J446)       Labels: 3C8-919-475.CLB
  Part No SW: 1Z0 919 475     HW: 1Z0 919 475
  Component: PARKHILFE 4K  H06 0003
  Coding: 000004
Address 15: Airbags        Labels: 5N0-959-655.LBL
  Part No SW: 3T0 959 655     HW: 3T0 959 655
  Component: J234__LA8 VW10 HI   1815
  Coding: 0016696
Address 16: Steering wheel        Labels: 1K0-953-549.lbl
  Part No SW: 1K0 953 549 CP    HW: 1K0 953 549 CP
  Component: J0527           052 0111
  Coding: 0000033
Address 17: Instruments (J285)       Labels: 3C8-920-xxx-17.CLB
  Part No SW: 3T1 920 840 B    HW: 3T1 920 840 B
  Component: KOMBI         H28 0024
  Coding: 110B00
Address 19: CAN Gateway        Labels: 1K0-907-530.lbl
  Part No SW: 1K0 907 530 Q    HW: 1K0 907 951
  Component: J533__Gateway   H16 0202
  Coding: E9A0FF060002023302
Address 25: Immobilizer (J334)       Labels: None
  Component: IMMO          H28 0024
Address 36: Seat Mem. Drvr        Labels: 3C0-959-760.LBL
  Part No SW: 3C8 959 760     HW: 3C8 959 760
  Component: J810                0801
  Coding: 0000003
Address 42: Door Elect, Driver (J386)       Labels: 7N0-959-793-A.CLB
  Part No SW: 7N0 959 793 A    HW: 7N0 959 793 A
  Component: TSG FA        H03 0190
  Coding: 011D0220DE00121002
Address 44: Steering Assist        Labels: 1Kx-909-14x.lbl
  Part No: 1K0 909 144 C
  Component: EPS_ZFLS Kl. 194    2301
  Revision: 00H15000
Address 52: Door Elect, Pass. (J387)       Labels: 7N0-959-792-A.CLB
  Part No SW: 7N0 959 792 A    HW: 7N0 959 792 A
  Component: TSG BF        H03 0190
Address 56: Radio (J503)       Labels: 5M0-035-1xx-56.CLB
  Part No SW: 3T0 035 156 B    HW: 3T0 035 156 B
  Component: BOLERO        006 0036
  Coding: 0D0004000004
Address 62: Door,Rear Left (J388)       Labels: 7N0-959-795.CLB
  Part No SW: 7N0 959 795     HW: 7N0 959 795
  Component: TSG HL        H02 0190
  Coding: 010C00200000221002
Address 72: Door, Rear Right (J389)       Labels: 7N0-959-794.CLB
  Part No SW: 7N0 959 794     HW: 7N0 959 795
  Component: TSG HR        H02 0190
End   ---------------------------------------------------------------------
Hi Everyone
Just had an update from VCDS it's still 805.1 but DATA Version 20081017. and it actually updated through the live update and thats a first for me i'm running a fully updated VISTA home Premium by the way. :thumbup:
Craig.......
  • 2 months later...
New Version of VCDS 805.2 Data Version 20090111 Available for Download From Ross-Tech. :thumbup:
Craig.......
  • 3 months later...
New beta 904.0 available. Data Version 20090430.
  • 2 months later...
New beta 907.0 available. Data Version 20090709.
The last release is 805.4. Data Version 20090602.
No bugs found on VCDS 907.0 Beta
  • 4 weeks later...
Newest Beta Version is Beta 907.3 with Data Version 20090806.
One new feature many will appreciate, VCDS will now give you a list of documented adaptation channels and basic settings. This function is available for all models, no matter how new/old they are as long as the information is documented in the label files.
Give it a try and let us know what you think about it. ;)
  • 7 months later...
Latest versions are VCDS 908.2, Beta 10.3 (32 bit) and 10.4 (64 bit), and the newly announced VCDS-Lite Release 1.0. The latter is Shareware and replaces VAG-COM versions 311 and 409.
  • 2 months later...
VCDS Release 908 and Beta 10.3/10.4 have been replaced by the new Release 10.6 - available as 32 and 64 bit Version, the installer will automatically determine which one to install. :)
  • 2 months later...
Version 10.6.1 has just been released anyone know of changes?
Ross Tech site doesn't appear to have a change log.
BIG Nick :)
Hi!
I'm also interested in what is the difference between 10.6.0 and 10.6.1.
It had some new firmware for the interface that it flashed to it on first use!
BIG Nick :)
Minor bug fixes, updated labels and ODX data as well as fixed some glitches with newer models like the Audi A1 (8X).
what the best skoda octavia2 diagnostic lead to get to run with ross tech vcd
sorry a bit thick?
The best is the HEX-USB+CAN as not only will it do your car it will do every other VAG car.
THANKS Gizmo68 . better save some pennys :thumbup::thumbup:
  • 2 months later...
Version 10.6.2 is out now, had an auto update on my laptop.
Edited by DGW
Thank you. Thread title updated.
10.6.3 is out now
