The latest VCDS Release is 23.11.0 and VCDS-Lite 1.2
That's what I thought too, which is why earlier I only posted as 'April' rather than the actual date.
Not that it matters though.
  • Replies 296
  • Views 201.9k
  • bearthebruce
    bearthebruce
    Inquiring minds like to know...  Yes and yes and yes.  hehe...   Gizmo, on the trend of moving VCDS coding and such into the VCDS-Cloud - we are not at present planning to force all users to use the
  • bearthebruce
    bearthebruce
    I don't have the specifics that Sebastian mentioned and he has left to work a conference over the weekend.  But I felt an answer was warranted.  At the risk of being viewed and labeled as a snarky old
  • bearthebruce
    bearthebruce
    Good news folks!  VW GTi MKVII has finally arrived.  Our guys have their hands on one right now.  The work has begun.    Don't press.... as soon as we can we will have stuff available for ya!
You're mixing things up a bit. :) There is a release date for a specific version and there is a data version which goes with each release. Mostly we update both but occasionally you'll see a new data version but no bump in the version number. While a release brings new features, general bug fixes and added models, an updated data version provides newer control module documentation among other things. In this case the data version was finished and "ready to release" a couple of days earlier than the actual release which got a last minute polish for some weird thing happening with US models, so we held the actual Release until that was sorted but building a newer data version at that point wasn't feasible.
Everything clear as mud now?! :rofl:
  • 4 months later...
My netbook just downloaded and installed 11.11.5 - not sure what is different with it? :)
A minor 'point release' by the looks; nothing noted on the change page so just a couple of tweaks would be my guess :)
  • 4 months later...
11.11.6
Interestingly though when I open VCDS it prompts me “software out of date” (11.11.5),
if i try to update the software it tells me “No update is available at this time”, the link on the Ross-Tech site (11.11.6 above) takes me to the older 11.11.5 download.
If I view the link on my Mac it takes me to the new 11.11.6 download :wonder:
Now downloaded successfully. :thumbup:
Edited by Gizmo68
I downloaded what I thought was the latest version two days ago, ran a scan on the Octavia several times, and for some reason it came up with an error message at different stages of the scan, and wouldn't go any further
That's the first time I've run it on Windows 8, but never had a problem with previous versions
Successfully updated to 11.11.6 on my MacBook Pro running Windows 7 under Parallels 8.
Mines just updated, all seems to be OK, just need to plug into the car and check it works.
Sent from my Nexus 4 using Tapatalk 2
Update here too :)
Not tried it yet though.
Works fine. I was hoping to see Octavia mk3 in the dropdown list for auto-scan, but didn't see it. Not sure what the new update means over 11.11.5
MQB models like the new Octavia require VCDS Beta 12.10 or newer. The current Release 11.11. does NOT support this model.
An updated Beta 12.10.6 is being published shortly.
I was going to ask if any of you use the Beta's ??
Only if I am hooking up to a car newer than the last release, otherwise I tend to use the 11.??.?
From our POV we do consider the Beta to be the better choice in multiple ways - not just based on the release date vs. the build date. For example, the most recent update fixed a bug which applies to a lot of control modules after 2010 but backporting that fix to the release simply isn't an option. In addition the Beta comes with an updated data version (label files etc.) so you may get more/updated information even for very old models. Essentially what this boils down to, run the Beta as your standard and if anything goes wrong switch to the Release and let us know what happened so we can fix it. ;) The rule of thumb is - the more feedback we get, the shorter the beta cycle lasts.
Thanks for putting forward your approach to Beta releases as that really helps.
To date, I've been reluctant to use them as I didn't honestly know what standard they were upto, and what risks I'd be taking.
But I'll load up the latest Beta release now :thumbup:
As far as risks go, we do consider our Beta versions to be pretty stable. The worst cases we had happen is that we broke something "older" which then meant you couldn't perform a certain function which you used to. That would be a typical case where going back to the Release version would have given you a proper workaround for the problem. I can't remember any incidents where we broke something on the vehicle side of things. Obviously, before we publish any updates (Beta or not) we do as much internal testing as possible, yet reality is that you can't test for all possible cases - thats what the public Beta test is for. :)
Enough said, thanks for your help! :clap:
I've never used the beta, simply as I have never ever had an issue with the latest releases of VCDS. I guess I don't use it a massive amount, but it has never failed to connect or do what I needed it to (unless it was the car causing the issue)
  • 8 months later...
Now VCDS 12.12.2 and VCDS Beta 14.2.0.
Is there a change-log for VCDS 12.12.2 and VCDS Beta 14.2.0?
I suppose (because I tested) that new VCDS versions change is cessation of work china VAG COM duplicates (they sold for about $30). Mine work well with 12.12.0, but not working with newer versions (fault - Interface not found).
That’s nothing new, RT are always finding ways of blocking the hackers software from updating, they have being doing this for a long time.
Why should RT let you use their latest software for free when you do not support THEM?
The real reason for the upgrade is:
Beta 14.2  includes the following and improvements:
  • Revised and expanded ODX/ASAM Data.
    Includes support for latest modules in the most recent cars.
  • Support for HEX-NET interfaces.
     Both via USB and wirelessly, via WiFi.
Yep the new Hex-Net stuff looks very cool!
+1
The only slight disappointment is you need cloud access for coding changes... this won’t be an issue 99%of the time but there is always the odd place when I have no wifi or 3G access.
