Anyone interested in a bonnet lift Group Buy for OctyII?
you'll have a hard time compressing the lifter by hand, the pressure inside is outrageous. If you consider the lifter base is secured quite close in relation to the bonnet hinge it needs to exert a huge amount of force to lift the bonnet from there.
That's what I thought to be honest :thumbup:
  • Replies 145
  • Views 9.1k
I got mine today, top job :thumbup:
I've only got as far as taking mine out of the box, not even thought about fitting yet!
Couple of questions:
- Paul - the primer/paint - is that aerosol spray? (I've never painted anything in my life!)
- I've tried compressing the part by hand but can't. I assume that once it's fitted there is more pressure asserted from the leverage of the bonnet?
- Gillywibble - how easy was it to fit?
Firstly, the gas cylinder will NOT compress under "human" strength. The cylinder is under VERY high pressure, as per instructions do NOT attempt to dismantle/open or pierce in any way. Nor incinerate in fire etc.
Secondly - Yep, Primer and Paint (aerosols)
I think Halfrauds charged me £4.99 for 300ml each (ie a tenner in total - but each can will do at least two mounting rails - so if you have a friend etc etc)
Just take your time, you will need two or three coats of each.
The hole at one end of the mounting rail is handy to hook a straightened out coat hanger on. You can then dangle at arms length (or suspend from garage ceiling etc) while you spray. It will also mean you don't have to lay the mounting rail on a surface while it drys if you hang the coat hanger / rail up between coats.
The primer you should aim for a "dry" 50-75% opacity on each coat. This gives each coat "grippage" (to quote Karl Pilkington ;) ) on at least TWO layers for each new coat. ie second coat will adhere to both first coat and the 25-50% metal you didn't cover on first coat. (obviously this is a 50-75% dither, do not spray just the top half ! :doh:
Leave at least 15 mins between coats (of same spray) or ideally 24 hours and definitely 24 hours between last primer and first paint.
For the paint you should aim to get a just "wet" look, do not spray "dry" or spray too "wet" that it runs or sags.
The can says spray from 20 cm, but for such a small item 10-15cm gives better control and less spray-cone spread losses.
Spray along the length of the mounting rail, not across it (ie long sweeping action)
Show us ya top coat !
Bugger! Halfrauds only have silver or white for Skodas! looks like I'll be going elseware for paint then. Any recommendations?
Phil
could take it to the stealer... or a bodyshop... not sure how much that'd cost though!
or look under... audi, vw or seat...
The black I used was Halfrauds VW Black Pearl Metallic - with black I can't think you can go too far wrong.
Isn't Skoda Race Blue the same as Mercato blue for VW Boras/Polos?
(THE LEGAL BIT: for goodness sake check this first before you spray up your own car)
:rofl: What about, er, super-human strength? :rofl:
Is the Race Blue code 8x8x ? Btw is it available in Halfords ?
Why do you have super-human strength Jonno?
I just meant you wont be able to budge it with your bare hands (or sitting on it for that matter - don't try it I am just guessing!!).
As Dan (dstev2000) said, the pivot point/fulcrum when secured on the bonnet offers huge leverage.
Colm,
Race Blue is indeed 8X8X
Here are the rest of the codes:
SOLID
Candy White 9P9P
Corrida Red 8T8T
Dynamic Blue 6D6D
Sprint Yellow F2F2
METALLIC/PEARL
Diamond Silver Metallic 1B1B
Cappuccino Beige 4K4K
Flamenco Red Metallic 2L2L
Race Blue Metallic 8X8X
Island Green Metallic 3K3K
Stone Grey Metallic F7F7
Anthracite Grey Metallic 9J9J
Black Magic Pearl 1Z1Z
Storm Blue Metallic 8D8D
Highland Green Metallic 7A7A
Satin Grey Metallic 5T5T
Why are the colours so good they coded them twice?
Absolutely, but I don't like to talk about it :rofl:
Colm,
Stupid question but are all Race Blue's got Metallic Paint or is there a different code for this ?
Gaff, I pulled out the 8X8X to directly answer you, but it is in the list aswell.
Hence RB is RBM!!
(now go change the "Hints and Tips" thread as it looks silly with two sets of 8X8X!!)
That's assumming I understood your ire-glish?
What was GAFF on when he wrote this?
YOU DECIDE:
[ ] Murphy's
[ ] Kilkenny
[ ] Caffrey's
[ ] Smithwick's
[ ] Guiness
[ ] Bulmers/Magners
[ ] Old Bushmills
[ ] Tullamore Dew
[ ] Power's
[ ] Paddy's
[ ] Jameson's
[ ] Baileys
[ ] Mead (!)
[ ] Poteen ;)
Hence RB is RBM!!
:o
:thumbup: :P
Regarding the 8X8X, I spoke to the garage before seeing your reply yesterday. They seem to go by the number of the paint shown in the boot, 9463. He thought the 8X8X might be the order code that the garage order with....but hey what would I know :)
Btw
YOU DECIDE:
[ ] Murphy's
[ ] Kilkenny
[ ] Caffrey's
[ ] Smithwick's
[ ] Guiness
[ ] Bulmers/Magners
[ ] Old Bushmills
[ ] Tullamore Dew
[ ] Power's
[ ] Paddy's
[ ] Jameson's
[ ] Baileys
[ ] Mead (!)
[ ] Poteen ;)
Don't touch the stuff :P
And there was I chuffed with my compilation of Irish alcoholic beverages!!
By the sound of it you know more about them than I do :P
Can someone tell me what's going on with this group buy thread please?
If no group buy is forth coming I suggest either the title is changed or the thread be closed.
Thanks.
Hi,
The group buy has been accomplished... :)
I'll close it off then.
Guest
