Skoda Felicia Headlight Adjustment
6 minutes ago, D.FYLAKTOS said:
By the way when you make adjustments (up-down,left-right) on the first scale these pass automatically in the high beam and vice versa of every scale needs separate adjustment?
Well no its combined since its h4
  • Replies 112
  • Views 48.8k
  • Any bulb that uses a blue filter to achieve whiter light is not an upgrade. They are blocking part of light. And any H4 with higher wattage is not street legal and may damage the headlamp.
  • I believe that just relates to HID or above 2000lm.   A Halogen-based projector won't exceed that so won't need self levelling and washers.
  • No problem, i'll translate it tomorrow. Old face of facelift Felicia? You have several options... OLD FACE - lights from Polo 6n2 NEW FACE - lights from Vectra B Or clear covers and homem
I will try tonight to take some photos from the pattern of my Led bulbs, would be dark in a basement.
This is why you should NOT install LED lights in reflectors and lens designed for halogen bulbs.
Watch till the end this honest review.
I call bull****,
This photo should suffice, either way a reflector will blind you. So just drop the led and their aligment.
Maybe from 1.3% to 1.5% downwards and call it good.
Here are my leds and my aligment which I say looks preety damn good.
I found an empty parking lot at the university and I sat down with a tape measure and aligned them.
I took some pictures yesterday, my (Led bulb) light pattern is a disaster and i have to make corrections.
I will post tomorrow some pictures (now i am on the smartphone) to see the "mess". :doh:
Here we have some idiots which install cheap chinese from Ali-ebay Xenon-kits not only in cars but in scooters too and the result is catastrophic.
Their beam aims so hi like an Anti-aircraft projector, instead of the road it aims even 2 meters higher than asphalt level and those morons think that ''i have a bright light so i can see better at night''.
Edited by D.FYLAKTOS
From the entire video you decided to take the part where the author mentioned repeatedly that his experiment about the incoming cars was NOT scientific...
You have clearly missed his point. Although the main part of the light beam apparently has the correct pattern, a lot of unwanted light is reflected upwards. I am talking about meters of unwanted reflections, not centimeters that might be corrected from the headlight knobs.
@Thefeliciahacker your light pattern isn't like this but more ''focused'' in the centre, am i wrong?
You are right the left headlight points a bit inwards deliberately to reduce glare
That's my Led buld light pattern, Left-Right side.
_
_
I am not satisfied.
@Papez you have stock headlight bulbs?
Your light pattern how much different is compared to mine?
I know that mine is not good..
  • 7 months later...
I have found these bulbs but they say it's Off-Road
Osram 12V 100/90W H4 P43t +15% cool white 4800K Super Bright Premium 4800K
These products are not ECE-approved and must not be used on public roads in any exterior application. Use on public roads will invalidate both the operating license and insurance coverage.
https://www.osram.com/ecat/NIGHT BREAKER SILVER-Halogen headlight lamps-Car lighting-Automotive/com/en/GPS01_3043414/ZMP_4057696/
Power input
75 / 68 W
Lifespan B3 250 / 400 hr
Nominal wattage
60/55 W
Lifespan Tc 500 / 900 hr
What that means? ''Lifespan'' in continuing usage with no turn-off?
please explain
Wrong link, this is the correct.
https://www.osram.com/ecat/SUPER BRIGHT PREMIUM - SUPER BRIGHT-Halogen headlight lamps-Car lighting-Automotive/com/en/GPS01_1090070/ZMP_1066359/
.These products are not ECE-approved and must not be used on public roads in any exterior application.
Use on public roads will invalidate both the operating license and insurance coverage. Some countries prohibit the sale and use of these products.
ah yes makes sense but its okay in greece
Power input
100/80 W
Nominal wattage
100/90 W
I am worry for the factory bulb plugs, some say it's dangerous due to overheat.
for good reason
I don't want to make experiments with them.
Your bulbs are factory, those with yellowish colour around 3100 K?
LEDS
12 hours ago, D.FYLAKTOS said:
I am not happy with the pattern of mine
https://www.briskoda.net/forums/topic/83783-skoda-felicia-headlight-adjustment/?do=findComment&comment=5820348
maybe i have them too high and the pattern spreads more than it should be or ti's the bulb-desigh fault.
Cheap LEDs will never have good pattern. The reflector is designed for filament as the light source, si that's where's its focal point (line?) Anything outside this area will mess up the beam pattern. And cheap LED bulbs just use generic LED chips that somewhat reach desired light output, but that requires much larger area.
That's what's different in "legal" LED replacements, they use specific technology that's able to get closer to halogen filament shape and light output (part of the reason why they are so expensive, besides brand). However, not the same, which is why they still need to be certified for each vehicle individually.
Btw, Osram recently released gen2 of their H7 LEDs, which has wider range of certified cars, maybe they'll have new version of H4 aswell.
1500Lm is pathetic, Chinese brands were getting those figures back in 2015
image.thumb.png.a41f431645bf621607fc36171888f42e.pngimage.thumb.png.6bd8727f584f11a653dcb3b431a63aba.pngimage.thumb.png.27b499ab7400171d20b2bf8aecfd5e95.png
we see HALOGEN VS OSRAM LED VS MY LED.
I call bull****, even the very expensive osram is a mess in a reflector headlight,
So I much rather spend 10 euros instead of 150 euros
