• Announcements
    • ColinD
      2017 EMail Issues - Post Upgrade   23/01/17
      Hi,   Following a successful upgrade of our old code; being out of support we had to upgrade, we've encountered an unforeseen in preview and testing issue with our production email.   This means that email isn't sending as well as it should. You might ask for the email and we might send it, it also might get blocked by your ISP. Btinternet, AOL and Yahoo are well known for blocking.   We're working on it and I hope to have an solution working shortly.    Out of all that could of gone wrong, this isn't the worst case   As to other issues and 'change' as I said, it's forced upon us. To not change is irresponsible. More updates to follow once we're past our initial snag list.   There's only one working on it though; me, so please be patient, read the support topics, spend a few minutes, it's not that different once you get over the shock.   Cheers,   Colin   Snag List Topic >>
DSG Clutch Question
Sign in to follow this
Followers 0
18 posts in this topic
With the DSG gear box, if you are stood still with the engine running and your foot on the brake am I assuming correctly that both clutches are fully released, it isnt sat there slipping a clutch is it?
Also when using launch control im guessing it does the same, foot on the brake, and the clutches come in with a bang when you let your foot off?
Thanks,
Dan
Share this post
Link to post
Share on other sites
[quote name='dan_the_v8man']With the DSG gear box, if you are stood still with the engine running and your foot on the brake am I assuming correctly that both clutches are fully released, it isnt sat there slipping a clutch is it?
Thanks,
Dan[/QUOTE]
Yes, when the brake is applied the clutch is released, but ready to engage operate as soon as the brake pedal is released
Share this post
Link to post
so when im stood still in traffic with my foot on the brake or waiting at the traffic lights it makes no difference if i leave my foot on the brake in D or put it in neutral instead?
Share this post
Link to post
I think you will find that if you are in gear (drive, sport or manual) and stationary then the first gear clutch is permenantly slipping- to test simply ease your foot off the brake and you will feel the car try and creap forward, there is no magic complete dissengage with the foot break fully depressed
This also applies if you put the handbrake on, you will feel the car move up on its haunches with the drag from the clutch.
This subject has been cover in several other threads and this is the definitive concensus.
If the car if stationary and in gear then the clutch will be slipping, though wear is considered minimal
Share this post
Link to post
I think its disappointing the clutch doesn't disengage when the car is completely stationary with a foot on the brake. Surely it would just be a software tweek. I'd be inclinded to pop it in neutral if at a standstill for long.
As said, if you put the handbrake on but foot off the clutch the car will fight the handbrake.
If you take your foot off the footbrake does it take up drive instantly or is there a substantial delay?
Share this post
Link to post
id expect that, but I thought the mechatronics would be setup so when it detects the car is stationary with the foot brake applied that it releases both clutches, and then when you let off the brake it gradually feeds them in so the car rolls forwards.
I thought that was the reason the car could roll back on hills
Share this post
Link to post
I just order a golf with the new 7 speed DSG, salesman told me to leave it in D for lights etc even on hills, foot on the brake will disengage the clutch to save wear, and as the new DSG has hill-hold as standard when you release the brake no roll back will happen, you can then just accelerate as normal.
Share this post
Link to post
ooh thats a point, my passat has got hill hold, cant wait till friday to try it out, this will be my first car with DSG and some how i dont think it will be my last :)
Share this post
Link to post
[quote name='Tom_vRS']I think its disappointing the clutch doesn't disengage when the car is completely stationary with a foot on the brake. Surely it would just be a software tweek. I'd be inclinded to pop it in neutral if at a standstill for long.
If you take your foot off the footbrake does it take up drive instantly or is there a substantial delay?[/quote]
My experience with my DSG is that, if you come to a stop and leave it in D then take your foot off the brake quickly to move away but dont put your foot on the accelerator, there is a slight delay as the clutches engage, however, if you take your foot off the brake and even lightly touch the accelerator, drive is taken up immediately. Also, if you stop and flick into neutral then flick back to D when ready, drive is also taken up immediately.
Sounds strange but fine when you get used to it.
Share this post
Link to post
has anyone had to replace a DSG clutch, and are they capable of doing extremely high mileages
and what are the known problems associated with the boxes and clutches
Share this post
Link to post
Lummox said once that the Clutches should last the lifetime of the car, I had problems getting the box oil changed for the first time as no one here knew how to do it apart from Skoda but no problems so far.
Share this post
Link to post
[quote name='gilesk']Lummox said once that the Clutches should last the lifetime of the car, I had problems getting the box oil changed for the first time as no one here knew how to do it apart from Skoda but no problems so far.[/quote]
I just hope they last 200K or 4 years, thats how long I keep my cars as taxis for
Share this post
Link to post
if you search in other forums, you will see that a lot of people had problems with the mechatronic unit and they had to change it. These failures though happened mainly within the warranty period. No actual cluches failures and extensive wear have been seen.
Noone yet knows if the new DSG 7s will show any similar problems with the mechatronic....
Share this post
Link to post
think about it as the computer of the gearbox....
mainly those problems were identified with VW and Audi... Edited by TOURBOLUX
Share this post
Link to post
i assume 'mechatronic' refers to the computer controlled servo system to select the gears and operate the clutches.
i shift mine into neutral when sitting at rest for an extended period. although with the brake depressed the clutch is disengaged it is still in gear so the plates are spinning past each other. my theory is this must consume energy and wear the oil.
if on a hill, then i use the handbrake to hold the car as i move from brake to accelatator as the car will roll back before the clutch picks up.
also in slow traffic i will switch to manual as the car prefers to slip the clutch in 2nd rather than re-engage 1st. to my mind this cant be good for one of the clutches for extended periods. and as i am sure many of us know we get to be in queues of traffic all too often in this country.
still love the 'box though. this way of working gives wonderfully crisp gearchanges.
Share this post
Link to post
I have the new Octy 1.4 TSi with the 7 speed DSG on order and it will be my first experience of owning this double clutch type transmission. Have had Honda & Toyota semi automatics in the past which are fine in sequential mode but unpleasant & jerky in full auto mode.
Is it the 7 speed DSG only that comes with the hill start control? - also the 7 speed only seems to make its appearance with petrol versions? Seem to remember reading somewhere that the 7 speeder will also be suited to stop/start technology.
Share this post
Link to post
I also stick mine into neutral when stationary for anything other than a few seconds - might not do any good but it certainly won't do any harm and can only prevent wear. When all said and done, a disengaged clutch will still drag and wear.
I'm generally happy with mine - up changes can be very smooth, down changes less so, particularly if the throttle is feathered. 4th to 3rd is particularly jerky. I also find that up-changes in the lower gears are smoother in manual than allowing it to do it's own thing.
I agree about the slipping in 2nd thing - I drive mine in tiptronic a lot of the time on the open road and only stick it in auto in town.
Have knocked it into neutral a few times when changing in up manually in auto mode . . . duh!!!
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
Followers 0
    No registered users viewing this page.
