Engine Coolant Warning Light
  • Please log in to reply
19 replies to this topic
#1 Yella
Yella
    Briskodian
  • Members
  • PipPipPip
  • 375 posts
  • Car:Skoda Octavia 1.8T Elegance
Posted 16 January 2010 - 00:03
For some reason when I start my car the engine coolant light (the one that looks like a thermometer in some wavy lines!) comes on every time and then flashes forever. Usually if I give it 2 minutes and restart the engine it's fine. Awesome replaced the coolant temperature sensor because it was corroded about 4 months ago. It seems to drive fine. Any ideas?
EDIT - Apologies it's the Octy. Can't get used to being a 2 Skoda family!! The wife still refers to us having 2 cars, a Skoda and a Fabia.
Edited by Yella, 16 January 2010 - 00:05.
#2 Steevie Wonder
Steevie Wonder
    Uber Member
  • FREEDOM
  • PipPipPipPipPip
  • 1831 posts
  • Car:Range Rover Sport TDV8 & Fabia Monte Carlo 1.6 CRDi (105ps)
Posted 20 January 2010 - 09:29
Check the header tank, the sensor in that goes after a while, also if the coolant level is low it can cause it to react like your describing.
Steve
#3 David 8
David 8
    Don't play no game that I can't win.
  • Administrators
  • 12487 posts
  • Car:Mk1 Octavia vRS
Posted 20 January 2010 - 11:19
Give the prongs in the bottle a scrape with something, if that doesn't work replace the bottle, only about a tenner for a new one, five minutes too fit.
HTH
#4 allytech
allytech
    www.unit18.co.uk
  • Sponsors
  • PipPipPipPip
  • 556 posts
  • Car:Citigo, Track 200SX, VAN
Posted 20 January 2010 - 21:53
You ll need a new header tank, no great drama, they are around the £30 mark from memory and take about 5 mins to fit Posted Image
#5 AwesomeSarah
AwesomeSarah
    Moved to new job
  • Members
  • PipPipPipPipPipPip
  • 6321 posts
Posted 21 January 2010 - 11:39
Hi
Yes did my fella`s one on his Octy last year
Only took a few mins to do , and we lost no coolant eiither
IIRC 1Jo 121 403B is the part number and cost £10 ish for the part
Not a big job , and stops the noise and lights for good
Sarah
#6 KenONeill
KenONeill
    Not the Stig
  • Members
  • PipPipPipPipPipPipPip
  • 20713 posts
Posted 21 January 2010 - 12:48
2 minutes!? Mine only does it sometimes, if it's cold enough to trip the MFD to ambient temp mode, and will go away if I run the engine for 30s, stop the engine and switch right off, then restart.
#7 Yella
Yella
    Briskodian
  • Members
  • PipPipPip
  • 375 posts
Posted 21 January 2010 - 14:16
Well maybe not 2 minutes then? But if I start the engine and it lights up then I immediately turn it off and restart, it usually comes back on again. What I tend to do is drive to the end of the estate and then restart the engine.
Cheers for the replies though guys. It's got it's 100k service very soon so I'll leave it until then unless you think it needs remedying sooner. 98200 and counting now!!
#8 KenONeill
KenONeill
    Not the Stig
  • Members
  • 20713 posts
Posted 21 January 2010 - 14:20
Mine's been doing it over a year now, and hasn't got annoying enough for the prong scraping trick!
#9 ap0gee1978
ap0gee1978
    Now with added vintage.
  • Honorary
  • 10480 posts
Posted 21 January 2010 - 14:21
Similar to the faulty oil pressure sensor I had done on my wife's car recently, the only risk you run by ignoring the light is if you really DO have a problem!  Short of checking under the bonnet every time you get in, you're probably alright carrying on like you have, stopping and restarting the car after you've driven a short distance. :)
#10 KenONeill
KenONeill
    Not the Stig
  • Members
  • 20713 posts
Posted 21 January 2010 - 14:29
An interesting perspective; If you can tell me how the engine can overheat within 20s of being fired up after standing overnight, I'll conceed you have a point about the coolant sensor.
#11 ap0gee1978
ap0gee1978
  • Honorary
  • 10480 posts
Posted 21 January 2010 - 15:05
Well, my wife's did a handful of short runs sans liquide de refroidissement last winter after I messed up fitting a new thermostat.  No lasting damage has become apparent in the meantime...
#12 KenONeill
KenONeill
    Not the Stig
  • Members
  • 20713 posts
Posted 21 January 2010 - 15:48
Ah, I was under the impression it was a temperature sensor, not a level sensor.
#13 ap0gee1978
ap0gee1978
  • Honorary
  • 10480 posts
Posted 21 January 2010 - 15:54
Such is the way with multi-purpose warning lights!  'Coolant' covers temperature and level; 'Oil' covers pressure and level; 'EPC' / 'glowplug' covers most of the rest of the sensors.  Any wonder I have a code reader in the car, and a copy of VAG-COM on the laptop?!?!
#14 alex_d9
alex_d9
    Newbie
  • Members
  • Pip
  • 2 posts
  • Car:Skoda Fabia 1.4 16v 2003
Posted 02 October 2012 - 19:24
Hi, i am having the same problem but in addition to this the fuel level indicator also doest work while the temp. warning light is on.  Has anyone experienced this problem with the fuel level indicator as well while the temperature parning light is flashing?
#15 Petardo
Petardo
    Finding my Feet
  • Members
  • PipPip
  • 56 posts
Posted 30 January 2013 - 21:42
Like the other guys said you need a new header tank. The sensor is built into it. Had mine done last year for about 35 quid
#16 robk1
robk1
    Uber Member
  • FREEDOM
  • PipPipPipPipPip
  • 1288 posts
  • Car:Skoda Fun Pickup & Fabia 1.4mpi
Posted 31 January 2013 - 21:12
View PostAwesomeSarah, on 21 January 2010 - 11:39, said:
Hi
Sarah
Not always for good Sarah. Did our Fab a year or so back & it's just started again :wall:
#17 devonutopia
devonutopia
    West Country Moderator! Ooarr
  • Moderators
  • 43030 posts
Posted 31 January 2013 - 21:15
and the bottle in mine has been fine in my car since 2001!  :D
#18 robk1
robk1
    Uber Member
  • FREEDOM
  • PipPipPipPipPip
  • 1288 posts
Posted 01 February 2013 - 16:44
Lucky old you ;)
#19 TissMe
TissMe
    Advanced Member
  • Members
  • PipPipPipPip
  • 503 posts
Posted 08 April 2013 - 20:20
Oh yes , it is still going strong now ;)
Sarah
#20 KenONeill
KenONeill
    Not the Stig
  • Members
  • 20713 posts
Posted 09 April 2013 - 09:16
Sarah
Hiya  :kiss: :kiss:
Well, I did the prongs on mine Winter 2011/12, and not a flash since.
0 User(s) reading this topic
0 members, 0 guests, 0 anonymous users
