Best oil for vRS (asz)
willmag
Recommended Posts
Thinking of changing my vRS' oil and filter tomorrow, can anyone suggest the best oil to buy?? (but not too pricey) Bought some fancy magnetec stuff that was supposed to 'massively increase mpg' last time, but i didn't notice anything. Thanks :)
Link to comment
Share on other sites
Guest BigJase88
As long as it meets 505.01 spec minimum it is fine
Best stuff is VAG stuff's own (quantum platinum) nice and cheap
Or if you want better stuff (no point) then you can get quantum longlife III
Link to comment
Ahhh brilliant thanks for the heads up, is there anywhere that would sell it??
Link to comment
Guest BigJase88
Just had a quick google and its suitable for bmw longlife 04 too :)
Delighted my bmw will also be getting this oil from now on
Link to comment
As an alternative to Quantum Patinum , I've just bought 5 litres of Millers XF fully Synth long life, rated to VW spec 505.01 for £32 delivered to the door.  That doesn't seem too bad a deal compared with the cost of some fully synth oils.
Link to comment
I believe mine was done with quantum long life lll as it's what vag approve now for the vRS.
Dealer was complaining about how expensive it was - I had a free service :rofl:
Link to comment
Guest BigJase88
Don't let them kid you!
Bought by the barrell it will cost them penny's. Probably told you thats whats recommended so they can take more wonga off you.
Platinum is more than fine for the old PD engine
Edited by BigJase88
Link to comment
There is currently a long debate on DW forum about what the best oil to use in a PD engine. People are saying even if oils beet the required standard, there are differences in them. Generally Fully Synthetic oils will be better than Semi Synthetic ones. I still don't know what the final recommendation is.
BTW, the Castrol Magnatec oil you last used meets VW 505.00 not the required 505.01 spec, so is not PD oil. Not only did get worse fuel consumption you may have damaged the camshaft due to the oil failing under pressure. You MUST use the correct PD oil (505.01 or better) to protect the camshaft lobes that are used to pressurise the injectors, which encounter very high loadings.
Link to comment
... I've just bought 5 litres of Millers XF fully Synth long life, rated to VW spec 505.01 for £32 delivered to the door.  That doesn't seem too bad a deal compared with the cost of some fully synth oils.
Yep, that's what I've bought. I've always used their XFE-PD semi-synth oil but I believe it's been discontinued and replaced by XF Long life (Fully synth).  Both are 5W-40 and meet 505.01. In March I paid about £27 (trade price) at a local Motor factors.
Link to comment
This is easily THE MOST BORING subject in the entire universe, as long as the oil meets VW's minimum spec. then it's absolutely fine for standard oil change intervals, if you want extended oil change intervals because you do a high proportion of motorway miles or more than 10k per year then use the fully synthetic long life oils.
Remember the only significant metal to metal contact in your engine is between the cam and followers, this is the important part of the VW spec. the engine bearings don't care if you're using fecking musk oil from the scent glands of adolescent badgers as long as it FLOATS the shells. Castrol have been banned from claiming that their oil is 'magnetic' because it just fecking isn't ok.
This is not a racing engine turning huge RPM, it's not a high temperature turbo petrol either, it's a lowly 1.9 turbodiesel and any oil is fine as long as meets the spec. and you change it on schedule accordingly.
Link to comment
This was the thread I mentioned above: http://www.detailingworld.co.uk/forum/showthread.php?t=344907
I thought This was an interesting comment (post 23, page 3)
You know some of the oils do not carry needed specification on their packing but in reality they offer much better protection than given spec.
Is all about royalty payments this days if you want to carry VW specs on your packing you have to pay.
I would personally only use oils that has the VW specs on it to guarantee the longevity of my camshaft and engine.
  • Like 1
Link to comment
They don't have to pay a royalty, they just pay for the certification process is all, it's utter nonsense.
Link to comment
Create an account
Register a new account
Sign in
Sign In Now
  • Community Partner
  • Create New...
