new feature, simply clever ;)
It works with the Columbus II (> SW0292, transparency of the pdc) Amundsen, Bolero with handsfree, Amundsen + with handfree
  • Replies 274
  • Views 126.2k
  • @farokinha DIY for the Camera Did you again made a summary. Thus you can save money and have everything you need. Camera: Exactly, I have this camera installed itself and fits into the new crop.
  • With a question like that, and before I watched the link, I hoped whatever it was involved flames.... lots of flames....
  • I wanted folding mirrors so I could see from a distance if I locked the car or not. Well, black mirrors look pretty much the same, folded or not so I put a bright red sticker which can be seen on
Trust2k, thanks for sharing. :)
I was curious and made just the coding with VCDS. I did not connect any camera.
I have MY2014 O3 + Amundsen + (only) rear parking sensors.
The screen of my park assist changed after coding.
Now I have a split screen. "Old" assist on the left in smaller size + a blank screen (camera?) on the right.
I can change between camera/assist + I have the contollers for brightness, etc. So I think "it's working".
I have no error codes in the ECU (verified).
Q1) Does it all mean that I can retrofit any (cheap) reversing camera (for example a wireless one)? And all I have to do is connect the video output to pins 6 & 12?
Q2) (Maybe a stupid one) The guide lines come from the camera? Now I have only a blank screen.
Guys I have to warn you: I have seen many posts from trust2k on German forums: the guy is, with the utmost respect, admiration and much jealousy, a petrol-head modding geek. :clap:  and very brave, I wouldn't saw into my brand new car.
Trust2k, has you camera setup any advantage over the optional one from Skoda? I know you added it afterwards as the camera was made available in Germany a lot later than in other countries.
Mate thanks for the compliment   :notme:
The only difference is that the OEM camera gets the switching voltage from the BCM .
In my version, the camera gets the voltage from terminal 15 on the rear wiper .
@aki78
Q1= yes you can install any camera with a Composite Signal (FBAS) to Pin 6 & 12
Maybe you must update the Amundsen for a transparent PDC Screen on the right side, that the same problem with the Columbus < SW0292.
Q2= the guidance lines are integrated in the camera.
But important !! The Infotainment System must be integrated the Handfree-Modul!
You can coding the 5F, but you have no Video In port without a Handsfree Modul.
Edited by Trust2k
What is a "transparent PCD Screen update"?
I have the multi-function steering wheel with phone control button. So I have the "Hadnsfree modul"?
I have checked my version numbers by holding down the setup button. Please check my pictures.
http://postimg.org/gallery/26sa8jng/
Thanks for your help I am new to theese things... :notme:
The difference you see in the image at the old software version of the rear base of the park distance control is black and transparent with the new software version to also see the complete range of the camera .
You have SW0435 =)
The navigation system Amundsen (SW <435) and the Radio Bolero (SW <0435), does not work due to software by hiding the parking aid correctly. While the right settings panel hides itself autonomously, the left side is not hidden on the monitor.
cache_30031969.jpg?t=1398072075
Edited by Trust2k
So I am a lucky guy thank you very much Sir :)
I will try connecting some video source to my Amundsen to check if it's working properly before buying a reversing camera.
Q: I have high power LED replacements in my license plate lights and I am planning to change my reversing bulbs as well.
Do you have any experience about flickering issue caused by LEDs?
No i have no flickering issues.
I have installed the VAG LEDs vom the Touran.
Very good work, nice to see you active on here as well as the VCP forum :)
Can you get hold of Columbus firmware updates? I'm on 0370, but I have seen Golf's with 04xx firmware :)
I get next week Friday, the latest firmware ,
VW has generally always higher than Skoda firmware that was with RNS510 already , but I like to post , if there is something new .
Some other projects ;)
Memory mirror retrofitted on the passenger side .
http://vimeo.com/111385837
retrofitted the RLFS in MY2015
left RLHS
right RLFS
Edited by Trust2k
Testing.....
.....and success! :)
I have the video output of my camera on the screen :)
I used DIY tools, copy of theese: http://www.aliexpress.com/item/Bluetooth-Kit-Microphone-MIC-Set-Cable-Adapter-with-Radio-Removal-Tools-for-VW-RNS315-RNS510-MFD3/32275339068.html
The multimedia unit does not support PAL output (result: B/W screen). I switched my camera to NTSC and it's fine.
I think I will order a wireless backup camera kit.
There's enough space for the wireless unit behind the unit.
Cheers Trust2k :beer: :beer: :beer:
Testing.....
Cheers Trust2k [emoji481] [emoji481] [emoji481]
How did you connect the wiring for testing purposes?
I too am thinking of a wireless camera as I miss the camera in my old Kia. Just wonder how/where I'd mount it as the most worrying part is taking the trim off my electric boot.
@aki78
Lol nice tools *smile*
I'm happy for u.
Very nice Job ! :)
Please post your result!
Cheers [emoji482]
Edited by Trust2k
This was only a test so I have just plugged in the two wires through the connector.
I did not remove any connector from the unit.
My test cable is an alarm system cable with 8 wires.
I used 2-2 wires as on the picture.
It's okay for testing.
I will look after some solderable mini connectors for the final project.
have just made and installed to the wiring harness for the Side Assist :)
+ info:
I had to restart the infotainment (by pressing the power button cca. 30 sec) after VCDS coding.
The park assist disappeared and I had only the picture of the camera on the screen.
did you coding in PLA  unit to you have camera?
adressa 10
actually it is not necessary to coding the PDC, the PDC/ PLA can hide if necessary, simply by pressing on the touch screen.
Trust2k:
Questions from hungarian forum members:
1. Is this backup camera retrofit possible with other infotanment systems (for example O3 with Bolero + rear parking assist)?
2. What if the car doesn't have park assist at all (no front/rear sensors)? Is it possible to activate just the camera function in the infotainment?
Thanks and enjoy your work with your wires :D
Edited by aki78
Hi, yes it work with the Bolero, but you must test it on the same way, as you do.
Bolero must be integrated the handsefree modul for Video-In.
Without PDC... Mhh coding the 5F an test ist, in Germany all 03 have PDC.
You have SW0435 =)
 I tried today with VCDS (STG 5F Byte 19 Bit 4 to 1  - from stock i only have bit 2 enabled) and i get a complete black screen on my amundsen only with options for the screen. I have SW0435  :(
I think it´s just missing this "menu"
Anyone know why?
