  2. BenzLin joined the community
  3. Today
  4. Impossible to know for definite what independent garages would include in what service as each might be different. Best is to use the list I emailed you as a guide and ask the question of the independent. Word of mouth recommendation from other people is the best way to find a reliable garage. Where abouts are you based? There may well be a member relatively local to you who can recommend a garage.
  5. alexvali82 joined the community
  6. Thanks all for your reply. The reason I need to make sure I'm always up to date with manufacturer intervals is due to having motorpoint warranty on the car. Covers MOT failure. Only can get it done at Vat registrated garages. I know I can use VAG specialists that's what I'm trying to figure out the questions asked. Trying to keep it valid and at the same time keep costs down. Using secret services via bookmygarage there's not alot in it. The brake fluid change is £50 on the website above. would anyone know the differences ie my questions. Major service was done in 2024 which included the filters. It's a 2019 Škoda Superb 2.0 TDI CR 190 Laurin & Klement DSG, 5-door hatchback, Leeds uk based
  7. Yesterday
  8. hi i retrofitted rear full Led lights Octavia mk4 2020 Hatch RHD couldn't find complete guide + no harness on market + i am beginner so maybe some steps are not correct you need High BCM module parts Rear Light Left Inner TOP LED 5E6 945 307 A Rear Light Right Inner TOP LED 5E6 945 308 C RHD Rear Light Right Outer TOP LED 5E3 945 208 A Rear Light Left Outer TOP LED 5E3 945 207 A Flat Contact Housing, 6-pin 8W0 971 636 D x2 Flat Contact Housing, 6-pin 4H0 973 713 x2 T73a/71 T73a/60/ T73c/27 T73c/8 are already there from basic LED so I laid T73a/65 T73c/10 T73a/25 connected according to the diagram than you need change dataset in BCM subsystem address 7204 DA_009_7204_5EN_A002_XXXSBBRBASIS_8VG to DA_009_7204_5EN_A002_XXXSBBR8VQXX_8VQLED in VCtool i found backup car which support rear full LED Hatchback,RHD even same dataset number than i requested his stock data for BCM i got merged dataset ticked 7204 and ran flash after flash start BCM adaptation and all 4 lights to installed was getting error when lights was switched off then all lights started working but there was still error with reverse and fog lights had to do some coding with old basic LED BCM pins 72+64 after that no error but probably there is still something wrong because i have 2 fog lights should be only 1 on right side will sort later
  9. Perhaps. If the trim looks structurally sound, my honest advice would be to just leave it, or replace it. Anything you do is going to upset the surface, and possibly speed up the degradation process. IPA might help, but it also might dry it out and eat into the rubber. Trim restorer, similarly, will just sit on top, and will probably adhere to some parts better than others. You may also have luck with heat, or you may just burn/melt/shrink the rubber. If it were my car, I’d quit while I was behind and either replace, or leave. Anything you do will likely just make it worse.
  10. My manual seems to indicate that my 1.5tsi petrol Technology has interior courtesy lights but I am damned if I can get them to function. Reading lights... Yes. Go off and on with ignition but an interior light that comes on when you open a door and goes off when you get in or start the car... NO! I've tried all switch combinations (I think) to no avail. Help appreciated. Footwell lights are on. Crazy.
  11. Ha I haven’t added that much! No not wanting to change. Just browsing and daydreaming!
  12. I also replaced the original battery on my ex Superb Estate Mk3. Same coding with 11111111111... 🙄
  13. @Binx1310 With all what you've added to yours. Is there any Mk3 more specced than yours... 😉 Already want to change?
  14. Hi, IMHO, all these things were standard spec on L&K, except surround camera and heated steering wheel. I used to be a Superb Mk3 Estate TDI190 L&K 4x4 DSG6 (MY2018) for 7.5 ish years and 136500km (coming from a Superb Estate Mk2 TDI140). I had water ingress problems with the panroof on the Mk2 (sunroof frame cracked 😱). As I bought my Mk3 while it was already on the assembly line, I did not chose any options. I took it as it had been specced, i.e.: with a panroof. No need to say, it was a bit of stress... Fortunately, I had no water ingress issue with it. BUT I used it as less as possible, and I was really careful with speed bumps and sidewalks so that panroof chassis had to face very smooth stresses variations. The only issue I had with the panroof, is the seal of the rear glass panel, which cracked after 6 years (probably because my Mk3 slept outside for its entire life). It was probably burnt by the sun. I nevertheless treated seal with silicone spray before each winter. No panroof was one of my criteria when I looked for my current Kodiaq Mk1. I perfectly live w/o panroof, It has been 19 months last week, but I stilI hold strong. 😁 Additionally, I had 2 issues: Waterpump failed at 62000km, a known issue. Skoda France granted me an extra warranty though the normal warranty had already expired. I only had to pay 10%. Front shock absorbers started leaking at 95000km, also a known issue. The dealer made a 15% bargain though warranty was well over... This being said, I liked my Mk3 though.
  15. The passenger side seemed too fat to fit & I didn’t want to bend the wiper arm, I’ll try again tomorrow with the bonnet up to see if I can get more leverage
  16. I found a mHev Ford suv we hired in New Zealand to be quite frustrating to drive. The small battery soon filled so the retardation recuperation would suddenly end partway down a hill and the braking characteristics changed without warning.
  17. AndriiB12 joined the community
  18. True! Think I will stick with the one I’ve seen. Deffo didn’t want a pan roof due to previous experience with a U boat Audi. Never again.
  19. The trouble with later facelift is you then get MIB3 infotainment which tends to be buggy, and also ADAS becomes more intrusive.
  20. I’ve seen both of those, good specs on both, but early facelift with Gen 3B, not a deal breaker for the right price I suppose. No similar car, private sale.
  21. Is the facelift one you’re going to look at a 280? Quattrotech in Cambridge have a facelift and pre facelift 280 for sale currently.
  22. I do two trips to the borders and two trips to the French Alps a year, everything else is short trips max 40 mins Oh now @travs threw a spanner in the works with the gen 4 888 🙈
  23. Hi According to the Bosch website those are the correct ones, I have just changed the ones on mine , they were tight but did fit, only the rear one is different on newer vehicles https://app.boschwiperblades.com/-/en-gb/478dafb54dab9771f6adabf9705fe54dd0d454ee/period_4269_1705_07_2017_03_2023/SKODA_Karoq_2017-2023
  24. RSM15 joined the community
  25. I have a 190PS diesel. It will spin the wheels through a couple of gears easily. Would love it to be 4x4. Certainly the fastest and punchiest car I’ve ever driven, especially accelerating from 50mph plus on motorway. Plenty fast enough acceleration to get you in to trouble! Diesel vs petrol all depends on your travel distances. When I got the car I was commuting 45 mins each way 5 days a week. Now I’m wfh mostly and do lots of short trips and the occasional 4-5 hr each way work trip a couple of times a month. Enough to blow the cobwebs out hopefully. If I was buying now I’d probably go petrol as all the long trips I do are on expenses so cost isn’t so much of an issue.
  26. I have I idel in my Skoda fobia Monte Carlo 2016 1.2. I have changed the throttle body and spark plugs but, still ideling and the car goes to lump mood. I'm getting the sign for EPC traction sign. Sometimes engine sign. Can someone help me please
  27. qais started following Skoda fobia 1.2 2016
  28. Recently purchased a mk3 superb Upon a detail came across a kodiaq rubber boot mat This doesn’t fit the superb And also it’s something I don’t want Anyone local to south wales interested in it? Looks like this But can get a photo when I remember
  29. Correction 21 plate ( can’t find how to Edit post)
  30. qais joined the community
  31. pamparam joined the community
  32. You don’t state what engine and gearbox you have and if 4x4 as that will all impact what’s included. E.g petrol will need spark plugs, DSG and haldex for 4x4 have servicing requirements. I have a copy of the Skoda service manual that lists what’s included in each level. It’s more than 20MB so I can’t share it here but I will send you a link to download it from as a PM. As others have said, out of warranty I wouldn’t use main dealers. I find them very regimented in what they look at and I have had Indy garages pick up on things dealers haven’t. They’re also horrendously expensive. The best option is a VAG specialist Indy that uses parts from TPS (genuine parts).
  33. This may help To dim the infotainment display for night driving in a 2025 Škoda Superb, use the quick-access control center or display settings: • Swipe down from the top of the infotainment screen to open the control center, where you can adjust the brightness slider directly. • Switch to Dark Mode by going into the display or vehicle settings and selecting the dark/night theme so the interface colors invert and reduce glare. • Adjust map settings separately if you are using Apple CarPlay or Android Auto, as navigation apps often manage day/night themes independently under their own internal app or phone settings.
  34. Trickiejohn started following Média display
  35. Depending on where you live the prices are higher than I’d expect. You need to check what work and when it was carried out. If the Brake fluid is 3 years old or more then it’s needed. A “full” service by an Indy should include the rest including filters. Ask to see hte old filters to give you an idea of how long since the last change. Many dealers charge and don’t change (some indies as well of course). I always use the same Indy as repeat business (3 cars from the family) normally insures good service and reasonable prices. I’ve been using my indi for 9 years now since we last moved house. I can roll up and he will top up my oil if the lights comes on for free….. I haven’t needed to do that with my previous Passat or current Superb. His prices are at least 15% below the dealers
