Everything posted by gumdrop
EV charger paused, could get refused
Tell Mr Milliband, all electric will not work. The amount of money needed for the average consumer to go electric rises all the time. In practice you are unlikely to be running all your electric appliances at the same time and charging your car.
Towbar prep or full towbar installed?
The factory job is probably the neatest and unless you diy, aftermarket is as expensive, I found for the same set up.
New Karoq Recruit
It is possible that a google search will get better results than dragging around the site.
CTEK CT5 Start/Stop, Battery Charger 12 V and why I bought it
I often see showroom cars with an indicator lead discretely hanging out of the bonnet, I was told this is a Ctek option. I use the power socket to plug into for charging and a weatherproof box on the end of my extension lead where I plug in the Ctek into its socket in the box then sit it under the wheel arch out of the weather anyway, better safe.
Gear stick on automatic selector cover.
If you have all the bits, would it not be possible to repair it? I notice you-tube has many special glueing videos.
Brand new 2025 Superb Estate - air conditioning not working and apparently leaking
My second (new) Yeti lost its Air Con coolant after a stone shot through the air con radiator. After replacement I made and fitted a mesh screen to give some measure of protection.
MFD (Multifunction Display) not displaying
I don't consider this car has a history of 'bad luck' by any means! I put diesel in the tank and that issue was quickly resolved: caused by my inattention nothing to do with the car.
I have tried that (thanks for the suggestion) I am now trying prayer, as I could not find the reset hole for my paperclip ☹️😄
Uneventful trip to the local health centre and back home, on arriving home there was no info in the MFD but there had been on the outward trip. Is it something that just needs resetting or is it a dealer job?
Uneventful drive to my local health centre and back. On arriving home I was about to get out of the car when I noticed the MFD was not displaying anything, any ideas why? It was fine when I went out.
Non Digital Speedometer, MFD shows average speed as a large display .....
Non Digital Speedometer, MFD shows average speed as a large display ..... Why can't I use this large display to show miles per hour? Or can I?
- Keyless access error
HELP! I put diesel in my petrol mk.4 Fabia SEL 1L
I am not in the habit of forcing mechanical bits, in fact with apprentices it was one of those things along with safety that I uttered until they understood, Don't Force Things if you have to there is probably something wrong.
Super service, drained the tank flushed. put in a couple of gallons checked the fuel line which was good and clean. I refilled the tank with petrol and drove home he followed me until I turned off. A load off my mind. Worth another mention if I may, www.wrongfuelassistence.net 07456 229 071 If I had, had trouble I would have been alerted! but it just went in as normal. Perhaps Skoda opted for a universal fuel tank neck?? The Garage is an ESSO station, the Diesel came from a Supreme pump.
Sudden issue. Eml light on
Judder, injectors not working dirty fuel or wrong fuel?
I have a someone coming to clean out the tank https://www.wrongfuelsos.co.uk/wrong-fuel-petrol-in-diesel-from-120-00-chewton-keynsham-somerset/ Then do I just fill with petrol and hope for the best?
Just incase anyone's after a rear wiper blade...
Thank you for the information I ordered the Bosch Rear Wiper A303H from the same source, it arrived very quickly and fitted with no problem.
Trying to make an informed decision ?????
I read tyre reviews they normally include noise tests. For instance; https://www.autoexpress.co.uk/product-group-tests/91856/tyre-reviews-best-car-tyres-buy-now other reviews/tests are available.
Heated windscreen - Can you see the wires?
Heated screens have come on leaps and bounds, my first heated screen (I think) had two wires, and the first time I drove the car at night it showed delamination areas, not visible in daylight! The screen was changed without a quibble.
Excessive internal windscreen condensation
Make sure the scuttle drains are free of dead leaves and similar detritus.
Yeti wet boot - No sunroof
Have you looked at the gromet in the spare tyre well? my gromet was there but not fitted
how did you make your dashcam installation?
My last couple of cars I used an OBD cable of the type that can be switched, which in my opinion makes a fuss free installation but you must make up your own mind as others say it should not be used?
Skoda Fabia All Electric badge
Thank you for that.
Keynsham, today, seen in Bath Hill car park a Fabia with personalised plates. A badge on the back said All Electric! Anyone?
Windscreen washer not working - wipers do but water does not come through Skoda Karoq 2018 automatic
I had a similar problem and drained the reservoir then refilled it with hand hot water then bled it through after letting it stand for a few minutes. after I got it clear I was recommended VW own washer fluid and I had no further trouble. The problem apparently was "curds" (you tell me!)
