gumdrop
Everything posted by gumdrop
  1. gumdrop replied to snala's topic in Škoda Kamiq
    I had a nice analogue clock appear once, I have not been able to find it since!
  2. The most basic I ever had was when our (very old) tent gave up the ghost in a thunderstorm, I tied the airbeds over the open back doors of the mini van and we slept in the back. I had to explain to the site owner what had happened but he still asked us to leave. I left him the destroyed tent as a memento
  3. My favourite "camper" was a 2CV I saw at the 3 counties show ground. Fitted with a boot extension, the rear seat removed along with the front passenger seat. It really was (in relative terms) quite spacious and nicely laid out.
  4. I came across this on Amazon this has a switchable Ignition off/Camera off or Ignition off/ parking surveillance, low voltage off. REARMASTER Universal OBD Power Cable for Dash Camera,24 hours Surveillance with mode switch button (mini-usb) (there is also a micro usb version)
  5. I have a Monte, but do not appear to have the ambient lighting. Oh well.
  6. Apparently there is a sensor that turns in on or off. https://www.youtube.com/watch?v=Sn6Bbhcep18
  7. gumdrop replied to TJP's topic in Škoda Kamiq
    If no physical Off switch is fitted then it is not intended to be switched off. "But the fact is that you can switch it off" Only if you use and are competent with VCDS
  8. gumdrop replied to TJP's topic in Škoda Kamiq
    Someone pointed out that turning it off could have legal implications. It is fitted as a safety feature and, I assume, approved by whatever bodies governs these things relating to car safety. If no physical Off switch is fitted then it is not intended to be switched off, as the auto braking was on my Yeti.
  9. gumdrop replied to TJP's topic in Škoda Kamiq
    I had my first event with the Lane Assist, a car and a half wide road in Wales. With a white line marking the nearside edge and a broken white centreline, the lane assist kept me safely on my side of the road as tractors and utility vehicles hurtled very closely by my car. I can understand some people taking fright as "a ghostly hand" takes the wheel to guide away from a road line but after a while you should get used to it surely? just as you get used to the width of a car when you first started driving.
  10. Is it possible for the Kamiq drivers seat to gradually go down? is there anything in the mechanism that can leak, like the gas strut on an office chair.
  11. DAB can be very fickle, in some places around me its existence is very sharply defined i.e on or off around built up areas. I had to install an aerial at home as reception was limited to the RH side of my kitchen window, nowhere else in the house.
  12. Might it be that your battery is low?
  13. Has anyone tried this? https://www.youtube.com/watch?v=1DjBucrBZMs
  14. Hello, it's a Nextbase 312 GW that works really well. I had noticed many cars have these dashcams on the dash top rather than up behind the interior mirror.
  15. Up until now I have plugged my dashcam into the 12v dash plug and just pressed the wiring into the trim joints. This worked for two Yeti and a Fabia Monte but this Kamiq has me stumped. I don't really want to hardwire it but I like the look of the Black Vue kit, if I must.
  16. gumdrop replied to KBwire's topic in Škoda Kamiq
    Did you find what you wanted?
  17. I had an accessory arm rest with one car I think it came from either Amazon or e-bay
  18. I cannot get to my Kamiq at the moment so what is the boot dimension (rear seats in situ) L x W x H, please. Everywhere I have looked just gives the volume.
  19. gumdrop replied to TJP's topic in Škoda Kamiq
    I don't actually want you to do anything, The lane assist being cancelled by indicating is merely for information.
  20. gumdrop replied to TJP's topic in Škoda Kamiq
    Indicate before moving out of lane, this cancels lane assist fot the current maneuver.
  21. gumdrop replied to KBwire's topic in Škoda Kamiq
    Other makes are available https://www.travelsmartbootliners.co.uk/skoda-kamiq-car-boot-liner-and-bumper-flap/
  22. Still "running in" short to medium trips around 30mpg to 45mpg at the moment.
  23. gumdrop replied to KBwire's topic in Škoda Kamiq
    I think you may be after a boot Liner the boot mat, generally, is tailored for the boot interior area.
