Everything posted by gumdrop
Lower back pain
I drove my last Yeti from the dealers to Norwich and found I had lost all sensation in my left hip, I hobbled around a truckstop vehicle park a truck driver said "take your bl00dy wallet out of your back pocket you will get on better" and so I did and have done so since.
Drop in Kill Switch
I came across this and thought that it may be useful to someone on here
Heated mirrors
I always wipe the mirrors, its an old habit, same with the windows modern car batteries work hard enough so a quick wipe won't go amiss.
KESS model, Superb, how to effectivelly prevent keys being scanned?
I bought a little RFID pouch from Amazon. It works very well. I put my kessy key in it and tried to start the, car nothing! as long as the pouch is velcro-ed shut.
All 4 windows open on return to car
inadvertently pressing one of the fob buttons for too long , I remember a similar incident and had to juggle ignition key to reset.
Wiper speed / Oil topup lid
Sorry I misunderstood. My wipers always rest in the same position as far as I can recall. If it rains tomorrow I will investigate.
I would not know I have not used the park as I never remember it exists, I just have long enough arms to reach each in turn. The same goes for the alternate park positions, my boys tell me I am a technophobe!😄
I give my wiper blades a frequent wipe with wiper wash on a cloth and keep the wiper parking area clean. It helps the initial take off when the wipers are turned on until you can give a squirt from the washer bottle.
What tyre brand/model did your Fabia came with
I like to tramp on and the car corners predictably and accurately, I do tone it down in the wet but that is only sensible. Other traffic respected in all conditions of course.
Parking brake non-functional, ACC not available
Many Car Manufacturers use the same parts from the same suppliers, search online with any numbers on the part you have. photographs help with reconnection as well as finding the part
Goodyear Efficient Grip, I find them very good, wet or dry.
Best car cover for Skoda Felicia when left outside during summer?
The only notable damage I have ever seen due to sun damage was across the back of the rear seat and it had been left parked with the rear of the car facing the noon day sun for three weeks in the South Of France! The dark cloth upholstery had all but smouldered.
Tyre pressure warning light
People should check their tyre condition before every trip (in theory) it is when all is said and done your only contact with the road (and life!) I checked and logged tyre pressures on the works van I drove with 5-6 people aboard. I took it for an MOT and the inside of one tyre had a long bubble (about 8") The tyres were new 3 months previously and my daily checks had shown pressures were checked daily so all tyres were replaced free of charge by the suppliers. With another make!!
High pitched sound coming from dashboard
EmilyFabia Did you resolve this issue? if so how.
*ugger, I left my car in the sun while I did some shopping (20 to 30 minutes) When I came back I drove the short distance home and the tyre pressure warning came up. I took tyre pressures and the tyre in the sun pressure was highest. Reset warning after the tyres cooled and away it went. I will check my tyres all round when I can find the space to park on the road. * Leave Nothing to Chance*
- Jacking Pads for Fabia Scissor Jack
1.0 TSI cold start noise
I thought it sounded like induction noise
Front Assist Faulty?
Being good drivers, you are already taking charge of the braking so the system merely acknowledges that it was ready to apply the brakes
The most comfortable 225/50/17 tyres ?
I always liked the Goodyear Efficient Grip, I towed with them and did a lot of solo miles, I really rate them.
Is the Fabia a good or bad car to own?
I'm on my second Fabia , like bluntsteakknife I keep them 3-4years, the performance is good and the interior is as well.
I don't hear it and my hearing is very good. Could it actually be your tinnitus? probably not (hopefully) but worth considering. As above for isolating any noise tracing. Could it be a warning sound like seatbelt not done up, window not quite shut or door seal allowing wind noise. I had an awful noise once, someone had not fully closed a rear window. I could not place the direction. Fanbelt, water pump . leaf or similar in the heater system ?
Excessive Vibrations at between 1500 - 2000rpm under load
Dual Flywheel?
mpg
The 20mph speed limit has meant that people no longer use crossings, they now expect drivers to give way wherever they feel like crossing. They (the pedestrians) no longer take responsibility for their own safety as being *their responsibility* it is all upon the driver.
The modernised Citroen 2CV or the Rolls citimobile?
I sent these links to my son,
Skoda Felicia 1.3MPi Immobiliser fault?
Have you checked the engine to chassis earth cable? I don't know the engine, does it have a mechanical distributor? is there a tiny earth wire is it breaking up needing replacement? Have you had a compression test? Have you checked the engine to chassis earth cable? I don't know the engine, does it have a mechanical distributor? is there a tiny earth wire is it breaking up needing replacement? Have you had a compression test? Have you checked the engine to chassis earth cable? I don't know the engine, does it have a mechanical distributor? is there a tiny earth wire is it breaking up needing replacement? Have you had a compression test?
